Closed Thread
Old 09-30-2005, 06:46 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default what's normal oil temperature for WRX?
Just installed oil gauge on my WRX. It's reading at 150C+ after driving for about 10 minutes. What's normal oil temperature for WRX?
Gauge is 3 gauge pack from Subaru. Its maximum reading is just 150C.
txl146 is offline
Old 09-30-2005, 06:59 PM   #2
senortighto
Member#: 51873
2006 purty blue STi
in my driveway
that sounds like it is waaaay too hot, normal oil temps are around 210-220F or so, and around 240ish with hard driving, if i remember correctly. also 150C would be much hotter than that, so it is a possibility that your temp sender could be fubared or maybe something else?
senortighto is offline
Old 09-30-2005, 08:06 PM   #3
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
Yeah, that's way too hot. Even on an extremely hot day, driving the car hard, I can barely get above 100 C on my factory oil temp gauge.
I did have many problems with erratic readings and low readings on the factory gauge. I ended up having to replace the sensor ($150 - Ouch!) You may need to do the same.
jac04 is offline
Old 09-30-2005, 11:00 PM   #4
fuzzy13
Member#: 14178
2002 WRX Sedan
Platnium Silver Metallic
Under regular driving conditions I am seeing temps in the range of 96-98C and going up to 100-102C on hot days. I have seen it as high as 114C but that was during a auto-x, lapping in 40C+ weather and 20W50 racing oil.
150C is way too high. If you can, check the voltage etc from the sensor with a multi-meter or try to see what voltage the ECU is getting from the sensor.
fuzzy13 is offline
Old 09-30-2005, 11:34 PM   #5
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
When I installed the sensor, the connector was soaked in oil. Not sure if it has anything to do with such high reading... I will try to clean it up and reinstalling it.
txl146 is offline
Old 10-01-2005, 08:06 PM   #6
jac04
Member#: 49895
09 Forester
Originally Posted by fuzzy13
...or try to see what voltage the ECU is getting from the sensor.
The ECU has nothing to do with this sensor.
jac04 is offline
Old 10-01-2005, 08:08 PM   #7
jac04
Member#: 49895
09 Forester
Good idea, but I'm not sure it will make a difference. When I was getting low readings, I thought the oil might be acting as an insulator. Try come electrical contact cleaner on the swivel part of the sensor where it enters the threaded plug.
jac04 is offline
Old 10-01-2005, 10:13 PM   #8
Suberman
Member#: 82487
2007 WRX STI Spec C
whoa!! 150C is way too hot...mines around 95C. creeping slightly above 100C during hard driving. The wheather here is 33-34C daily.
Suberman is offline
Old 10-01-2005, 10:26 PM   #9
ebeck
Member#: 35585
RIP I'll always be
The Ver8 Magistrate
With regular Mobil 5/10W-30, the oil will fall apart at 115C. At those temps recing oil is needed and it needs to be changed alot. Think weekly. Above 130C is too hot period. I suspect the guage is broken.
You want to keep it 90C-100C.
ebeck is offline
Old 10-02-2005, 02:25 AM   #10
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Vettes run 240F+ under normal operating conditions, and close to 300F when racing. That's 115C normal and 130C+ racing. They come stock with M1, so I doubt that M1 "falls apart" at those kinds of temps, otherwise they would be spinning rods quite frequently.
Corvette Forum - Oil temps at the track?
Those temps are much higher than the temps in your typical WRX, though, as posted above.
drees is offline
Old 03-15-2007, 02:01 PM   #11
okaythen
Member#: 63397
hey guys I was running a circuit track and few min into it my oil temp is 250F.....could someone tell me how high I need to stop racing and how high I need to get oil cooler? thanks, I have vf34, full exhaust, FMIC
okaythen is offline
Old 03-15-2007, 02:17 PM   #12
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Go to the electrical forum and read the gauge FAQ.
Unabomber is offline
Old 03-15-2007, 02:17 PM   #13
ralliharri
Member#: 85035
2011 WRX 5-door
KTM 690 Duke
I had the oem gauge pack and sometimes I would get high readings like that, cleaned the connection and that tok care of it. Now I have a Defi/STI Genome pack, commuting I seee between 82-88 Celsius, y-day at WSIR I had +112C max on a +28C ambient temp with M1 oil and a 25%/75% antifreeze/didtilled water mix and a bottle of water wetter.
ralliharri is offline
Closed Thread
Normal oil consumption for 2009? Economatic Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 11-06-2009 12:39 PM
Normal operating temperatures for sleeved engines? jigga Built Motor Discussion 30 12-06-2007 05:39 PM
Normal Oil consumption for an STI??? carguy19 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 07-17-2004 02:06 AM
What's the best deal for WRX in Los Angeles area? over_rev Southern California Impreza Club Forum -- SCIC 7 01-24-2001 10:36 AM
