Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Old 09-28-2005, 12:50 PM   #1
sheikthin
Member#: 77592
* missdawn = MILF
now with 25% less pistons
Default EJ257 hybrid oil pump question
tried searching for this. if i'm doing an EJ257 shortblock swap with stock WRX heads, do i need to get an STI oil pump or does the stock WRX oil pump suffice. I'm kinda short on cash now so i need to reuse everything i can so if it will be enough, then i'm happy. at a later time i'll replace it with an STI pump when i get the V8 heads so it can better supply for a higher redline. Please tell me i can re-use the stocker!
sheikthin is offline   Reply With Quote
Old 09-28-2005, 02:16 PM   #2
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
If you are interested, I have a good used EJ257 pump. PM me.
S.
n2xlr8n is offline   Reply With Quote
Old 09-28-2005, 02:27 PM   #3
codered
Member#: 58033
2008 Forester Sports
Pure White
Pretty sure they are the same.
codered is offline   Reply With Quote
Old 09-28-2005, 04:03 PM   #4
Division By Zero
Member#: 7555
Even though I was told that the parts are different, I can not see any difference between them. I've evened opened both up including the valve section. I got a 2.5L pump though just in case I was wrong
Division By Zero is offline   Reply With Quote
Accusump and oil pump question apexslider Built Motor Discussion 5 09-24-2009 03:33 AM
????Uprated oil pump question???? Rallly2000 Built Motor Discussion 11 10-22-2008 02:47 AM
Oil Pump Question On A Jdm Sti Vi (ej207) jkjersey Built Motor Discussion 2 06-03-2006 04:40 PM
EJ25 oil pump question the desert fox Normally Aspirated Powertrain 3 06-10-2003 07:34 PM
race engine oil pump question PeterJ Motorsports 4 08-16-2002 11:57 PM
