Old 10-01-2005, 03:19 PM   #1
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
Default Problems with JDM alignment
after installing these i cant get the low beam to significantly adjust lower, after cranking it all the way to the lowest position to seems to get worse???!??
is there a cycle (one or 2 full turns) that i cant go beyond? i cranked it like 100 times and it doesnt get better. IDEAS?
bren wrx is offline   Reply With Quote
Old 10-02-2005, 06:22 PM   #2
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
bumpppp
Old 10-02-2005, 10:52 PM   #3
vinceGC8
Member#: 72263
2008 Impreza STi
Dark Grey Metallic
you were adjusting it using the bottom adjustment thing right? the top one is horizontal adjustment.
you could have poissibly stripped the screw that adjusts the headlight. did u buy these new or used?
vinceGC8 is offline   Reply With Quote
Old 10-03-2005, 01:07 AM   #4
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
used from a friend who never touched but nothing looks strip, all the teeth spin, and they do adjust, but BARELY
Problems with JDM fog kit on my STi ewright Interior & Exterior Modification 1 08-02-2005 10:22 PM
problems with jdm hid projector install Benjamin Tang Electrical & Lighting 2 10-23-2003 11:03 AM
Problems with JDM cindergarden Subaru Conversions 3 06-11-2003 12:04 PM
Problem with JDM Hids, help!! Cerum Interior & Exterior Modification 1 03-02-2003 03:00 PM
bulb (turn signal) problem with JDM tails wop Interior & Exterior Modification 2 05-11-2001 08:17 AM
