Old 09-29-2005, 08:39 PM   #1
alpinev12
Member#: 90186
2006 Impreza WRX Ltd
2011 Audi S4
Default Phillips HID conversion kit on '06 WRX
Anyone install one of these yet on an '06? Thinking about having it done. Would order it from xenondepot.com and have it installed by professionals. Comments/suggestions? Thanks in advance...
Rick B.
alpinev12 is online now   Reply With Quote
Old 09-29-2005, 09:21 PM   #2
minx1225
Member#: 89034
2015 WRX Limited
CWP
I have the NX's 8500k HID Kit on my car and they look NICE!.. I compared with stock 04 STI and Stock 03 Evo's ( Projectors ) HIDs and they look like cheap $50 Xenon wanna be lights.. My friend has the exact same HID as mine on his bug eye JDM Projector headlights and they look even better...
Some might say it's not worth getting the HID but IMO it is worth it...
I can see better at night time. I come from a car that sits low and had regular headlights , which was really hard to see at night time.. I had to check if the light was on sometimes.
Well , if you ever get one do a full search and people's comment on the HID you are getting. SOmetime they look cheap. Get 8500k
minx1225 is offline   Reply With Quote
Old 09-29-2005, 09:51 PM   #3
alpinev12
Member#: 90186
2011 Audi S4
I'm actually looking at 4300k cause they have the best light output. I favor brighter light over a bluer color. I just feel guilty cause the car is brand new and the projector lights on the '06 are quite good. For $379 + install I would hope that the phillips kit is worth it.
Rick B.
Old 09-29-2005, 11:06 PM   #4
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
If you do go with an HID aftermarket kit, getting one with Philips components is a good choice. I've had mine for almost two years now and they're still going strong. And good idea with going with 4300K - I see you've done your research. Kudos to you
Post some pics of the beam pattern against a wall if you do wind up getting them. I'd like to see the light output of an aftermarket HID kit in the WRX halogen projector setup.
Hank3 is offline   Reply With Quote
Old 09-30-2005, 03:33 AM   #5
AK*WRX*2004
Member#: 56485
2009 Ram 1500 CC SPT
R.I.P. Bro
I actually ordered mine on the 28th (phillips 4300k gen 4 slim ballasts). They're still in transit but I'll be sure to post up my impressions. -Gene
AK*WRX*2004 is offline   Reply With Quote
Old 09-30-2005, 07:08 AM   #6
Okita Souji
Member#: 41097
2005 WRX
AK*WRX*2004, where did you buy your kit from?
Okita Souji is offline   Reply With Quote
Old 09-30-2005, 11:16 AM   #7
Power_Getter
Member#: 45089
2008 DGM STI -R Spec
2010 BMW X5 ///M
Is the new wrx use H7 halogen projectors ??
Power_Getter is offline   Reply With Quote
Old 09-30-2005, 04:36 PM   #8
AK*WRX*2004
Member#: 56485
R.I.P. Bro
xenondepot.com
Old 09-30-2005, 04:42 PM   #9
Bayley
Member#: 49763
2004 WRX
Jetzt mit 25% mehr Motor!
...good man.
Also, don't forget that the cut off shield of the projector is what actually creats the "blue-ish" light that so many people are looking for. A properly setup 4300 bulb in a projector will actually have a bluer appearance than a 8000 degree bulb. Even better, the light output of the 4300 bulb will be a hundred times better.
Bayley is offline   Reply With Quote
Old 10-04-2005, 02:35 AM   #10
AK*WRX*2004
Member#: 56485
R.I.P. Bro
Exclamation
UPDATE:
Hey Guys,
I just installed my 4300K HID kit the other day. The bulbs that came with the kit fit into the stock holes (two H1 holes) fine BUT they make the bulbs are pointed WAY up. My stock high beams do NOTHING because the bulbs are aimed so high.
Problem. Just tonight I was driving and my passenger side HID started to flicker and my brake light and ABS light came on. They won't go away... I'm not sure if the kit fried my ballast or whatever but I'll have to go and check it out tomorrow.
Their customer service has been, OK so far. They've returned some of my e-mails but they havn't replied to two of them so hopefully they pull through tomorrow. I'll keep you guys updated on xenondepot.com but as of now, I'd recommend not buying things from them until my little problem clears out. -Gene
Old 10-04-2005, 04:00 AM   #11
Okita Souji
Member#: 41097
2005 WRX
Dang, sorry to hear about that. Hope you get that resolved soon.
Old 10-04-2005, 04:27 AM   #12
pignoseWRX
Member#: 93152
2006 Impreza WRX
SGM
that guy who recommended the 8000k bulbs has NO idea what he's talking about, but i'm sure you guys knew that if you're considering the phillips.
AK*WRX... i've heard people complain about their legacy gt's when using the h7 kit and that they've had to aim the headlights WAY down. are you using them in projectors or just in stock '04 housings?
yes
pignoseWRX is offline   Reply With Quote
Old 10-04-2005, 08:05 AM   #13
Hank3
Member#: 16157
'03 Mazda P5 <><
AK*WRX*2004 - did you disable your DRLs from behind the glovebox? If not, that could very well be the reason your HIDs are flickering.
Old 10-04-2005, 05:52 PM   #14
AK*WRX*2004
Member#: 56485
R.I.P. Bro
yes
I have the stock housing... I looked into the projectors but they would've cost me over $950 w/out shipping + there's about a week downtime...
Old 10-04-2005, 05:53 PM   #15
AK*WRX*2004
Member#: 56485
R.I.P. Bro
Yes I did. I had some HID's before these and disabled them long ago. -Gene
Old 10-04-2005, 07:52 PM   #16
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
Originally Posted by AK*WRX*2004
UPDATE:
Hey Guys,
pics? check ebay they have some ocari's on sale those are projector housings
ATX25RS is offline   Reply With Quote
Old 10-04-2005, 08:15 PM   #17
pignoseWRX
Member#: 93152
2006 Impreza WRX
SGM
yeeeeeeeeeeeeeeesh... DIY...
the DIY retrofit of 7-series projectors in to my old civic didn't cost anywhere near that much WITH another set of oem headlights. ebay + diy is the way to go on those.
Old 10-04-2005, 09:22 PM   #18
alpinev12
Member#: 90186
2011 Audi S4
**UPDATE**
Ordered my Philips 4300k H7 kit today from xenonking.com instead of xenondepot.com. The customer service at xenonking is far superior plus the kit was $5 cheaper ($374) and shipping was free. I have an appt. for installation on the 22nd. Can't wait.
Rick B.
Old 10-04-2005, 10:02 PM   #19
garie
Member#: 26607
2002 wrx wagon
^^ u can get the same mcculloch kit that xenonking has on ebay for 280 shipped.
thats where I got mine
garie is offline   Reply With Quote
Old 10-04-2005, 10:53 PM   #20
alpinev12
Member#: 90186
2011 Audi S4
I prefer the Philips unit for a $100 more just for piece of mind. Xenonking also sells the Mcculloch for around $280 shipped.
Rick B.
Old 10-05-2005, 01:26 PM   #21
RacEoHolic330
Member#: 91581
2013 WRX Limited 5dr
ISM
I'm looking into putting in a new set of HID projectors myself. does anyone happen to have pics of the stock 06 2.5i/WRX halogen projector. If not i'll just take the headlight apart myself when I have time to find out what it looks like.
The ideal thing to do would be to buy a set of OEM Hella ballasts and ignitors such as the ones found on audi's and bmw's. however, that requires the use of relays to avoid frying the stock harness when the bulbs are warming up., which can be a pain in the ass to wire in. So i'm probably just going to go with a philips kit cause they're designed for stock wiring. Then i'll find HID projectors on ebay that are the same design as the stock halogen projectors and go from there.
RacEoHolic330 is offline   Reply With Quote
Old 10-05-2005, 01:50 PM   #22
Hank3
Member#: 16157
'03 Mazda P5 <><
I haven't seen info on the '06s yet, but for the '02-'05 WRXs, the main DRL module is located behind the glovebox. Here are some pics of where it is:
http://forums.nasioc.com/forums/showthread.php?t=843079
*Edit - the '06 DRL unit is in the same location as the pics show in the above thread.
Here's a recent thread where an '06 STi owner disabled the DRL unit:
http://forums.nasioc.com/forums/show...light=2006+drl
Old 10-05-2005, 03:41 PM   #23
RacEoHolic330
Member#: 91581
ISM
thanks Hank. I found it.
Old 10-05-2005, 06:02 PM   #24
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
folks, for h7 projectors, why go with "kits" when you can get OEM equipment for nearly the same price and better availability.
rebased bulb kits usually arent made as well as oem.
h7 is a very popular bulb base for projectors. like the valeo proejctors, all you need is an h7->d2s adapter
then you can use any OEM bulbs, and ballasts.
BMW, SUBARU/Nissan etc... plus its much easier to get OEM d2s bulbs than aftermarket rebased bulbs.
a pair of d2s costs 75 dollars
BRAND NEW ballasts AND bulbs are 300 bux
d2s adapters are at most 15-20 dollars.
ask sean @
hidtech.com
hell, i'd drive up there and install it for you
psyber_0ptix is offline   Reply With Quote
Old 10-05-2005, 06:40 PM   #25
alpinev12
Member#: 90186
2011 Audi S4
ask sean @
hidtech.com
~Payam Fahr
Darn. I wish I knew about this a little while back and I did do a lot of research. Oh well...I'll try the Philips H7 kit and if there are any problems (crossing fingers) I will go the above route. Thanks buddy...
Rick B.
How to: Install HID Conversion kit into 2007 WRX AxlxA Electrical & Lighting 45 07-22-2016 12:29 PM
WTB bi xenon projectors and hid conversion kit for 02 wrx doopah Private 'Wanted' Classifieds 2 10-04-2009 02:33 AM
02 JDM STI Projector with Phillips HID conversion Kit vicdeng Exterior/Styling 21 07-22-2008 03:21 PM
HID conversion kit. 02-03 WRX danniel Private 'Wanted' Classifieds 1 11-08-2006 10:34 PM
HID retrofit kit on stock WRX headlights? Sideways Interior & Exterior Modification 2 10-10-2002 05:08 PM
