Welcome to the North American Subaru Impreza Owners Club Friday July 3, 2015
Old 09-27-2005, 10:44 PM   #1
DeKaP
Member#: 90627
2005 Impreza WRX
Obsidian Black Pearl
Default headlight problems
i went to change my bulbs again.......but i didnt like em so i decided to change em back, but the thing was, now the bulbs dont work so i tried to use the new ones i bought and they didnt work either, the stock ones didnt work either, could i have messed up the wiring for the low beams? how do i check....the high beams and fogs still work fine, could it be the bulbs could only be used once? i just dont understand how it works one second and not the next, and now i dont have low beams =/.
DeKaP is offline   Reply With Quote
Old 09-27-2005, 10:46 PM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
what bulbs did you have in there? wattage?
Old 09-27-2005, 10:47 PM   #3
DeKaP
Member#: 90627
2005 Impreza WRX
h1 sylvania silverstars
Old 09-27-2005, 11:21 PM   #4
DeKaP
Member#: 90627
2005 Impreza WRX
i just checked the fuses and nothings wrong with them
Old 09-28-2005, 01:14 AM   #5
markadopolus
Member#: 69586
Silverstars are junk. Return them right now.
markadopolus is offline   Reply With Quote
Old 09-28-2005, 04:45 AM   #6
GravelRash
Member#: 16318
2002 WRX Franknwagen
Grime over Sedona Red
Got a multi-meter? If not, get one; try Sears for a variety of types and prices...
1 - Check the bulbs for continuity.
2 - Unplug the low beam sockets. Turn on the headlights: check across the terminals in each socket for 12V.
If #2 shows no voltage, then how did you check the fuses? Sometimes they fail but it can't be detected visually. Use the meter to check for continuity across the fuse, just like the bulbs.
GravelRash is offline   Reply With Quote
Old 09-28-2005, 06:17 PM   #7
DeKaP
Member#: 90627
2005 Impreza WRX
i got it, when i took the bulbs out it musta burnt out or something cause i just bought new ones put em in and works fine....thanks for the help though
Old 09-28-2005, 07:43 PM   #8
wayfastwhitey
Member#: 96577
2002 Subaru WRX
World Rally Blue
PM Billy C he had to rewire his headlights. He was having a problem but after rewiring it has worked since.
wayfastwhitey is offline   Reply With Quote
Old 09-28-2005, 07:44 PM   #9
wayfastwhitey
Member#: 96577
2002 Subaru WRX
World Rally Blue
did you touch the bulbs with your fingers?
Old 09-28-2005, 07:45 PM   #10
wayfastwhitey
Member#: 96577
2002 Subaru WRX
World Rally Blue
that will popem....... i know from experience
Headlight problem! ButTMaN! Interior & Exterior Modification 8 12-07-2002 03:55 AM
WRX Headlight problem ybnormal70 Newbies & FAQs 2 11-02-2001 04:14 PM
Headlight problem Silky Interior & Exterior Modification 5 10-28-2001 11:59 AM
('93-'01) Headlight Problem... MP2.5RS Impreza Forum 2 08-17-2001 01:55 AM
01 Headlight Problem Mr Cheese Forester Forum 4 03-29-2001 01:45 PM
