Old 09-29-2005, 02:48 AM   #1
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
Default Morrett Ballasts Broken help!
one of my HID ballasts makes the light blink, and the other one simply doesnt work.
they are brand eaglite
here are all the numbers on the ballasts that dont make sense to me but might to someone else.
lamp type HID conversion kit 35w
INPUT 13.5VDC norm.
OUTPUT 35W @ 85V RPMS
LIFE >3000Hours
25K V
ok... the lights are morrette lights. since both th ballasts are obviously broken (ive tested them, and the bulbs are good,) what is the best route to go when buying new ones, for afforability and brightness?
jared nelson is offline   Reply With Quote
Old 09-30-2005, 12:28 AM   #2
2phless
Member#: 69343
1998 TransAm cnvrtbl
Tried opening them and making sure they aren't wet? I've seen them get wet, go nuts, then come back to life again when they are dried out.
(Don't open them with power on them...) (ouch)
2phless is offline   Reply With Quote
Old 09-30-2005, 01:16 AM   #3
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
i tried opening them, and they are basically filled with a sort of semi hardened rubber filler that fills the whole ballast. i was going to start kind of cutting through them, to get inside, but it wasnt going to work out. I figured Id just spare myself the frustration.
Old 09-30-2005, 10:36 AM   #4
Impreza2003
Member#: 67247
2003 2.5RS BRP
SQC 189
swap sides, put the "Faulty" ballast on the good side and see if its the wiring on that side of the car or the ballast.
You dont want to open it up because it can void your warranty.
Impreza2003 is offline   Reply With Quote
Old 09-30-2005, 11:18 AM   #5
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
i allready did that. ive tested both ballasts on the same side, different side same bulb both bulbs, im 100 percent sure that one ballast is bad, and the other one is causing the light to blink. which means that its probly also faulty.
Old 09-30-2005, 12:54 PM   #6
Vudoo7
Member#: 78887
2010 WRX Wagon
Dark Grey
ebay is a good place to buy ballast or u can try hidtech.com or hidplanet.com
Vudoo7 is offline   Reply With Quote
Old 09-30-2005, 01:04 PM   #7
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
thanks for your help, what do all the numbers on my ballasts mean? what do i have to specify in getting new ones?
Old 10-06-2005, 10:13 PM   #8
jared nelson
Member#: 35075
for Trade with U!
PM me to trade.
any more info? on like what my ballasts are and stuff.?.
Old 10-06-2005, 10:41 PM   #9
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Rallylights.com carries Hella Ballasts.
Strut Screw Broken - HELP orvtech Brakes, Steering & Suspension 11 08-19-2007 06:25 PM
Hard lines broken. Help! Rev1 Brakes, Steering & Suspension 28 04-26-2006 03:58 PM
2004 WRX Exhaust C.C. broken? HELP RuWRXcrazy2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 11-14-2005 07:08 PM
Somethings Broken....help? vica153 General Community 5 05-13-2005 01:18 AM
Factory Alarm Broken Help!! vapo Car Audio, Video & Security 4 09-14-2003 11:27 PM
