Old 09-27-2005, 09:44 PM   #1
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
Default Missing an alignment dowel, problem?
I noticed after I got my motor all put together except for the rocker covers that one of the little alignment dowels from under the cam cap fell off. I don't really see how this could be a problem since everything is obviously lined up fine if it's bolted together, the only thing I'm worried about is where do those holes go, would there be any problems with a little oil seeping in? Is it just a hole that goes nowhere that they stick an alignment pin in?
jasona is offline   Reply With Quote
Old 09-27-2005, 10:55 PM   #2
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
My recommendation to go ahead and get a new dowel pin for it. The cam rides on machined surfaces that are made to tight clearances. For the price that the dowel is, probably less then a buck it would be the smart and safe thing to do for the price of the part. The dowel makes sure that the cap seats in the same exact place every time and when you torque the cap bolts down. As for the oil leaking into the holes, you should have some RTV to seal the cap onto the head so that should be a problem.
Burnout is offline   Reply With Quote
Old 09-28-2005, 12:21 AM   #3
jasona
Member#: 11786
2014 OB 2.5i 6MT
I still have the dowel, it's just the engine is already completely reassembled, I don't want to take it all apart to put the dowel back in if I don't have to. If all my bolts are already in and torqued, then it's lined up already even without the dowel. So is there really any reason I NEED to put the dowel back in, or should I just save it and put it back next time I take the motor apart (if there is a next time)?
Old 09-28-2005, 10:59 PM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
See how she does. Hopefully it won't shift. If it does though, I wonder how much if any damage will occur. There are 18 bolts holding it in place. Best of luck.
Tim Sanderson is offline   Reply With Quote
Old 09-29-2005, 08:32 AM   #5
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
If it shifts you could probably get oil leaking from the cam seal and the rear cap. Irregular ware on the lobes and maybe even on the valve's tops them self.
Old 01-20-2015, 05:02 PM   #6
Keleios
Member#: 187581
Resurrecting this truly ancient thread to try and figure out what the part number is for this "Cam Cap Dowel Pin"!
It's 8.5mm in diameter and 12mm long and it isn't in any of the diagrams on parts.subaru.com.
I caught this before assembly, I think it got lost at the machine shop, but I might have lost it before I gave it to them. I'd rather not pull a head from a junkyard to get a new ~$2 pin.
Also, anyone reading this thread in the future, you need the pin. The bolts are too loose a fit to work for alignment and the two halves will likely end up pinching the cam and screwing up oil flow.
Keleios is offline   Reply With Quote
in for an alignment and out needing an engine. Meridius Mid Atlantic Impreza Club -- MAIC 51 06-17-2010 12:40 PM
Just missed a gear....big problem? Or no? lavid2002 Newbies & FAQs 16 03-29-2010 10:16 PM
Never have I missed an Episode of 24.... JMP73 Off-Topic 9 05-05-2004 11:32 AM
California's missing an autobahn..... nottheliving Southern California Impreza Club Forum -- SCIC 53 03-16-2004 02:28 PM
A good price for an install of eibach pro-kit and an alignment 1yellow03 Brakes, Steering & Suspension 6 05-29-2003 04:37 AM
