Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
View Poll Results: STi strut issues?
Yes 38 51.35%
No 36 48.65%
Voters: 74. You may not vote on this poll
Old 09-27-2005, 08:15 PM   #1
poison
Member#: 37678
Default How many STi owners/STi takeoff owners don't have strut issues?
Poll. If you have issues, please post specifics.
poison is offline   Reply With Quote
Old 09-27-2005, 08:18 PM   #2
jweiss
Member#: 31636
2005 STi & '82 911
CGM & rosewood
No issues here (because I took them off after 300 miles and put them in the corner of my garage )
jweiss is offline   Reply With Quote
Old 09-27-2005, 08:20 PM   #3
MD04WRX
Member#: 72891
2014 Molten ST
2000 2.5RS - 2014 XV
Subaru Banner
I have JDM STi V8 Spec C take offs. No problems at all.
MD04WRX is offline   Reply With Quote
Old 09-27-2005, 09:50 PM   #4
Okita Souji
Member#: 41097
2005 WRX
JDM V8 Takeoffs with JDM pinks. No problems.
Okita Souji is offline   Reply With Quote
Old 09-27-2005, 10:24 PM   #5
BIGSKYWRX
Member#: 7958
09 GH B+
Lets see- v7 STi sedan struts (w/ RA springs, Grp N tops) ~ 30,000 miles- no problems, v7 STi wagon struts (w/ STi wagon springs, Grp N tops)~ 10,000 miles - no problems, v8 wagon inverted struts (w/ STi pink wagon springs, Grp N tops) ~ 10,000 miles- no problems.
Knock on wood I've had no problem w/ any of the STi struts I've run (can't say the same w/ my old DMS inverted struts).
It's obvious the inverted design is more susceptible to stiction issues, but it sounds like w/ some lubing that much of the time it is alleviated.
Big Sky
Old 09-27-2005, 10:53 PM   #6
Thumper23
Member#: 11571
had my passenger rear strut replaced under warranty at 13k, problem started at 10k
no problems since
Thumper23 is offline   Reply With Quote
Old 09-28-2005, 12:41 AM   #7
Javier
Member#: 19346
2003 MBP WRX
Wiseco / Oliver EJ257
12345
Javier is offline   Reply With Quote
Old 09-28-2005, 12:46 AM   #8
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
US STi Struts, JDM pinks, no problems I know of.
THAWA is offline   Reply With Quote
Old 09-28-2005, 02:06 AM   #9
JIM THEO
Member#: 29715
2004 WRX
WR blue
JDM Spec C take offs with Prodrive springs here, NO problem so far after 20000km but have put small grease nipples in the rears in order to lubricate them from time to time with white silicon grease!
Great solution!
JIM THEO is offline   Reply With Quote
Old 09-28-2005, 03:22 AM   #10
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Great solution!
Nice idea Jim. So did you just drill a hole and insert a grease fitting? Post a pic if you can.
My unscientific hobby theory is that after some time the area around the bushings/bearings that locate the inner strut lose their grease as its slowly wiped away. This bushing then starts to see some wear and the interface generates some and thestrut insert starts knocking. regular lubrication helps keep this area smooth and free. Just my theory.
Arnie is offline   Reply With Quote
Old 09-28-2005, 04:50 AM   #11
JIM THEO
Member#: 29715
2004 WRX
WR blue
Exactly Arnie, this is what happens!
I drill some holes in the area between upper-lower bearings that keep in place the inner shaft and put small grease nipples.
As simple as that, I did it many times in friend's struts none of them has clunking problems so far and one has already covered 70000km!
Of course you should lubricate them frequently say 5-10000km ore every second service time with white silicon grease for suspensions.
JIM
Old 09-28-2005, 07:31 AM   #12
jamal
Member#: 71875
98 Legacy GT
my wheels fit
My left rear sits a little lower sometimes and clunks. I plan on lubing them to see if it helps. I get the feeling Subaru won't warranty the take-off struts on my 93 Legacy, even if they only have about 2k miles. Oh, they're v8 US struts and springs.
The grease fitting is a pretty neat idea.
jamal is offline   Reply With Quote
Old 09-28-2005, 07:36 AM   #13
Siper2
Member#: 1134
2007 BMW 328xi wagon
STi Version 5/6 struts, purchased new (for $240/set, which is what they cost before Subaru jacked up the price) in 2001, installed October of that year with matching STi springs.
Currently have about 85K miles on the suspension (124.5K on the car), and they've clunked since the very beginning. Primarily the right rear, though the left rear does it occasionally too.
Some people lately have said to try a white lithium grease to lube the strut shaft. It's temporary, and the problem returns, but this at least narrows it down more "officially."
=S2=
Siper2 is offline   Reply With Quote
Old 09-28-2005, 12:27 PM   #14
JIM THEO
Member#: 29715
2004 WRX
WR blue
Sorry my mistake I also use lithium grease in the rears! ops:
Old 09-28-2005, 12:54 PM   #15
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
Version 7 STi RA springs, struts, tophats.
Zero issues.
Valhakar is offline   Reply With Quote
Old 09-28-2005, 02:41 PM   #16
kuks
Member#: 39753
07 OBP WRX
03 Sonic Yellow WRX
sti v8 spec takeoffs on an 03 wrx. After about 6 months I began hearing the dreaded right rear clunk... I jacked up the back end and re-greased the strut --good as new!! No clunk any more
kuks is offline   Reply With Quote
Old 09-28-2005, 02:57 PM   #17
DChan
Gone... But not forgotten
Member#: 60342
2004 STi
No issues here.
DChan is offline   Reply With Quote
Old 09-28-2005, 03:40 PM   #18
Focus4
Member#: 20107
2004 STi
no issues here w/ JDM pinks...
Focus4 is offline   Reply With Quote
Old 09-28-2005, 04:10 PM   #19
boxered
Member#: 61884
Nary a peep with 25ishK.
boxered is offline   Reply With Quote
Old 09-28-2005, 05:36 PM   #20
Rdrcr
Member#: 83166
2005 WRX STi
Aspen White / Gold
No issues with my usdm struts, vehicle purchased 3-05
Mike
Rdrcr is offline   Reply With Quote
Old 09-29-2005, 08:46 PM   #21
poison
Member#: 37678
bump1
Old 09-30-2005, 12:56 AM   #22
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Myles' had 48k on his when he took his off and they were fine. The guy that bought his still has them and no clunking.
J
RaceComp Engineering is offline   Reply With Quote
Old 09-30-2005, 12:58 AM   #23
Obsidian
Member#: 5627
06 WRX STi
Car purchased 8-03. Had NO issues till about 3-4 months ago then the fronts began clunking. Slight at first, but has only gotten worse. Is now at the point it clunk almost every turn at a speed >25mph. Car currently has ~31k miles on it.
Obsidian is offline   Reply With Quote
Old 09-30-2005, 03:56 PM   #24
GTWORX.com
Member#: 97303
2009 WRX and Boxster
Gray and Black
GTWORX.com is offline   Reply With Quote
Old 09-30-2005, 05:56 PM   #25
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
25,000mi or so, v7 take offs, zero problems
jblaine is offline   Reply With Quote
How many dents do you '02 owners have? travisatlarge Car Care & Detailing 48 02-27-2009 02:29 PM
STi V7 RA takeoff owner reviews Jeff_DML Brakes, Steering & Suspension 0 03-26-2004 02:42 PM
How many here are previous DSM owners? joostin420 General Forum Archive 27 01-21-2001 12:24 AM
