Old 09-28-2005, 02:50 PM   #1
a2_power
Member#: 95078
Default How Do I Disable Daytime Running Lights?
Ok. Got a 2003 wrx, and every time I take off the damn parking brake, headlights turn on. This sucks.....how do i disable this?
thanks a lot
-Pat
a2_power is offline   Reply With Quote
Old 09-28-2005, 02:53 PM   #2
sevendhappy
Member#: 16283
Teh Car n00b!
G-Club represent!!!
Two plugs, one under the hood, and one under the glovebox. Do a search, and there should be pictures of what to look for exactly.
sevendhappy is offline   Reply With Quote
Old 09-28-2005, 03:08 PM   #3
a2_power
Member#: 95078
if someone could get me a link to that it would make my life a lot easier!
thanks!
**now beginning search**
Old 09-28-2005, 03:28 PM   #4
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Hank3 is offline   Reply With Quote
Old 09-28-2005, 04:17 PM   #5
a2_power
Member#: 95078
SO..... as far as i can see i just need to unplug the plug under the glovebox.
is this correct?
Old 09-28-2005, 04:22 PM   #6
Hank3
Member#: 16157
'03 Mazda P5 <><
Yes, you are correct.
Old 10-11-2005, 12:08 PM   #7
colombo140
Member#: 97790
2008 STi
Thumbs up
Thanks for finding those links to the 2 locations for the disconnects.
colombo140 is offline   Reply With Quote
Old 10-11-2005, 12:32 PM   #8
a2_power
Member#: 95078
it worked perfectly.......thanks a lot!
Old 10-12-2005, 07:08 AM   #9
file_id
Member#: 28197
2003 WRX w/ VF34
Seriously, instructions to disable DRL should be a sticky by now.
file_id is offline   Reply With Quote
Old 11-01-2005, 06:08 PM   #10
Scooby fan
Member#: 98399
'13 Legacy 3.6R
Twilight blue
Default Day time running lights
Hi...Just another "Lost soul" looking for answers I have a 2002 RS sedan and want to disable my DRL's....unfortunately the pictures in the various threads on the subject don't look anything like the wiring under my dash (Glovebox)....I have most of the panels off and there is nothing that looks even remotely like the pictures I have found in this thread.
HELP!!!
Has anyone actually performed this deed on an RS??
Scooby fan is offline   Reply With Quote
Old 11-01-2005, 06:16 PM   #11
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
HELP!!!
i have an 04RS and it is in the same spot. i dont see why it would be different....i have done this so many times i can do it without removing anything all you really need to remove to make it easier is the side panel on the door.
ATX25RS is offline   Reply With Quote
Old 11-01-2005, 06:18 PM   #12
ATX25RS
Member#: 4597
Old 11-01-2005, 06:18 PM   #13
Handsdown
Member#: 29355
i have an 03 RS and it's in the same spot.
WE NEED A STICKY
Handsdown is offline   Reply With Quote
Old 11-01-2005, 06:22 PM   #14
Scooby fan
Member#: 98399
'13 Legacy 3.6R
Twilight blue
OK....I'll have another look....that is the picture I have been using and I had the "Kick panel" off as well....it appears that the plug has 3 wire from it...Blk/Grn/Yellow....correct??
Old 11-01-2005, 06:23 PM   #15
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
I don't think it should, turning your DRLs off is a safety issue. DRLs make you more visible even in daylight. People are less likely to cut you off or pull out in front of you.
Personally I'm thinking of hooking my foglights up to the e-brake so they turn on whenever its down, as my RS does not have DRLs
Old 11-01-2005, 06:51 PM   #16
Scooby fan
Member#: 98399
'13 Legacy 3.6R
Twilight blue
Thanks for the help guys There is nothing that looks like that, in that location, on my car ....must be elsewhere. Cheers
Old 11-01-2005, 07:03 PM   #17
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It's a 10-wire plug, not a 3-wire. Did you remove the glovebox? That's the best way to find it.
Also, are you not in the US? Might have something to do with it.
Old 11-01-2005, 08:29 PM   #18
ATX25RS
Member#: 4597
can you post some pics of what you are looking at? preferably at the same angle of the one i posted above?
Old 11-02-2005, 01:29 AM   #19
Scooby fan
Member#: 98399
'13 Legacy 3.6R
Twilight blue
Mulder has the "CLUE"....I spoke to the service mgr at my dealer and he says that the "Canadian" cars are wired differently for some reason.....apparently the same relay but in a different place? The search goes on
Old 11-02-2005, 01:31 AM   #20
Scooby fan
Member#: 98399
'13 Legacy 3.6R
Twilight blue
If I get a minute tomorrow I will takes some pics....I assume that the pic you posted was with the glovebox and side panels removed??
Old 11-02-2005, 08:11 AM   #21
Hank3
Member#: 16157
'03 Mazda P5 <><
This is pretty weird. I don't think Scooby fan is overlooking the DRL plug since it is pretty easy to find. It must be located elsewhere then on the Canada models
Pic of the plug just with the glovebox taken off from the passenger side door area:
Old 11-02-2005, 12:10 PM   #22
bmorton
Member#: 43528
2004 Outback Sport
The pictures above match my 2004 OBS (in Canada) exactly. So as of 2004 anyway it was no different than in the US. Can't figure out why the Canadian 2002 would be different than in the US since the implementation of DRLs is exactly the same.
bmorton is offline   Reply With Quote
Old 11-02-2005, 12:46 PM   #23
Scooby fan
Member#: 98399
'13 Legacy 3.6R
Twilight blue
Hi guys....I found it It is where your picture shows it...except it appears to be about 3" higher up under the dash.......to get at it without removing the glovebox would take someone with fingers about the size of chopsticks and 6" long
After I disconnected it and put the glovebox back together, I couldn't even get a finger in there far enough to touch it. All in all, about 10 min. work and a couple of skinned knuckles
Thanks for your help
Old 11-02-2005, 01:05 PM   #24
SubieWahn
Member#: 38107
2003 WRX Wagon
Yeah - I couldn't even begin to reach mine without removing the "glovebox". It's really the "trim" piece on the side of the glovebox that covers it - the trim piece just happens to be all one piece of plastic with the glovebox assembly!
SubieWahn is offline   Reply With Quote
HOW TO: Disable Daytime Running Lights on '06 DECALFX Newbies & FAQs 311 05-31-2012 08:46 PM
How to disable Daytime Running Light in 2007 Impreza wlit Electrical & Lighting 3 04-01-2010 09:40 PM
Show me how to disable daytime running lights. sc00bywagon Electrical & Lighting 6 07-31-2005 08:37 PM
Disabling Daytime Running Lights on a 2000 Legacy GT? rao Legacy Forum 16 05-04-2001 12:35 AM
how to disable daytime running lights in WRX? christurismohk WRX Forum Archive 21 01-26-2001 09:03 AM
