Old 10-02-2005, 07:55 PM   #1
Suburban
Member#: 61237
2004 Impreza 2.5 TS
Default How'd you wire gauge temp sender?
I wired up my tranmission temp sender, and the gauge isn't working. I stripped about 1.5" or wire, tied it to the button machined into the top of the sender, wrapped the rest around, and then secured with heat shrink tubing. For the sender ground, I wired a hose clamp which I tightened to the hex flats of the sender, and secured the other end of the wire to a covenient body ground nearby.
How did you do it? I realize that if you put your sender in the block, you probably didn't have to worry about the ground wire, but does that sound right?
Is there some way I can check for a signal on the sender wire? I have a multimeter, albeit a cheap one.
I wonder if my problem might also be that grounding on the radio chassis might not work. That's what the fastwrx.com gauge wiring guide said to do, but it seems odd. Wouldn't be too hard to check the voltage there, and tap into the clock ground, I just don't have the energy after contorting under the car for hours.
Gauge and sender are VDO, by the way.
Suburban is offline   Reply With Quote
Old 10-04-2005, 12:36 AM   #2
Suburban
Member#: 61237
2004 Impreza 2.5 TS
Bump.
I'm getting about 13 volts (cheap multimeter, remember) from the accessory power wire, which goes to the gauge, so ground and power wires are okay, I think. I think I got about 2.6 ohms between the sender wire and ground, so I guess the sender connections must be okay.
I wonder if the gauge is just defective. I've never seen the needle do anything. Never jumps when I turn the key to ACC, or start the car. Never moved. Or maybe that's normal, I dunno.
Please help!
52mm Red Digital LED Trans Temp Gauge w/ Sender WRXwife Drivetrain 3 04-18-2010 03:27 PM
Lamco Voltmeter & oil temp gauges without wiring harness or sender gopsu Interior/Dressup/Audio & Security 0 07-22-2009 08:52 PM
'04 Performance Gauge pack problems - oil temp sender wastintime Electrical & Lighting 4 05-01-2006 07:03 PM
new oil temp sender for stock gauge pack PeterJ Electrical & Lighting 1 03-23-2004 07:13 AM
Oil temp gauge. What sender? Jon Bogert General Forum Archive 2 01-11-2001 01:41 PM
