Old 09-30-2005, 11:45 AM   #1
drewdogg
Member#: 90003
2005 STi
Default Running Lean - Maybe?
Hey guys, I finished a 1.8->2.2 swap running on 1.8 ecu a few weeks ago and have been kinda fine tuning and chasing CEL's since then. I got most all CEL's except for a EGR temp sensor, which according to FSM's there isnt one... but any way im side tracking the real problem......
Right now when i try to push the car fairly hard or better yet when i try to give it more gas than it takes to cruise, or am going up a hill fairly steadily and try to push it more, the engine will bog. The engine will just lose all power and feel almost like im downshifting. I back off the gas a bit and it jumps right back to where it left off-literally. This is getting real annoying especially when i wanna accelerate any more than an old lady. I did put in a 2.5 fuel pump in so i doubt its not getting enough gas, but im thinking that since this is doing it under heavier loads and im opening the throttle letting in more air than the engine/ecu can handle... maybe(?)
Could even be the idle air control letting in too much air. I did try blocking it off cuz i was having idle problems for a while and it ran great when it was hot. But then when the engine was cold, it was having trouble starting so i put a smaller hose on it to allow some air so it would start, but small enough to drive. Maybe i'll give blocking that off another try.
Any thoughts are greatly appreciated.
drewdogg is offline   Reply With Quote
Old 09-30-2005, 03:52 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
Try a tank of good gas to make sure it's not pulling timing under load. 1.8 ECUs have agressive timing maps....moreso than some other ECUs.
A small clamp on the fuel return line will temporarily bump fuel pressure as you increase the amount you crimp it. With this and a gauge, it can be useful in seeing if you're getting enough fuel (regardless of what pump you have in).
Jay Storm
Old 09-30-2005, 04:27 PM   #3
drewdogg
Member#: 90003
2005 STi
Ok i'll try that...
Oh i meant to put this in before, but i'm also getting around 21 mpg!!!
sti car runs lean wont stay running =( with (video!) sti3573 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 28 12-16-2009 01:24 PM
wrx runs better in warm weather. Am i running lean? DLBWRXR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-16-2006 09:59 AM
Running lean on top end ('98 vs. '99)? Force[FED] Legacy Forum 3 01-29-2001 01:00 PM
How Do U Know if Your Car is Running Lean? Xscreamer General Forum Archive 7 08-29-2000 09:45 PM
Running Lean? What type of Gauges? Ethan Technical Forum Archive 4 05-24-2000 11:59 AM
