Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 09-27-2005, 07:30 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default JDM CONTAINER LANDED - Transmissions, Engines, Suspension, etc.
Hey all,
We just got a massive container in with tons of goodies on it. It will take us awhile to get everything up on here so bear with us.
Motors:
-JDM V7 EJ205 Long Block!!
-JDM V7 EJ205 (Legacy 2.0 Turbo)
-Higher compression Pistons
-JDM WRX AVCS (higher lift / duration cams)
-JDM WRX AVCS head / valvetrain
-Not included - Intake/exhaust manifold, injectors
-Less than 1000km on engine
-Great for WRX engine swaps (isntallation is as easy as getting rid of the plastic instake manifold and dropping the WRX manifold in - AVCS is additional wiring)
SOLD, THANKS!!!
Add JDM AVCS ECU for - $399
JDM WRX EJ205 ENGINE FAQ
-1X JDM FXT EJ257 Engine with the cam sensor adapter - MANUAL
-This is essentially a NEW USDM EJ25 STI engine, minus the red intake manifold. The real difference between the FXT and the USDM STI (250HP versus 300HP) is tuning, turbo size, and intercooler size. The short block is identica (save the crankshaft)! The heads are identical!
-Less than 1000KM!!
-2.5 Liter, AVCS, etc.
-Long Block includes all pumps, sensors, intake manifold, alternator, etc
-The best bang for the buck power and torque bolt-in motor on the market.
$2999 + shipping
We're still going through the trannys and and heads so those will be posted later. If at all possible, please refrain from asking for availibility on these items until after they have been posted. Thanks!
STi items:
STi Pink Springs - 04+WRX/STi
-Designed by STi to work with your stock Struts
-Doesn't lower your car too much: -.5" all around for STi, -1" all around for WRX.
-Will retain excellent ride quality while lowering car's center of gravity for increased handling prowess.
-Spring rates: Front: 258 lbs/in; Rear: 218 lbs/in
$379 shipped!!!
STi Group-N Strut Top Mounts - 04+ WRX / 04+ STi
-Stronger version of the stock style upper mounts. Hardened material increases suspension response by reducing flexing and camber changes. Good intermediate modification to maintain streetability over full-blown metal pillowball upper mounts. Easy bolt-on installation with no modifications necessary.
*Front Strut Top Mounts will work for all WRX model years.
$110 shipped for front!!!
$185 shipped for rear!!!
$279 shipped for F and R!!!
STi Group-N Strut Top Mounts and STi Pink Spring Combo - 04+ WRX / 04+ STi
$639 shipped!!!
STi V-Limited Lip- 04+WRX/STi
$579 shipped!!!
More to come!
Gruppe-S is offline
Old 09-27-2005, 08:14 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Cusco!
Cusco V2 Lower Arm Bar - 02+ WRX / 04+ STi
-The purpose of the Cusco lower arm bar is to reduce alinement flexing and improve body rigidity. The lateral arm improves body and rigidity by connecting at the lower arm points. Thus preventing body flex and therefore dramatically improving steering, throttle response and traction. The Version II Bar mounts by multiple bolts and the lateral and foe aft rigidity is greatly increased over Version I.
$150 shipped!!!
Cusco 22mm Rear Sway Bar (3-way Adjustable) - 02+ WRX
-Often described as the single most aggressive suspension modification for your Impreza, the addition of stiffer swaybars properly distributes cornering forces by reducing lateral sway applying increased cornering force on the outside wheel and will ultimately increase vehicle turning characteristics. The rear sway bar will increase oversteer and allow the car to turn tighter, while the front sway bar will have the tendency to increase understeer.
$155 shipped!!!
Helix Rear Endlinks - 02+ WRX
-Helix Solid Endlinks are CNC machined from high strength aluminum. This makes an excellent replacement for your factory plastic endlinks which tend to twist and bend upon corner-loading. The addition of Helix Solid Endlinks significantly increases cornering response and tightness, regardless of the use of an aftermarket sway bar or not. The use of spherical bearings allows for a much wider range of angular movement and eliminates the squeaking and creaking associated with the deterioration of rubber or urethane bushings. The spherical bearings are teflon coated to prevent dirt and debris from fouling movement.
$79 shipped!!!
Helix Rear Endlinks + Cusco 22mm Rear Sway Bar Combo - 02+ WRX
$229 shipped!!!
Cusco 22mm Front Sway Bar - 04+ STi
$155 shipped!!!
Cusco Pillowball Upper Mounts - 02+ WRX / 04+ STi
-Designed to work with your stock struts.
-The full pillowball design controls unwanted forces under acceleration and braking. Stable steering response in essense and lane changing improved stability over bumps and holds roll in corners. Enables linear handling and keeps you on the record line better. Stability and safety during turn-ins and under braking. Camber adjustable by sliding the plate and pillowball sections.
$219 shipped for Front!!!
$219 shipped for Rear!!!
$419 shipped for Both!!!
Cusco Engine/Tranny Mount Combo - 02+ WRX / 04+ STi
-By reducing flex found in the stock mounts, these mounts will dramatically decrease engine and tranny movement.
$250 shipped!!!
Cusco Shifter Bushings - 02+ WRX / 04+ STi
-The Cusco Shifter Bushing is designed to replace the soft rubber bushing found at the anchor point of your shifter assembly. This upgraded bushing greatly improves the feel of the shifter by eliminating that spongy feel you get when changing gears.
$37 shipped!!!
Thanks,
Geoff
510-783-5300
[email protected]
Gruppe-S is offline
Old 09-27-2005, 08:39 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Gruppe-S is offline
Old 09-28-2005, 12:37 AM   #4
schuey_1
Member Sales Rating: (3)
Member#: 72524
05 Subaru WRX Sti
Hi how hard is it to install the Cusco Shifter Bushings.
Thanks
Rj
schuey_1 is offline
Old 09-28-2005, 01:34 PM   #5
tantrum
Member Sales Rating: (4)
Member#: 91608
2003 WRX
Midnight Black
Thanks
Rj
I would like to know the same thing
tantrum is offline
Old 09-28-2005, 06:10 PM   #6
eatus ravenous
Member Sales Rating: (14)
Member#: 26068
please check your Email ... thanks
eatus ravenous is offline
Old 09-28-2005, 07:08 PM   #7
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Thanks
Rj
They're quite easy to install. On our books, it's a half hour job.
Thanks,
Geoff
Gruppe-S is offline
Old 09-29-2005, 04:54 AM   #8
b4437
Member#: 23162
2006 300c,forester x
silver steel
pm you,geoff.
b4437 is offline
Old 09-29-2005, 07:29 AM   #9
ShaggyGT
Member Sales Rating: (27)
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
ShaggyGT is offline
Old 09-29-2005, 04:43 PM   #10
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hey Matt,
Those are the only pictures we have of them at the moment. I will try to snap some pics of them when I have a free moment.
Thanks,
Geoff
Gruppe-S is offline
Old 09-29-2005, 04:47 PM   #11
Bishop
Member Sales Rating: (108)
Member#: 59993
Ass, grass or cash
no one rides for free!!
geoff,
will the STi V-Limited Lip- 04+WRX/STi fit an 04 wagon?
Bishop is offline
Old 09-29-2005, 05:02 PM   #12
nvrenuf
Member#: 20638
2003 wrx & turbo si
sonic yellow,black
Does ur motor come with wiring harness and all that stuff
nvrenuf is offline
Old 09-29-2005, 06:26 PM   #13
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Originally Posted by J*Bishop
geoff,
Hello,
This lip will not fit an 04 wagon unless you put sedan fenders and STi side bumper thingys on your wagon.
Our motors do not come with any exhaust components, the IC, the turbo, the harness, or the ECU. These items can all be purchased separated at a discounted price if you buy the motor from us.
Thanks,
Geoff
Gruppe-S is offline
Old 09-29-2005, 06:32 PM   #14
Bishop
Member#: 59993
Ass, grass or cash
Originally Posted by Gruppe-S
Hello,
Thanks,
Geoff
bummer. thx
Bishop is offline
Closed Thread
JDM Container landed. Three JDM STI's for part out. One is a spec c! Kingpin Interior/Dressup/Audio & Security 53 04-17-2005 11:28 PM
JDM Container Landed! Kingpin Drivetrain 61 11-08-2004 07:59 PM
JDM Container Landed!!! Kingpin Interior/Dressup/Audio & Security 62 07-10-2004 03:23 PM
JDM Container Landed Kingpin Engine/Power/Exhaust 56 07-09-2004 02:58 PM
JDM Container Landed!!! Kingpin Wheels/Tires 17 06-17-2004 11:53 AM
