Welcome to the North American Subaru Impreza Owners Club Thursday March 5, 2015
Old 09-28-2005, 10:17 AM   #1
subee13
Member#: 96007
2006 Impreza 2.5i
Steel Grey Metallic
Default 06 Intake
OK i searched for this but could not find it. Is the MY05 intake the same for the myo6. i have an 06 impreza 2.5i and i was wondering if the new injen CAI will work on my 06? Thank you in advance. I want to pick that intake up soon but i hav not heard of anyone with it on the 06 yet.
subee13 is offline   Reply With Quote
Old 09-28-2005, 01:39 PM   #2
subee13
Member#: 96007
2006 Impreza 2.5i
Steel Grey Metallic
anyone? help?
Old 09-28-2005, 05:09 PM   #3
NJ 2.5RS
Member#: 85606
2002 2.5 RS
Blue Ridge Pearl
I dont think anyone has come out with one yet. The 06s are way to new to get anything worth while.
NJ 2.5RS is offline   Reply With Quote
Old 09-28-2005, 07:59 PM   #4
subee13
Member#: 96007
2006 Impreza 2.5i
Steel Grey Metallic
i know the engine got variable valve timing but i thought the intake might work. Anyone know for definate?
Old 09-28-2005, 08:45 PM   #5
LaGuaGua
Member#: 97021
NO it won't help. Injens intakes are calibrated to the mass air flow. The 06 is an entire different set set up than the 05.
LaGuaGua is offline   Reply With Quote
Old 09-28-2005, 09:08 PM   #6
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
judgin just by look at a pic of the new 06 motor it looks like it has the 05 INtake manifold and MAF setup SO I am pretty damn sure the 05 INJEN will fit the 06 motor but performance wise i don't really know what it would do but im guessin it'll make significant gains as well.
Caplin 2.5 is offline   Reply With Quote
Old 09-29-2005, 04:00 AM   #7
mamiyarz67
Member#: 55940
05 LGT 5SPD WGN
Royal Blue Pearl
wow - thats changed a lot since my 02 lol
course mine just has a HUGE 3" hole in the side of my airbox lol, i like the CAI but it just sounds nicer now Flow > cold
mamiyarz67 is offline   Reply With Quote
Old 09-29-2005, 07:55 AM   #8
subee13
Member#: 96007
2006 Impreza 2.5i
Steel Grey Metallic
Kaplan thanks a lot. I believe in 05 they went to MAF pver MAP. I was unaware of how the 05 engine looked. I assume they are the same. I currently have an e-mail into injen. I woudl assume the gains would be better on the 06 than the 05 due to the variable valve timing. The 06 was mad eto have torque thorughout the wide range of revs. Once i confirm i will get one and let you guys know how it is on the 06. I believe any intake will do wonders for our NA scoobys as the stock airbox IMO is restrictive. I want straight thorugh air.
but in the meantime if anyone knows for sure they can chime in.
Thanks in advance
-Matt
Old 09-29-2005, 11:39 AM   #9
Caplin 2.5
Member#: 71203
2005 2.5rs
^^ seriously anything is better than the restrictive stock one. I think it should yeild gains the same if not less but the 05CAI was designed on my car and my car doesn't have I-active valve lift system. So I'm a lil skeptical on what gains it'll put out but definately intrested. GOOD LUCK
Old 09-29-2005, 01:37 PM   #10
subee13
Member#: 96007
2006 Impreza 2.5i
Steel Grey Metallic
i assume you have one on your car? Can you tell the difference on the butt dyno low end, mid, low end torque? is it deep and loud at WOT? i am looking for a little gain in acceleration, better fuel economy, and the throaty sound. thanks in advance. But you are right soo damn restrictive. i don;t want to just take teh snorkel off either.
Old 09-29-2005, 06:19 PM   #11
Caplin 2.5
Member#: 71203
2005 2.5rs
You can like barely feel the extra horspower kick in at around 4600rpms and you can feel it pull you to redline quicker than stock. Stock felt like it would lag, and as for torque I was able to feel a little bit more of a beefy low end. As for sound if you use it as a CAI at WOT it sounds like a beast and at redline it is just rediculously loud. If you use it as a short ram it is just rediculously loud all around.
Old 09-29-2005, 09:58 PM   #12
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
What is the width of this Maf sensor? Does anyone have the voltage range of the sensor wire of the airflow sensor or can someone point me to a diagram with this info? Thanks!
Kevin Thomas is offline   Reply With Quote
Old 09-29-2005, 10:23 PM   #13
Boom05rs25
Member#: 95157
05 Impreza RS 2.5
OBP 5spd Winged
I cant say for sure,as i havent done it. I do have an 05 and the engine's air filter is the exact same as that one"probbly the same part#" anywayz Id bet a good chunk of money that it not only will fit but give better gains then on an 05. There isnt a whole lot of science to a CAI,but ill buy an 05 CAI and repackage it TO SAY 06 and charge ya 50 more bucks if you want ....thats all cobb,injen,etc. will do...BUT WE'LL SEE !!
Boom05rs25 is offline   Reply With Quote
Old 10-06-2005, 01:27 PM   #14
subee13
Member#: 96007
2006 Impreza 2.5i
Steel Grey Metallic
To the top!! Anyone know for sure?
Old 10-11-2005, 03:39 PM   #15
subee13
Member#: 96007
2006 Impreza 2.5i
Steel Grey Metallic
Just so you guys know its works with some modifications. I wasn;t about to spend 230 on an intake and not use it. I like it. Doesn't make the car super quick but it pulls harder and faster.
Old 10-11-2005, 04:02 PM   #16
vwown3d
Member#: 69991
Leh Keen
Approved
what type of modifications! nice job getting it to work!
vwown3d is offline   Reply With Quote
Old 10-11-2005, 05:57 PM   #17
subee13
Member#: 96007
2006 Impreza 2.5i
Steel Grey Metallic
If you look at the picture you will see a tube with a white connector on the front of the airbox connecting to the throttle body. The 05 injen intake has only connectors for the 2 side tubes. I went to home depot bought a 1/2" t-connector for 1.78 and 2 feet of tube from autozone for 1.19 a foot. I had hose connectors so now all 3 tubes are connected. I taped teh third tube because it has a sensor attached and i didn;t want it to come loose. So far so good and not throwing any CEL's. I love the intake so far. Sounds mean and pulls great up top.
-Matt
Old 10-12-2005, 12:08 PM   #18
dizizjake
Member#: 56879
2015 WRX STi LTD
CRYSTAL WHITE PEARL
www.injen.com
contact the RD dept.
dizizjake is offline   Reply With Quote
Old 10-12-2005, 01:02 PM   #19
FriedIceCream
Member#: 84154
2010 S&M WTF
Trans Purple
looks the same to me either than my radiator shield and catch can.
FriedIceCream is offline   Reply With Quote
Old 10-12-2005, 01:04 PM   #20
FriedIceCream
Member#: 84154
2010 S&M WTF
Trans Purple
wait the windshield fluid look like its under the fuse box now... any other noticable differences?
Old 10-12-2005, 02:21 PM   #21
subee13
Member#: 96007
2006 Impreza 2.5i
Steel Grey Metallic
Ok a few things...
#1 i contacted Injen a month ago almost. They have the longest turn around for Q&A.
#2 Its already on my car i had to mod it
#3 look at the pic of teh 05 and a pic of the engine bay up top. At the front fo teh air diffuser box there is another tube. the intakes are different. i assume that the extra tube and sensor is for the variable valve timing.
the intake rocks though.
-Matt
Old 10-13-2005, 09:16 AM   #22
FriedIceCream
Member#: 84154
2010 S&M WTF
Trans Purple
i think its just the pcv hose relocated
06 Intake manifold, ported TGVs, fuel rails, exhaust manifold 2006whitesti Engine/Power/Exhaust 15 08-20-2010 01:12 AM
06 Intake manifold on an 03??!!?? cueballsi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-19-2009 01:26 PM
WTB: 04-06 intake snorkel calib17a SCIC Private Classifieds 3 12-12-2006 11:42 PM
WTB: 04-06 intake snorkel calib17a Private 'Wanted' Classifieds 0 12-12-2006 06:31 PM
FS: 04-05-06 intake system WRX sti matdiot Private 'For Sale' Classifieds 0 03-04-2006 05:33 PM
