Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 09-28-2005, 05:53 PM   #1
PR_WRX
Member#: 45943
2007 wrx
black
Default Help! 05 STI gauge cluster in 04 WRX
I bought an 05 STI gauge cluster for my 04 wrx. The only issue I'm having is the plug that goes on the left side that controls the fuel and temp gauge is different. I've already search and no one has the answer, everything is about the b28 pin but that's only for 02-03. Please help! Thanks!
PR_WRX is offline   Reply With Quote
Old 09-29-2005, 11:15 AM   #2
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
05's are not plug n play with any other year.
i would suggest selling the 05 cluster and just getting an 04
Old 09-29-2005, 12:01 PM   #3
vwown3d
Member#: 69991
Leh Keen Approved
'68 Volvo Amazon
would an 05 sti cluster fit in an 05 wrx?
vwown3d is offline   Reply With Quote
Old 09-30-2005, 01:38 PM   #4
o2sys
Member#: 43842
200? WRX STI
u didnt search enough, i had the same problem, and i posted a thread about it...look at the plug and the harness carefully, if u cut the ridges of the plug a certain way it will fit, u will have like two pins left over on the cluster but thats ok, it serves other purposes that the WRX doesnt have so it will all function correctly.
o2sys is offline   Reply With Quote
Old 09-30-2005, 01:45 PM   #5
aznguyjac
Member#: 87488
i wonder if the 05 sti cluster will fit plug n play in the 05RS as well.....
if so, i can put the cluster into my "wish list"
aznguyjac is offline   Reply With Quote
Old 09-30-2005, 01:48 PM   #6
o2sys
Member#: 43842
200? WRX STI
it does fit, just u need to slightly modify the fuel/temp plug and dont forget to cut the b28 wire
Old 09-30-2005, 04:01 PM   #7
Einherjar
Member#: 15582
2002 STi Wagon
Full STi swap
I know they fit, but I hear some people have problem with a buzzing, which I presume is the shift beep. Does the shift light & beep work if you put a 05 cluster into a 02 wrx? Thanks.
Einherjar is offline   Reply With Quote
Old 09-30-2005, 04:30 PM   #8
Okita Souji
Member#: 41097
2005 WRX
you don't need to cut any wires for the 04-05s. B28 is the cruise indicator light thats on the gauge cluster on the 04-05 models.
Okita Souji is offline   Reply With Quote
Old 09-30-2005, 04:42 PM   #9
o2sys
Member#: 43842
200? WRX STI
yea as soon as i plugged it in, the cluster started beeping, so i had to take the back part out and remove the buzzer, but the shift light works fine, and on the 05's the temp gauge will work also
Old 09-30-2005, 04:52 PM   #10
Okita Souji
Member#: 41097
2005 WRX
Weird, i've never had any issue with the buzzer. It seems like a hit or miss thing with people.
Old 10-01-2005, 06:49 PM   #11
vwown3d
Member#: 69991
Leh Keen Approved
'68 Volvo Amazon
04 wrx and 05 rs have the same plugs. u can cut the plug or just get an 04 sti cluster. im running an 04 sti cluster in my 05 rs.
Old 10-02-2005, 08:22 PM   #12
PR_WRX
Member#: 45943
2007 wrx
black
Thanks for all the good info guys. I know by looking at the plug I can make it fit by modifying it, just wanted to make sure the 2-3 extra pins are not for something important. Already took care of the beeping and like previously stated b28 is not an issue on the 04-05.
Old 10-02-2005, 08:24 PM   #13
o2sys
Member#: 43842
200? WRX STI
yea i learned that the B28 wasnt important for the 04-05, no wonder the cruise light wont come on when activated!!! lol, well all fixed now!
Old 12-19-2005, 07:52 PM   #14
nixgame22
Member#: 101219
any pics or info on removing the buzzer would help me tons!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! please and thank you.
nixgame22 is offline   Reply With Quote
Old 12-28-2006, 11:40 AM   #15
Chapel
Member#: 3496
1995 Roadmaster
Beige
also, has anyone had the blown fuse problem?
It blows the radio fuse when you plug it in
Chapel is offline   Reply With Quote
Old 09-24-2007, 04:49 PM   #16
siubaru
Member#: 85081
2004 wrx
aspen white
I have the same beeping problem, but removed the beeper and fine now but, also have the ABS light on and the brake light on. anyone else have the same problem or know how to fix this. I have an 06 sti cluster into a 04 wrx. thanks.
siubaru is offline   Reply With Quote
Old 09-25-2007, 01:17 AM   #17
GDBF
Member#: 108473
2006 WRX Blouch
340whp/363wtq
How did you fix the buzzing sound?? You need to cut two wires. Did you cut it? The ABS light, there isn't a good solution yet. I'm on the search right now. About your brake light, not sure why it's on because they shouldn't be on all the time.
GDBF is offline   Reply With Quote
Old 09-28-2007, 09:07 PM   #18
siubaru
Member#: 85081
2004 wrx
aspen white
I just removed the buzzer.
Old 12-20-2007, 03:42 PM   #19
shootinsoobie
Member#: 71170
04 JBP
All Murdered Out
why dont you just take out the bulbs?!?
shootinsoobie is offline   Reply With Quote
Old 12-21-2007, 09:53 AM   #20
Okita Souji
Member#: 41097
2005 WRX
ABS light is on because the ABS circuitry for both in the cluster and in the car was changed starting with the 05 model year. I have checked the wiring diagrams for both years and the redesign uses a reverse in the way the voltage reads when the light is on/off. I forget exactly what year has 12v on when the light is off vs. 12v on when the light is off. I'll go over my diagrams and report back later.
The change in the design causes the ABS light to work "backwards" if you don't use a cluster of the same years as your car.
Example: The ABS light usually works by coming on when you turn the key the the "on" position and then goes out after 2 seconds or so. If you use an 04 STi cluster in an 05 WRX, when the key is turned to the "on" position the light will initially be out and will come on after 2 seconds.
I have an 05 WRX and I used a USDM 04 STi cluster and have checked this firsthand. There is no way to make the light work correctly unless you use the following cluster configurations:
02-04MY RS/WRX --> Use 04MY STi cluster
05-07 RS/2.5i/WRX --> Use 05-07 STi cluster (must move certain pins to make the cruise lights, fuel indicator, and temp indicator function correctly).
If you are using a cluster not suited for you model year, the ABS system will still function normally. To get rid of the light I just put tape on the back of the cluster face.
As for the buzzing sound, I never had that problem and my shift alarm works normally. Not sure if this is the case with using JDM STi clusters.
Shootinscoobie: The 04+ STi cluster uses LEDs instead of bulbs.
NOTES: 05-07 STI CLUSTERS HAVE A DIFFERENT HARNESS PLUG ON THE LEFT SIDE COMPARED TO THE RS AND WRX MODELS. YOU WILL NEED TO MODIFY OR FIND A PLUG OUT OF AN STI IN ORDER TO PROPERLY WIRE UP THE CLUSTER.
USING AN 04 STI CLUSTER IN AN 05 RS/WRX WILL PLUG IN NO PROBLEM, BUT THE ABS LIGHT WILL NOT WORK RIGHT.
Old 05-08-2008, 04:28 PM   #21
singincanary
Will mod for Guinness
Member#: 77921
'02 Foz
'07 'beca, '08 OBXT
having the same problems with the abs light, and the e-brake light on my car. Haven't tried the cruise yet.
singincanary is offline   Reply With Quote
2004 STi Gauge Cluster in 04 WRX StealthfishWRX Interior & Exterior Modification 8 04-17-2009 01:08 PM
04-05 sti gauge cluster in bugeye? 98jdmlegacy Interior & Exterior Modification 7 02-12-2009 07:55 PM
WTT: 05 STI gauge cluster for 04 WRX cluster nixgame22 Interior/Dressup/Audio & Security 28 08-15-2007 03:49 AM
WTT: 05 STI gauge cluster, for 04 STI cluster Ctracer911 Interior/Dressup/Audio & Security 0 06-26-2007 01:26 AM
05 STI gauge cluster in 03 wrx, who can do it SICK03SONIK Southern California Impreza Club Forum -- SCIC 3 02-19-2007 08:47 PM
