Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 09-30-2005, 03:44 PM   #1
916dave
Member#: 27896
2003 WRX Wagon
Default Mech vs. Elec Gauges
I'm contemplating getting some Omori boost/egt gauges. Is there any real difference between the mechanical vs. the electronic gauges?
916dave is offline   Reply With Quote
Old 09-30-2005, 04:03 PM   #2
waktasz
Member#: 86356
2015 s1000r
wheelie monster
For electrical gauges you probably have to buy an additional sending unit and it involves more wiring, but is probably more accurate.
waktasz is offline   Reply With Quote
Old 09-30-2005, 04:57 PM   #3
916dave
Member#: 27896
2003 WRX Wagon
mmm.... so for simplicity's sake, go with the mech? I mean, the mech gauge is still probably more accurate than the stock?
Old 09-30-2005, 04:59 PM   #4
ElBartoRex
Member#: 33899
2013 Focus ST
TB
I bought the omori electronics for better accuracy- they arent hard to hook up at all, not a big deal, you just have to splice a few other wires.
ElBartoRex is offline   Reply With Quote
Old 09-30-2005, 05:07 PM   #5
916dave
Member#: 27896
2003 WRX Wagon
Did you have to get an additional sending unit also? If so what does something like that cost?
Old 09-30-2005, 05:22 PM   #6
PhatheadWRX
Member#: 16899
they stay the same
age
If you already have the Subaru Boost, would there be any problem getting the Omori mechanical boost then just hooking it up to the hose/wires for the Suby one?
logic tells me no, just making sure
PhatheadWRX is offline   Reply With Quote
Old 09-30-2005, 05:24 PM   #7
waktasz
Member#: 86356
2015 s1000r
wheelie monster
I don't see why there would be a problem with doing it that way.
Old 10-01-2005, 04:47 PM   #8
ElBartoRex
Member#: 33899
2013 Focus ST
TB
it wouldnt be a problem, but the omori gauge is 52mm and the stock subaru gauge is 40mm..so the stock pod had to be modified with a dremel or something to make it fit.
if you buy the electronic gauges they come with all the sending units needed, but they do cost a little bit more than the electronic gauges. Check out www.j-spectuning.com for good gauges slection and prices.
Old 10-01-2005, 05:06 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Omori makes a 45mm gauge which will fit in the Subaru 42mm pod. I replaced my OEM Lamco gauge in the 3-gauge pod with an Omori, it fit with some dremeling of the bezel. If you have the column mounted gauge the Omori can be squeezed into the pod.
Old 10-02-2005, 12:41 AM   #10
dubluv17
Member#: 26298
MBP
i was thinking about the difference between electronic and mechanical gauges and i figured that electronic gauges start out with a mechanical unit, then it converts it to an electronic signal that goes to the gauge...so when you think about it, the reading that the gauge displays is originally from a mechanical unit...so is the electronic gauge really more accurate? it might have a more accurate mechanical unit, but other than that i don't know why it would be...the needle will maybe move a little different too...am i way off on my theory?
dubluv17 is offline   Reply With Quote
Old 10-02-2005, 01:11 AM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
All electrical gauges use an electric meter movement. The signal that moves the meter is provided by a sensor that measures the parameter in question- a pressure sensor for boost/vacuum, thermistors for oil or coolant temp, etc.
Mechanical gauges do not use electric meters and have mechanisms inside that are acted upon directly by whatever is being measured. Boost gauges usually contain Bourdon tube movements inside, which mechanically compare the ambient atmospheric pressure to manifold pressure.
In the case of boost gauges, both types are accurate as long as they are decent quality meters. The electrical ones have no moving parts besides the actual meter movement, so their response time is faster but this is not a huge issue.
Old 10-02-2005, 01:45 AM   #12
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Unfortunately, I don't think there is a universal answer to that question. One has superior accuracy & precision if the accumulated "error" that occurs as the actual signal is being passed along, converted, and contaminated with "noise" is smaller compared to the other. Could we say that one system definitely accumulates less error than the other?
For example, poor wiring/circuitry in an electronic gauge could offset the ideal supply voltage to the pressure sender in an electronic gauge such that it becomes a terrible system. The piezo element of an electronic gauge's pressure sender could be of a poor quality with significant hysteresis. In a mechanical gauge, the bourdon tube, or the gearing that follows could be poorly calibrated. A system made of high quality parts could have been improperly calibrated. In the end, it's the sum of the errors that matters.
I know that for industrial use, sensors are available in different ratings (in terms of accuracy, precision, response time, and possibly other relevant metrics). The "better" ones are usually more expensive, but that is not always the case. Afaik, aftermarket automotive gauges do not publish their quality metrics (e.g. precision, accuracy, etc.) per established industrial standards. Until then, it is up to the consumer to make their own conclusions.
As a "driver's feedback" tool, imho any gauge that reads reasonably consistently, and returns to zero when it should, is probably adequate. Anything beyond that is probably personal preference.
my 2 cents
Edit: Mulder beat me to it.
satrya is offline   Reply With Quote
Mech. Boost Gauge vs. Elec. Boost Gauge YooperWRX Newbies & FAQs 9 07-09-2009 11:37 AM
Difference between mech. & elec. boost gauges? PinnacleChronos Interior & Exterior Modification 5 12-12-2004 02:07 PM
3 Greddy elec. gauges w/pod, Invidia DP, Tanabe racing medallion cat back ihateSUVs Private 'For Sale' Classifieds 7 02-25-2004 07:17 AM
hod di i get my omori elec.gauges to dim?? StarDogChampion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-24-2002 08:27 PM
Mech. or Elec. gauges JakRex Newbies & FAQs 4 01-31-2002 05:53 PM
