Old 10-01-2005, 04:11 AM   #1
1SIKWRX4U2NV
Member#: 24358
I miss boost...
Default JDM Fog Light Sizes?
I got home way too late from work to tear my jdm fogs out...can anyone lend a hand and tell me what size bulb they are using in their jdm fogs? I'm really considering a yellow bulb...i just haven't found jack about what size they are. Thanks ahead of time!
1SIKWRX4U2NV is offline   Reply With Quote
Old 10-01-2005, 11:16 AM   #2
909
Member#: 18776
04 and 05 JDM Fogs run H3's.
I know, I own a set.
Hope this helps.
909 is offline   Reply With Quote
Old 10-01-2005, 04:31 PM   #3
1SIKWRX4U2NV
Member#: 24358
I miss boost...
you rock...thanks. Any suggestions you might have for yellow (h3-sized) bulbs?
Old 10-01-2005, 05:47 PM   #4
WR^2X
Member#: 37617
Narva Golds from danielsternlighting.com.
Actually, it looks like he has changed them to "CPI-Universal Gold." I have them, and they are great.
WR^2X is offline   Reply With Quote
Old 10-24-2005, 05:55 AM   #5
1SIKWRX4U2NV
Member#: 24358
I miss boost...
can the jdm fogs run either 55w or 100w bulbs? I don't know jack about bulbs...does wattage determine brightness, or does it just have to do with the particular application???
Old 10-24-2005, 11:16 AM   #6
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
I wouldn't run anything higher than 55w bulbs on the OEM wiring, JDM or not. However, if you want to run higher wattage bulbs though, you'll have to build your own wiring harness with a relay that's activated by the OEM wiring.
Wattage does determine brightness. However, the design of the lamp shape, reflector, and lens also determine brightness.
www.rallylights.com has all the info you'll ever need. Or just ask here. They also stock Hella Yellowstar bulbs in various wattages.
05 JDM fog light bulb size tacomaprime Electrical & Lighting 0 12-29-2009 08:30 PM
fs: 04-05 jdm light housings. jdm fog light kit. rathead Exterior/Styling 13 10-11-2008 12:40 PM
fs: 04-05 jdm headlight housings, jdm fog light kit, fog clear covers rathead MWSOC Private Classifieds 8 10-08-2008 12:08 PM
Bulb size for 05 JDM fog lights FlatBoost Electrical & Lighting 4 06-21-2007 03:50 PM
JDM fog light size brunetmj Electrical & Lighting 3 02-20-2004 05:05 PM
