Old 10-02-2005, 09:04 PM   #1
mrtrex
Member#: 12223
2005 WRX
Default Can I tune my car with Delta Dash?
I am running a vishnu tuned ecutek ecu. I am trying to get some more power out of the car in its current state. I have a dyno that I can use but can I fine tune it with the delta dash?
mrtrex is offline   Reply With Quote
Old 10-02-2005, 09:39 PM   #2
dentsport
Member#: 71201
Shop Sport Service
781-551-3399
Yes and no. Ecutek has a ''user-tune'' feature in which you can make global timing/fuel adjustments. By global i mean if you add a degree it adds it across the board for the whole map.
This feature isn't available with all ecu codes. I believe the tuner also has to activate this feature for you to be able to use it.
I would recommend a custom tune. I personally don't like the global adjustments and would only use it to make the tune safer and not to get more power. Good luck.
Louis
dentsport is offline   Reply With Quote
Old 10-02-2005, 09:51 PM   #3
mrtrex
Member#: 12223
2005 WRX
Thanks for the info. I am running a vishnue ecutek and I want a custom tune. It sucks they are in Cali
Old 10-02-2005, 09:53 PM   #4
wrxdaddy
Member#: 14164
02 Impreza Wgn
95 L Project in progress
Fine tune in what way? I don't think you can get more power using DeltaDash other than do logging, change idle settings and retard timing up to 5 degrees overall. If you are looking for more power, a retune by an EcuTek tuner is required.
wrxdaddy is offline   Reply With Quote
Old 10-02-2005, 10:00 PM   #5
wrxdaddy
Member#: 14164
02 Impreza Wgn
Just because you have a Vishnu EcuTek doesn't mean you are stuck. Any EcuTek tuner will be able to give you a custom tune.
Old 10-04-2005, 04:49 PM   #6
PunKidd
Member#: 8533
2002 2.5 RS-T
LudeSpeed S. III W/ FMIC
Yeah, you already have the license on the ECU, so you'll just have to pay hourly for the tuning. The bummer is that your local tuner will not have access to the map that Vishnu loaded on the ECU, so they'll have to start from scratch (or w/ what ever base maps they have in house).
PunKidd is offline   Reply With Quote
Can i tune my ECU with a mac :confused: YamadaRunner Newbies & FAQs 11 09-30-2009 11:53 PM
Anythng I can do to my car, with little money shamrock 05 Interior & Exterior Modification 30 04-13-2008 08:28 PM
Tuning with Delta Dash on an Ecutek Reflash Tuned Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-04-2004 09:43 PM
Can I run a VF39 with out tuneing my car SupraTT&WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 05-22-2004 10:57 AM
A/F with Delta Dash mynew02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 06-05-2002 01:10 AM
