Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 11-17-2005, 10:32 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default Japan Container Landed!!!
STi items:
STi Pink Springs - 04+WRX/STi
-Designed by STi to work with your stock Struts
-Doesn't lower your car too much: -.5" all around for STi, -1" all around for WRX.
-Will retain excellent ride quality while lowering car's center of gravity for increased handling prowess.
-Spring rates: Front: 258 lbs/in; Rear: 218 lbs/in
$379 shipped!!!
STi Group-N Strut Top Mounts - 04+ WRX / 04+ STi
-Stronger version of the stock style upper mounts. Hardened material increases suspension response by reducing flexing and camber changes. Good intermediate modification to maintain streetability over full-blown metal pillowball upper mounts. Easy bolt-on installation with no modifications necessary.
*Front Strut Top Mounts will work for all WRX model years.
$110 shipped for front!!!
$185 shipped for rear!!!
$279 shipped for F and R!!!
STi Group-N Strut Top Mounts and STi Pink Spring Combo - 04+ WRX / 04+ STi
$639 shipped!!!
STi Lateral Link Set (Full Pillowball) - 02-05 WRX
The six piece STi rear lateral link set upgrades all 8 link bushings to pillow ball type joints (spherical bearings) sealed against dirt intrusion. Also includes metal (w/ uniball joints) rear swaybar links with adapter brackets. With ultra-low compliance joints, this lateral link set significantly improves rear alignment control, handling response, and feedback. There will also be a slight increase in noise and vibration. The trailing arms replace the rear front trailing link bushing with pillow ball joints. Completes the set of rear suspension members when combined with one of the lateral link sets.
$525 shipped!!!
Cusco!
Cusco Type OS Strut Tower Bar - Front - 02+ WRX / 04+ STi
Suspension upgrades such as high performance springs, shocks and tires can add additional stress to the chassis resulting in additional chassis flex. Cusco Type-OS improve chassis rigidity and reduce this flex. Lightweight aluminum and high rigidity oval sectioned pipe used.
$150 shipped
Cusco Type CB (Carbon Fiber) Strut Tower Bar - Rear - 02+ WRX / 04+ STi
Suspension upgrades such as high performance springs, shocks and tires can add additional stress to the chassis resulting in additional chassis flex. Cusco Type-CB strutbars improve chassis rigidity and reduce this flex. The all carbon fiber shaft is lighter than most other bars and adds a serious race quality to the vehicle.
$220 shipped
Cusco Type OS-T Triangle Brace - Rear - 02+ WRX / 04+ STi
*Only includes the triangle brace, not the rear strut tower bar.
$125 shipped
Cusco Rear Suframe Brace and STi Rear Diffuser- 02+ WRX / 04+ STi
-Rear subframe brace is designed specifically for STi rear diffuser.
-Allows easy installation of 06 STi rear diffuser on 02-05 MYs.
-Stiffens chasis resulting in crisper vehicle dynamics and improved handling.
$249 shipped
Cusco Pillowball Upper Mounts - 02+ WRX / 04+ STi
-Designed to work with your stock struts.
-The full pillowball design controls unwanted forces under acceleration and braking. Stable steering response in essense and lane changing improved stability over bumps and holds roll in corners. Enables linear handling and keeps you on the record line better. Stability and safety during turn-ins and under braking. Camber adjustable by sliding the plate and pillowball sections.
$219 shipped for Front!!!
$219 shipped for Rear!!!
$419 shipped for F and R!!!
Cusco 22mm Front Sway Bar - 04+ STi
-Often described as the single most aggressive suspension modification for your Impreza, the addition of stiffer swaybars properly distributes cornering forces by reducing lateral sway applying increased cornering force on the outside wheel and will ultimately increase vehicle turning characteristics. The rear sway bar will increase oversteer and allow the car to turn tighter, while the front sway bar will have the tendency to increase understeer.
$155 shipped!!!
Please contact us for ordering information!
Thanks,
Preston
Phone: (510) 783-5300
We Accept Paypal!
Paypal: [email protected]
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Preston
Price including shipping: $XXXX
Shipping address.
Gruppe-S is offline
Old 11-17-2005, 10:39 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Helix Rear Endlinks - 02+ WRX
-Helix Solid Endlinks are CNC machined from high strength aluminum. This makes an excellent replacement for your factory plastic endlinks which tend to twist and bend upon corner-loading. The addition of Helix Solid Endlinks significantly increases cornering response and tightness, regardless of the use of an aftermarket sway bar or not. The use of spherical bearings allows for a much wider range of angular movement and eliminates the squeaking and creaking associated with the deterioration of rubber or urethane bushings. The spherical bearings are teflon coated to prevent dirt and debris from fouling movement.
$99 shipped!!!
Helix STi Rear Endlinks (Full Pillowball) - 04+ STi
$ 99 shipped!!!
STi Replica Strut Tower Bars - 02+ WRX / 04+ STi
-Suspension upgrades such as high performance springs, shocks and tires can add additional stress to the chassis resulting in additional chassis flex. These STi Replica Strutbars improve chassis rigidity and reduce this flex. By using a monocoque aluminum tube shaft, high strength and rigidity are obtained without unnecessary weight gain.
$75 shipped for the Front!!!
$60 shipped for the Rear!!!
$125 shipped for the Pair!!!
Tein Pillow Ball Mount (front) Subaru WRX 02-04
- Full pillowball: *NMB's (The world's top spherical bearing manufacture) pillow ball is used.
-Ultra duralumin A2017S-T4 (aircraft material) is used for upper seats and adjusting plates with anodized aluminum to have maximum strength and durability.
-Front camber adjustable
$180 Shipped!!!
DNA SERIES Helix Power is pleased to announce the release of the Helix DNA Sport Coilovers. Helix DNA Sport Coilovers are designed to with the budget minded performance enthusiast in mind. Unlike race coilovers which often exhibit harsh ride characteristics, high cost, and sometimes excessive noise, Helix DNA Sport Coilovers are designed primarily for street service with mild track service in mind. Featuring excellent ride characteristics and lower cost, these coilovers are a fine balance of street function and track service. Fully rebuildable and available in multiple spring rates at an additional cost.
- 8/6 kg/mm spring rates.
- Exclusively matched valving
- Independently height adjustable lower bracket
- 16 way dampening adjustable
- Light aluminum Shock Body
- Camber Adjustable, Full Pillowballs in the Front
- Currently 04 STi fitment only
$999 SHIPPED SPECIAL INTRODUCTORY PRICE!!
Guys, these coilovers have actually been available for several months. But they were not released until we tested these coilovers for ourselves. We have not only ran these coilovers in our street cars (for longevitiy and durability testing), we have heaped tons of abuse on these coilovers at various tracks around California, including Thunderhill, Buttonwillow, etc. We feel that these coilovers are simply the best bang for the buck coilovers available on the market.
Thanks,
Preston
We Accept Paypal!
product name: XXXX
sales rep: Preston/Geoff
Shipping address.
Gruppe-S is offline
Old 11-17-2005, 10:44 PM   #3
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
GD Vaned and Slotted 2 Piece Direct Replacement Rotors for 04/05 STi
In stock and ready to ship; the best bang for the buck 2-piece rotors!!
Gruppe-S is happy to announce that we finally offer some affordable 2 piece direct replacement rotors for the front of your STi!
-Retains stock Brembo calipers
-6 lbs. lighter per rotor than stock (equivalent to a total loss of 60 lbs. on the front of your car)
-Aircraft grade hardware (non-floating design)
-Zinc coated rotors
-Vaned and slotted
-Track tested
$549 + Shipping!
___________________________________________
Brake Packages for the WRX
Gruppe-S finally carrys Motul Fluid! People have been asking for some cheap effective brake combos for their WRXs for quite some time now. This is the most cost effective way to improve your brakes.
Porterfield R4S Pads + Goodridge SS Lines + Motul RBF600 Fluid
*The Goodridge Stainless Steel Brake Lines will improve your pedal feel and stop unwanted line flex at high temp.
*The Porterfield R4S Carbon Kevlar Brake Pads have a superior coefficient of friction compared to the stock pads and have excellent fade characteristics. They'll take 20 minutes of weekend track time for beginner to intermediate drivers with no ill effects
*2 Pints of Motul RBF600 Brake Fluid are more than enough to flush your entire brake system. This is some of the best brake fluid out there (DOT4) and is track worthy stuff.
All 4 Corners for 02 WRX - $299 Shipped
All 4 Corners for 03+ WRX - $319 Shipped
Thanks,
Preston
We Accept Paypal!
product name: XXXX
Shipping address.
Gruppe-S is offline
Old 11-18-2005, 09:24 PM   #4
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
new product added!
Gruppe-S is offline
Old 11-22-2005, 09:11 PM   #5
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
bump.
Gruppe-S is offline
Old 11-29-2005, 04:02 PM   #6
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
bump !
Gruppe-S is offline
Old 11-29-2005, 05:49 PM   #7
kunfuzion
Member Sales Rating: (20)
Member#: 1094
'85 Levin Hatch
color of rust
hi just sent in payment for m.c brace. let me know if you received it and if it is possible to receive it by fri? thanks.
jeff
kunfuzion is offline
Old 11-30-2005, 05:55 PM   #8
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Jeff - Thanks for the order.
Regards,
Preston
Gruppe-S is offline
Old 12-03-2005, 10:12 AM   #9
breaksjm
Member#: 66372
2012 Impreza WRX STi
I have a wrx motor swap in my 2001 RS coupe. Is the cusco m.c. brace compatible?
breaksjm is offline
Old 12-05-2005, 05:07 PM   #10
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
breaksjm - PM sent
thanks,
Preston
Gruppe-S is offline
Closed Thread
Japan Container Landed!!! Some Cusco stuff and JDM takeoffs! Gruppe-S Suspension/Brakes/Handling 24 08-08-2005 09:28 PM
Japan container landed ! JDM motors & tranmissions ! Gruppe-S Engine/Power/Exhaust 27 03-12-2005 06:48 PM
Japan container landed! JDM engines & VF34 turbos ! Gruppe-S Engine/Power/Exhaust 24 01-26-2005 04:36 PM
Japan container landed! Lots of JDM engines! Gruppe-S Engine/Power/Exhaust 22 01-20-2005 04:57 PM
Japan container just landed, lots of goodies unspoken for! Gruppe-S Vendor 'For Sale' Classifieds 101 03-11-2004 01:07 PM
