Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 09-30-2005, 10:27 AM   #1
03 RS
Member#: 81227
2012 Wrangler 4DR
Gecko Green
Default td04 on sohc 2.5
i know i need an exhaust manifold, up/down pipes, different intake, and intercooler to run this setup on my RS, what else does this entail, do i need a piggyback or just an AFR controller? please any help will be greatly appreciated as i have most parts waiting to go into the car
03 RS is offline   Reply With Quote
Old 09-30-2005, 10:58 AM   #2
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Coolant and oil Lines, RRFPR and some piggy backs to control fuel and timing. The TD04 has a Wastegate pressure of 8 PSI so your definitely going to need fuel and timing mods.
Ohh also your going to need a WRX crossmember
Old 09-30-2005, 12:45 PM   #3
2milehi
Member#: 81633
'98 RS-T
It never hurts to use the on this site and READ, READ, READ! The more you are informed, the better you will understand what you are getting into.
Also you will need a waterpump from a WRX. And from what I read and tried, the stock intake will work with the WRX intercooler, but it is TIGHT!
2milehi is offline   Reply With Quote
Old 09-30-2005, 08:20 PM   #4
darioc
Member#: 35695
02 RST
98 Outback 92 Wrangler
you dont need a wrx waterpump
darioc is offline   Reply With Quote
Old 09-30-2005, 08:41 PM   #5
kid22
Member#: 396
2000 2.5 RS-T
22WannaB
This is true
kid22 is offline   Reply With Quote
Old 10-01-2005, 01:08 AM   #6
erik04wrx
Member#: 88066
2004 wrx sedan java
black Cobb SII
what about that oil filter spacer line thingy (that is the SOA term for it)
erik04wrx is offline   Reply With Quote
Old 10-01-2005, 03:12 PM   #7
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
the water pump housing will be touching the wrx cross pipe idk if you want it to because that would raise the watertemp by alot. the pipe will fit but it will be making contact, any turbo waterpump will clear it by a few inches so it would probably be better.
Kawikid20o2 is offline   Reply With Quote
Old 10-08-2005, 11:04 AM   #8
2milehi
Member#: 81633
'98 RS-T
Unless you like to burn a hole in your lower radiator hose or plastic thermostat housing.
Old 10-08-2005, 09:11 PM   #9
Natoe
Member#: 90353
Sold '95 22T Impreza
'99 EJ205 L, AE86 GVR4
also, dont the turbo water pumps have 3 inlets/or outlets, while the non turbo has only 2??? my NA 1.8 had 2 i think, and my leg turbo has 3, i think.
Natoe is offline   Reply With Quote
Old 10-15-2005, 06:06 PM   #10
2milehi
Member#: 81633
'98 RS-T
There is only one outlet on a factory 2.5 engine. I used a 1/4" pipe tap to plug the other two smaller outlets. That was after I "pulled" the steel nipple from the pump.
Old 10-15-2005, 07:16 PM   #11
kid22
Member#: 396
2000 2.5 RS-T
22WannaB
any odds of posting a pic on that? that would help us RS-T'rs a lot!
Old 10-16-2005, 08:11 AM   #12
Assassin4457
Member#: 96773
04 WRX, RIP GC8
Will I also be needing this water pump and crossmember? im also planning to turbo my RS, but with the FAT Turbo Kit but i can't post a URL yet (completely gay rule im sorry)
What does the crossmember do? (sorry im a nub, what is it exactly, i have an idea but i need it to be clarified)
if u need the link plz pm me or feel free to email me.
Assassin4457 is offline   Reply With Quote
Old 10-16-2005, 12:16 PM   #13
El_Kameleon_G
Member#: 87103
2005 Impreza RS RWD
Plat'num Plus...SOLD!
Go to RS25.com
You don't need the crossmember or waterpump ONLY if you buy the up/down pipe fit for the RS. They bolt up to your stock header. I am working on a kit right now and all i need is the WRX turbo and oil/coolant lines. I really recommend you go to that site and look over everything that it has to offer. I can guarantee you will find almost anything you are looking for. Let me know if this helps.
El_Kameleon_G is offline   Reply With Quote
Old 10-16-2005, 01:16 PM   #14
2milehi
Member#: 81633
'98 RS-T
Sure can, but the water pump is installed so it won't be the best pic.
Old 10-17-2005, 04:13 PM   #15
2milehi
Member#: 81633
'98 RS-T
Here is the pic
Old 10-17-2005, 05:11 PM   #16
damonmlime
Member#: 54525
2000 ej20g rs
blue ridge pearl
I read that you cant use the wrx uppipe on sohc engine even with the wrx crossmember because the uppipe will run into the head, anyone else hear that?
damonmlime is offline   Reply With Quote
Old 08-06-2006, 10:58 PM   #17
96Imprezadent
Member#: 62556
1995 Fastest EJ18T
[email protected] Record Run.
i just installed a wrx manifold and erz uppipe on my 1.8....no fitment issues aside from the waterpump. damn that waterpump.
ack bringing it from the dead...what the hell.
96Imprezadent is offline   Reply With Quote
Old 08-07-2006, 11:59 AM   #18
fishheadback
Member#: 68120
1998 RS 2.0 vf23 STi
& MK6 GTI
I have a WRX intercooler, Exhaust mani, DP and bypass valve for sale
fishheadback is offline   Reply With Quote
SOHC 2.5 Heads on EJ22E renyo Normally Aspirated Powertrain 4 05-30-2009 11:22 PM
Compression testing specs on a 2.5 SOHC? FSRBIKER Normally Aspirated Powertrain 6 04-19-2006 02:23 PM
Will a DOHC f2.5 intake manifold bolt up SOHC 2.5 heads w chapman Normally Aspirated Powertrain 9 10-11-2005 10:24 PM
2000 2.2 to SOHC 2.5 obuerkle Subaru Conversions 3 05-20-2004 12:24 PM
Horsepower on stock 2.5 SOHC motor wcbjr Normally Aspirated with bolt-on Forced Induction Powertrain 4 01-09-2003 12:20 PM
