Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Old 09-27-2005, 10:24 PM   #1
BrandonWRX
Member#: 42177
2005 STi
Default A way to set boost gauge to 0?
I got a mechancial boost gauge but it came in the mail set at -10 inHG (vacuum) instead of 0 or near 0. Is there a way to adjust it so it rests on 0? I couldnt open up the damn thing without feeling like it would break, I tried to open it on the rim part. Keep in mind its mechanical, since electrical boost gauges set themselves. I read that once its off 0 youre pretty much screwed correct?
BrandonWRX is offline   Reply With Quote
Old 09-27-2005, 10:42 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you bought it new just send it back and get another one. If it's used it may be possible to open it up and mess with it but usually they aren't off by that much. Sorry to say but this one is probably not useable.
Old 09-28-2005, 12:12 AM   #3
ice_bomb
Member#: 37972
2003 Impreza WRX
My HKS boost gauge always at -0.5 when the engine runs. is this normal?
brandon, I didnt mean to hijack your thread, but I kind of in a similar situation.
ice_bomb is offline   Reply With Quote
Old 09-28-2005, 12:22 AM   #4
Hunt3r
Member#: 95484
I've been wondering about the same thing with my boost gauge. It reads up to 2.0 bars (kg/cm^2) straight to the right and 0 straight to the left but it never rests on 0. Instead when not on boost it goes down below the 0 mark and has a few lines marked with a mmHg measurement. I'm guessing that's just a smaller measurement since there is still some air flowing thru the turbo when the engine is running. Maybe your gauge is like that too?
Hunt3r is offline   Reply With Quote
Old 09-28-2005, 12:41 AM   #5
ice_bomb
Member#: 37972
2003 Impreza WRX
Mine is measured in Kpa. Usually it reads -0.5 Kpa when idle. I dunno if this is normal. I bought the car used, it reads like that when I got it.
Any idea?
Old 09-28-2005, 10:38 AM   #6
JimBlake
Member#: 82247
2005 Saab 9.2x Aero
satin grey
Idling, it should have a good vacuum. 0.5 kPa is only about 0.07 psi, so that's pretty close to zero. Are you sure you're reading the scale correctly?
JimBlake is offline   Reply With Quote
Old 09-28-2005, 11:20 AM   #7
REX8
Member#: 24038
Oh man guys....your engine draws air IN while running. You should see negative pressure on the guage while at a standstill. This is normal.
But yeah, in the box, I don't believe it should be reading a negative pressure. Unless the package was sealed...
Old 09-28-2005, 05:08 PM   #8
ice_bomb
Member#: 37972
2003 Impreza WRX
What box?? what package is sealed?
I haven't checked my air filter for a while. I dont think it's related to boost gauge. am i correct?
Old 09-28-2005, 05:34 PM   #9
JimBlake
Member#: 82247
2005 Saab 9.2x Aero
satin grey
I think REX8 was answering Brandon's original question. Sounds like HIS guage was reading 10" of vacuum before he even installed it. Mulder already answered that one; if Brandon just bought it, send it back cause it's defective.
Old 09-28-2005, 05:41 PM   #10
REX8
Member#: 24038
Yup, I was talking about his BG. If the package was vacuum sealed, you could possibly see it reading a negative pressure while still in the package...
Old 09-28-2005, 06:27 PM   #11
BrandonWRX
Member#: 42177
2005 STi
Haha yes it was -10 inHg int he box. I have made arrangements to return it. However I might have a better solution (quicker). I did the insurance thing for 2 extra bucks, is there a way to get my money back from USPS?
And as for the other "hijacks" no problem. Your gauges are normal, they should be reading a vacuum of about -.05 to -0.06 when the car is idling, and even more negative when you are decelerating. The negative manifold pressure is normal in all cars, its the basis of the vacuum system. When its + then theres the fun
AP boost gauge to check for boost creep? sperry7 AccessPort 3 07-24-2006 05:20 PM
any recomadations on what setting to set boost robert trabulsi Engine Management & Tuning 0 01-07-2005 07:24 PM
3-way joint for boost gauge Jeff_DML Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-17-2003 08:00 PM
Setting boost controller at 0 psi biggreen96 Normally Aspirated with bolt-on Forced Induction Powertrain 15 09-14-2002 07:46 PM
Where to mount boost gauge?? cincyRS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-29-2001 07:17 PM
