Old 09-30-2005, 06:33 PM   #1
andjurs
Member#: 64726
Default adjustment to highbeams
Are there adjustment screws for the highs? I tried searching but it's too general. My plan was to convert the highs into "fogs" by adjusting them down and adding ion crystal bulbs. It may sound dumb but it doesn't hurt to try something new for a change!
Thanks in advance.
- andrew
andjurs is offline   Reply With Quote
Old 10-01-2005, 08:16 AM   #2
andjurs
Member#: 64726
anyone?
Old 10-01-2005, 08:26 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I'm not sure if there are high beam adjusters on the 04/05. Your owners manual should tell you this.
As far as attempting to use the high beams as fogs, this is not a good idea. The beam patterns for fogs and headlights (low or high beam) are very different, and you can't use one as the other just by rasing/lowering the beam. If you want functional fog lights, you will need to buy and install them. There are no shortcuts.
Old 10-01-2005, 09:00 AM   #4
andjurs
Member#: 64726
Thanks for the response! I got this whole idea from the G35 since the fogs are integrated in the actual headlight also. Oh well.
- andrew
Old 10-17-2005, 02:36 AM   #5
andjurs
Member#: 64726
i can't find my manual! can anyone somehow take a picture of where it is? thanks!
Old 10-18-2005, 08:56 AM   #6
resident1155
Member#: 92659
2002 Impreza RS
ya except the g35 uses xenon headlamps...quite different from the $50 dollar lights on our cars.
My dad has this car...he can light up the road not only for himself, but also for the other 3 cars in front of him
resident1155 is offline   Reply With Quote
Old 10-18-2005, 02:44 PM   #7
JimBlake
Member#: 82247
2005 Saab 9.2x Aero
satin grey
Yeah, but those lamps (reflector & lens) are designed to show the right beam shape for a foglight. They don't just aim the highbeams & swap a different bulb.
It's not because they're xenons, it's the shape of the reflector & lens.
JimBlake is offline   Reply With Quote
Old 10-28-2005, 04:39 PM   #8
JDMprojekt
Member#: 97664
wait, so are the adjustment screws for the highbeams?
JDMprojekt is offline   Reply With Quote
Old 10-28-2005, 05:08 PM   #9
steadyhands
Member#: 89277
what are you driving? On the impreza/wrx/sti the reflector for the low and high beam are a single piece of plastic, so adjusting one adjusts the other.
steadyhands is offline   Reply With Quote
HIDs won't come on after switching to highbeams? fattysnax Electrical & Lighting 8 10-06-2008 11:47 AM
How long did it take to Adjust to your car from another make ? system60 Newbies & FAQs 25 06-27-2007 10:13 PM
Swapping DRL from lowbeam to highbeam? jezzy Interior & Exterior Modification 17 10-31-2006 12:24 AM
How long for ECU to adjust to mods? AndyWRXWG Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-21-2003 12:09 PM
What's your TurboXS MBC adjusted to? SubEd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-09-2001 02:26 PM
