Old 10-01-2005, 11:06 PM   #1
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
Default How do you separate the oil pan from the block?
I've got all the bolts out, now what?
Service manual says to use some special tool, I don't have it, what else works?
jasona is offline   Reply With Quote
Old 10-02-2005, 02:00 AM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Use a putty knife or something similar that is skinny and flat. Gently work it between the block and pan.
Legacy777 is offline   Reply With Quote
Old 10-02-2005, 12:19 PM   #3
InsaneAznKid
Member#: 57037
1998 Audi A4 1.8T
Pearl White
yeh pretty much nething that is strong enuf and skinny enuf and try to get it inbetween the block and pan. I used a flat head screw driver and a hammer personally.
InsaneAznKid is offline   Reply With Quote
Old 10-02-2005, 12:28 PM   #4
shwaggin
Member#: 90017
2003 Forester 2.5X
WRC Wim-Wam Shaft
Subaru must have some reason to specifically say not to do that. Have you looked into maybe buying the tool from Subaru (it could be cheap) or renting a similar thing from AutoZone/Advance?
shwaggin is offline   Reply With Quote
Old 10-02-2005, 01:54 PM   #5
BlkTS02
Member#: 50142
2002 2.5TS
MBP
FHI doesn't want you to use something that can score / gouge the block or the pan, which is why they have the disclaimer.
BlkTS02 is offline   Reply With Quote
Old 10-02-2005, 10:56 PM   #6
InsaneAznKid
Member#: 57037
1998 Audi A4 1.8T
Pearl White
meh..mine was perfectly fine
Old 10-03-2005, 01:32 PM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
A healthy dose of being careful will ensure the pan comes off without damaging the block's sealing surface. A putty knife (preferably brass) would be even better....but just being careful is usually enough.
Jay Storm
Old 10-03-2005, 03:31 PM   #8
mranlet
Member#: 66304
98 RWD BG Outback
...with R200 and ITBs ;)
I couldn't seem to get the few bolts on the rear side of the pan off past my crossmember (98 OB Wagon and nothing would fit in there). Can you even get those off without lifting the motor?
The putty knife will be fine. Are you using an OEM replacement gasket or RTV sealant?
mranlet is offline   Reply With Quote
Old 10-03-2005, 03:32 PM   #9
amorton
Member#: 72798
2000 2.5 RS Sedan
Blue Ridge Pearl
give the pan a few good knocks with a rubber mallet then use the screwdriver
amorton is offline   Reply With Quote
Old 10-03-2005, 05:10 PM   #10
vwown3d
Member#: 69991
Leh Keen Approved
'68 Volvo Amazon
bang it a couple times, try not to mess up the seal between the block.
vwown3d is offline   Reply With Quote
Old 10-03-2005, 07:52 PM   #11
chip4761
Member#: 55867
2005 Saabaru
AS
I just whacked on mine with rubber mallet a couple of itmes. It popped right off.
chip4761 is online now   Reply With Quote
Old 10-04-2005, 06:25 PM   #12
Legacy777
Member#: 4800
You have to raise up the motor a little bit to get the back screws off.
Old 10-05-2005, 12:41 PM   #13
mranlet
Member#: 66304
98 RWD BG Outback
Is there enough play in the stock mounts? Thanks!
Old 10-05-2005, 12:52 PM   #14
jasona
Member#: 11786
2014 OB 2.5i 6MT
you have to unbolt them
Old 10-05-2005, 05:38 PM   #15
chip4761
Member#: 55867
2005 Saabaru
AS
oh yeah, those rear screws are a pain. I would suggest raising the engine as much as possible. Maybe remove the manifold bolts as well. It's the installation that is the bigger hassle.
Old 10-05-2005, 06:17 PM   #16
mranlet
Member#: 66304
98 RWD BG Outback
Hmmn.... I'm planning on pulling my motor to do some headwork, solid motor mounts, and valve cover gasket replacement anyway, maybe I'll just let my oil pan gasket leak until then
Old 10-06-2005, 05:54 PM   #17
sidekickawd
Member#: 91929
1995 Impreza L (RIP)
UPDATE Color soon to come
It is very possible to get to the bolts in the back. All you need is the right tools and alot, ALOT of patience.
I did my oil pan gasket a month ago, i used a ratchet with an extension and a "swivel" extension on top!
NO need to raise engine!
sidekickawd is offline   Reply With Quote
will the oil pan from a 1.8L fit.... Meat Supply Pre-2002 Factory Turbo Powertrain 7 03-11-2009 10:30 AM
How do you tell if Oil pump is Primed? Turbo Oil Line? Hayaboosted Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-25-2008 02:55 AM
How do you separate the tranny/clutch? d00f Transmission (AT/MT) & Driveline 3 05-16-2002 12:35 PM
How do YOU keep your sub box from flying around? Jimmy S. Car Audio, Video & Security 22 02-18-2002 01:29 AM
How do you change gear oil? 2yLiTe Interior & Exterior Modification 4 11-01-2000 10:41 PM
