Old 09-27-2005, 09:30 PM   #1
BoardRider
Member#: 32059
1997 Legacy GT sedan
CBR600, WR400, Z50R
Default WTB: Springs for My 97 Leg GT - Just Bought Some KYB-GR-2's!
Before I go on-line and buy a new set I thought I would look in the good ol Legacy forum. Does anyone have some springs they want to sell? Preferably close to Seattle so shipping would be minimal.
I'm not an aoutocrosser. I just like to do a little spirited driving here and there, and I take a road trip here and there (so I don't want it to be too stiff). I heard that it's bad to drop my Legacy on GR-2's so I don't want anything too low. T or F? But I wouldn't mind a little drop for aesthetics! As long as it doesn't compromise my snow driving (to get me up the mountain to snowboard)!
Enough restictions? Let me know if you have anything to sell! Thanks!
BoardRider is offline   Reply With Quote
Old 09-27-2005, 09:47 PM   #2
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
97 LegacyGT Wagon 4EAT
Sounds exactly like the springs I would want when I get some KYB GR-2's also If anyone can also suggest make/model of springs like this that would be awesome!
Good luck with your WTB
GTWagon_Phreak is offline   Reply With Quote
Old 09-27-2005, 09:57 PM   #3
Perdue
Member#: 57431
98 Legacy GT
04 Dakota QC 4x4
I'm dropped on H&Rs and GR2s and haven't noticed any ill effects, but then the springs are stiff as all hell. I've never heard of dropping a car on GR2s being bad, but they aren't as nice as the AGXs, which can be adjusted.
For your info:
Eibach Prokit: -1.2" front, -1.2" rear; H&R Sport: -1.5" front, -1.0" rear; Progress Technologies: -1.5 front, -1.5" rear. All numbers approximate. I'm pretty sure that the Progress springs are closest to the stock spring rate, giving a much smoother ride. Eibach is somewhat stiffer, and as I said above, H&Rs are stiff as all hell, which can make a long drive sort of rough on a guy. Someone correct me on this stuff if I'm wrong.
Perdue is offline   Reply With Quote
Old 09-27-2005, 11:02 PM   #4
snowone
Member#: 6035
05 92-X Saabaru
98 Legacy GT Wagon
Legacy
I would recommend (and am currently using) Whiteline CONTROL springs (flatout are LOW, if you want that). You'll find little if any noticeable drop when first installed w/ GR2's, but it firms things up great. Consider gettin the STi top mounts for this combo, you'll be happy. It will settle to approx .5-1" lowering. I believe these are still some of the cheapest springs for our application too...
http://pdm-racing.com/products/subaru_corner.html
*I live in the snow/mountains during the winter, and am very happy with this setup maintaining reasonable clearance-clarence w/ improved handling.
Hope that helps.
Sorry no snow pics w/ this setup yet....
snowone is offline   Reply With Quote
Old 09-27-2005, 11:13 PM   #5
Bakergtt
Member#: 59207
'05 X was 98 LGTT
couldnt he go with sti springs with right equipment?
Bakergtt is offline   Reply With Quote
Old 09-27-2005, 11:16 PM   #6
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
What do STI Top Mounts do? I assume these are the top mounts for the struts?
Old 09-28-2005, 10:41 AM   #7
gtwagon941
Member#: 16874
2008 Audi RS 4
01 Subaru LGT Sedan
Yep, they are for the struts. They are made of stiffer rubber and therefore more precise then the factory ones, so I understand it. they will however make things a bit nosier and rougher. I decided not to get them as they are kinda pricy, but...
Jared
gtwagon941 is offline   Reply With Quote
Old 09-28-2005, 11:47 AM   #8
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Interestingly on the STi mounts, if you want to save some money just get the fronts as on the rear mounts only the struts bear on the rubber.
ss
subysouth is offline   Reply With Quote
Old 09-28-2005, 11:49 AM   #9
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Hope that helps.
snow, are you getting any rubbing on the rear fender lips? Rolled? Removed fender liner? That looks close.
ss
Old 09-28-2005, 12:12 PM   #10
BoardRider
Member#: 32059
CBR600, WR400, Z50R
Are many springs interchangeable with other Subaru models. I did some searching and couldn't find much about it. I know someone who's selling Whiteline Control springs for a 93-01 Impreza. Would those fit on my 97 GT sedan? I know the part numbers are different for the Impreza, but is that just marketing...?
Old 09-28-2005, 12:26 PM   #11
snowone
Member#: 6035
05 92-X Saabaru
98 Legacy GT Wagon
South... the tires are 225's and are a bit wide... bought them used w the wheels from a wrx kid. Only major rub I've had is in the front on hard down hill corners, actually caught the fender lip and bent it out a bit. Haven't noticed rub in the rear, but then again I don't load the fat chicks up in the back seat very often.
215's won't rub at all. I think the perspective in that pic makes it look closer than it really is.
'rider: use leg spec part numbers, the impreza springs are not correct. not just marketing. STi top mounts aren't neccessary for the needs/wants you described.... they do creat a bit of noise, but nothing too dramatic.
*if you want to check out this setup, hit me via pm/email and we could hook up in seattle or eastside.
Old 09-28-2005, 03:11 PM   #12
BoardRider
Member#: 32059
CBR600, WR400, Z50R
Thanks snowone! PM'd you.
I'll stick with the Legacy PN's. There's another guy sellign 02 WRX stock springs (3000mile) for cheap! But if they won't work, and it looks like no one else around here has any springs to sell, I'll buy some new ones. I think I am going to buy the Whiteline Controls. P/N's for these springs for a 6/1994 - 2/1999 BD sedan are 70198-Front & 70381-Rear, for those interested.
Old 09-28-2005, 05:39 PM   #13
BoardRider
Member#: 32059
CBR600, WR400, Z50R
Boxer4Racing, GlobalPerformance, adn PDMRacing.com all have the springs on backorder! Whiteline is in Australia and it takes many weeks to get an order in... Does anyone know of any other distributors that may have these springs. Look like i may not be able to install my new suspension for several weeks!
Old 09-29-2005, 07:21 PM   #14
BoardRider
Member#: 32059
CBR600, WR400, Z50R
Question
OK, now I'm pretty confused. I just ordered the springs (Whiteline Control) from Boxer4Racing and at the end, he told me that if they happened to be out of stock by the time he completed the order, he would ship me the springs for the WRX... . . .He said that the 2002-2004 WRX springs are interchangeable with the 97 Legacy GT. That doesn't sound right.
Can anyone verify or dispute this?
If 2002 WRX springs will fit then I will buy some used '02 WRX stock springs (3000mile) that I saw for cheap!
Old 09-29-2005, 07:24 PM   #15
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
Yes, I'd like to know this also!
Old 09-29-2005, 07:47 PM   #16
gtwagon941
Member#: 16874
2008 Audi RS 4
01 Subaru LGT Sedan
I'd call them back and tell them you ONLY want the Legacy springs. Your car is a different weight than the WRX, not to mention that I am pretty sure the spring perches are an issue as well.
Subysouth will no doubt clarify this issue. But I'm 98% sure that you don't want WRX springs with Legacy struts, or even at all.
Jared
Old 09-29-2005, 10:00 PM   #17
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
dude, theres eibach pro-kits on ebay all the time for under $200, like $230 shipped.
Old 09-29-2005, 10:22 PM   #18
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
Got a link? Thx
Old 09-30-2005, 11:44 AM   #19
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
I can dispute that in several ways.
Firstly, WL control spring part numbers.
95-99 Legacy sedan
F - 70198
R - 70381
02-03 WRX sedan
F - 80066
R - 83158
Further there are NO PN interchanges between ANY Legacy and ANY Impreza in the WL spring catalog.
Secondly I can dispute that based on personal experience, of a related sort anyway. The Ver7 STi suspension I purchased had incompatible rear spring perches with my oem rear springs(didnt try the fronts) diameterwise. Since you can put STi spring on stock WRX struts, that would suggest Legacy springs are also incompatible with WRX rear springs diameterwise.
A lot of this misinformation I think stems from the fact that entire GD/GG suspension assemblies can be directly bolted into the BD/BG Legacys with varied results and the BD/BGs and 02-03 GD/GGs use the same f&r topmounts. You cant however interchange parts very easily because bottom spring diameter, spring perch height, etc can be different. I wasnt pleased at all with the height I netted from both a Ver7 and 8 sedan suspension on my wagon. Too much drop even though weights are similar. The Legacy springs use a ton more spring preload(are longer) to counteract the Legacys weight.
CN: If you are paying for new springs, you should be getting the exact springs designed for your car, not a relative.
ss
Old 10-03-2005, 12:42 PM   #20
BoardRider
Member#: 32059
CBR600, WR400, Z50R
Default Status Report...
OK, I called Boxer4Racing on Friday but they were closed for some Subaru event. So I sent an email and told them I only wanted Legacy springs, NOT WRX P/N's (keep in mind that I already ordered the Whiteline Control springs).
This was their reply I received this morning:
The springs for the front we sent are the Legacy 93-1999 the only WRX springs were the 'Rear' which we have confirmed fit the Legacy 95-99 and the weight in the rear is the same since both are close to the same curb weight in the rear. The Group N top hat for the 'Rear' of the 95-1999 Legacy comes from the 2002-2003 WRX which again we know fits with no issue since we have done it here in the shop.
We raced a 98 Legacy GT sedan for close to two years that is why we know for a fact these parts are interchangeable. The 95-1999 Legacy is closer to a 2002-2003 WRX than any Impreza model from 93-2001.
Front #70198 (Legacy 94-1999)
Rear #83158 (WRX 2002-2003)
What do you think? Should I protest...? Or should I just use them, since it takes about 6-10 weeks to order new ones from Whiteline (Australia), and no one in the U.S. seems to have them? It seems like they know what they are talking about, but it's different from what I have heard/read in here...
Old 10-03-2005, 11:42 PM   #21
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
The topmounts are interchangeable correct. Its the rear spring lower diameter that is off. Now in this case the rear spring diameter will be smaller than you need so it might work(the reverse definitely doesnt work.) The weight issue is also an issue of spring preload as well as outright weight of the vehicles. The only way that works is if there is identical rear spring perch heights and spring pre-load, which anecdotal evidence(of people swapping WRX complete units to BD/BGs) would suggest this is incorrect. My experince has been the GD/GG STi rear springs perches are off about 3/4" from the Legacys and the spring pre-load is WAY off.
Again, I would want the springs that are intended for my car. But if they are willing to pay for shipping both ways and take them back if they dont work correctly, no harm in trying.
ss
Old 10-04-2005, 04:03 AM   #22
spdracr00
Member#: 65823
1996 Impreza L
Red
http://cgi.ebay.com/ebaymotors/EIBAC...spagenameZWDVW
there ya go... cheap and good springs..
spdracr00 is offline   Reply With Quote
Old 10-04-2005, 04:04 AM   #23
spdracr00
Member#: 65823
1996 Impreza L
Red
I wish now that i hadnt gone with my WRX suspension swap and stuck with legacy stuff, but i couldnt find much info and i wanted it done on the cheap. of course now i'm shelling out $250 for a set of GR-2's and another $250 for LEgacy Springs. so my $200 lowering kit is gonna cost me $500 to get it right.
Old 10-04-2005, 07:38 AM   #24
xcntrk75
Member#: 60224
2008 FXT Sports 2.5
Dark Grey Metallic
ss
They'll fit... I run a WRX spring on the rear of my Legacy. I would be concerned with the weight/pre-load as SS pointed out. Their differen't part numbers for a reason...
Good choice on the WL control springs... I love mine... should have gone with better struts though...
xcntrk75 is offline   Reply With Quote
Old 10-06-2005, 01:47 PM   #25
BoardRider
Member#: 32059
CBR600, WR400, Z50R
Default Fyi
Here are the spring rates for the control springs I just got from Whiteline:
.................................P/N..........Spring Rate
94-99 Legacy Front......70198.........175lbs/in
94-99 Legacy Rear.......70381.........105 > 180lbs/in
00-02 WRX Rear...........83158.........106 > 177lbs/in
">" means a spring rate range in a progressive spring design.
A single number denotes a linear spring design.
just bought some kyb agx, good price? SilvSuby Brakes, Steering & Suspension 9 05-15-2006 09:02 AM
Wagon: Just Installed Swift/KYB GR-2's! NW OBS Brakes, Steering & Suspension 0 04-14-2006 12:12 AM
WTB: Whiteline Control Springs for my 97 Legacy GT Sedan BoardRider Private 'Wanted' Classifieds 0 09-28-2005 04:17 PM
Bad gas mileage on my 97 Leg. GT Why? georgiamiata Normally Aspirated Powertrain 5 07-01-2002 09:53 PM
Are there really any safe intakes for my 97 Legacy GT? gimpless Normally Aspirated Powertrain 4 01-18-2002 11:56 PM
Message Board Statistics All times are GMT -4. The time now is 04:12 PM.
