Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 10-01-2005, 12:36 AM   #1
marc l
Member#: 84592
2003 impreza WRX
yellow
Default problem with my hydra
hey whats up
i have a 99 subaru impreza with a custom turbo kit and i was running the hydra system. i was running okie. by okie i mean that it had its tuning glitches and what not... anywayz the last couple days it would start to act up. i knew it was working okie when the check engine light was on but it would all of a sudden just die!... and go back on! well yesterday i was driving home and POW same thing... this time it just didnt restart. it flat out died. i went back 2day with my laptop to see if there was a chance of getting the pos. to work but the software kept saying that i wasnt connected to the comp. so far my experince with this system has just been horrible. it has never seemed to work properly since the first day ive used it. anywayz im hoping someone on this site MIGHT be able to give me a hand. since as it sits now i have a 1500 dollar paper wieght thats worth a throw into a brick wall.
ANY help would be great!
thanks
marc l
TWE engine tech
marc l is offline   Reply With Quote
Old 10-01-2005, 12:18 PM   #2
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Originally Posted by marc l
hey whats up
thanks
marc l
TWE engine tech
Is this an Element Tuning Hydra EMS? I don't think it is as I would have heard from you but if so I can help you out but otherwise you'll have to contact the dealer you purchased it from for assistance.
Depending on what base map is in there it could be 1000 different things. A stand-alone is only as good as the tune it contains. Garbage in means garbage out! You may have bitten off more than you can chew as purchasing a stand-alone without a good base map and adequate tech support is a recipe for disappointment.
There are customers who are very good with tuning the Hydra and I'm sure if you provide a data log they'll try to help you out. If you cannot work this out yourself or through your dealer I do offer a support package with Element Tuning base maps and tech support but you may be better off putting that money towards a custom tune. You can also post on the Hydra EMS forums.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 10-02-2005, 01:47 AM   #3
marc l
Member#: 84592
2003 impreza WRX
yellow
hey sorry phil yesterday i was quite annoyed at the hydra system after it left me stranded across my city.
anywayz i'll try to explain the situation a bit more
the problem with the system wasnt that it isnt tuned right, its that it just completly died. it gets no power to the box no matter what car you plug it into. i originally got the system from andrew nam. maybe if you have heard of the problem b4 and have any info that would be great.
thanks
marc l
Old 10-02-2005, 10:41 AM   #4
Element Tuning
Member#: 54918
673 WHP Element
Check the main relay wire that powers the Hydra and make sure it's not loose, broken, or pinched etc. If you don't know what wire this is give Andrew at Hydra EMS a call and I'm sure he'll help you out.
Good luck.
Phil
Problems with my wrx stephentodd Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-02-2010 09:53 PM
Ok something is seriously wrong with my Hydra 2.17 spoolinsti05 Other Engine Management 6 06-02-2008 01:10 PM
help with my hydra dentprone Other Engine Management 3 08-07-2006 03:56 PM
Need help with my Hydra THE-95-STi Mid Atlantic Impreza Club -- MAIC 15 06-16-2006 10:24 PM
problems w/ my hydra pux888 Other Engine Management 34 01-25-2005 07:16 AM
