Old 10-02-2005, 10:16 PM   #1
95 avus blue
Member#: 57818
Default would an STI guage cluster fit an 02 WRX wagon?
Hi guys, would an STI guage cluster fit an 02 WRX wagon?
95 avus blue is offline   Reply With Quote
Old 10-02-2005, 10:52 PM   #2
vinceGC8
Member#: 72263
2008 Impreza STi
Dark Grey Metallic
yes it will
vinceGC8 is offline   Reply With Quote
Old 10-02-2005, 10:54 PM   #3
SplatZ400
Member#: 84377
2011 335d
as long as its an 04 gauge cluster.
SplatZ400 is offline   Reply With Quote
Old 10-03-2005, 02:25 PM   #4
wagons_ho!
Member#: 16574
My v7 (02JDM) plugged right in, and everything worked immediately.
The DCCD control lights illuminate with the PRNDLL of my automatic transmission too!
The v8 cluster (03JDM/04+USDM) needs some work, I'm told... but IMHO the bugeye STi cluster belongs with the bugeye Impreza...
wagons_ho! is offline   Reply With Quote
Old 10-03-2005, 06:40 PM   #5
triumph87
Member#: 34125
06 WRX STI
Blk
Is there any way to put the 05 sti cluster in the 02 wrx
triumph87 is offline   Reply With Quote
Old 10-03-2005, 08:45 PM   #6
Dutch
Member#: 82272
Its more trouble then its worth. You would also have to get the STi odometer mileage set to your current WRX mileage. You would have to send it out to some guys to do that.
Dutch is offline   Reply With Quote
Old 10-03-2005, 09:23 PM   #7
SplatZ400
Member#: 84377
2011 335d
no u dont have to ^^^ that is a personal choice. no the 05 sti cluster will not fit an 02. the only cluster that fits the wrx (02-05) is the 04 sti cluster. the 05 sti cluster only fits in other 05 sti's!
Old 10-03-2005, 09:23 PM   #8
SplatZ400
Member#: 84377
2011 335d
the cluster swap takes all of 5min!
Old 10-03-2005, 10:09 PM   #9
vwown3d
Member#: 69991
Leh Keen Approved
'68 Volvo Amazon
the 05 sti cluster will work with a little platic trimming so i guess its not plug and play but its not the end of the world for you if you buy one
vwown3d is offline   Reply With Quote
Old 10-04-2005, 07:15 AM   #10
wagons_ho!
Member#: 16574
For the second time, the V7 cluster plugs right in, without cutting, splicing, chopping, scraping, dremmelling, swearing or buying other parts to make it fit.
The V8 (04-05) cluster filts, but you have to do the other stuff to make it work. The fascia (the thing that fits on top of the acutal cluster) is different, so you need one of those or some warning lights are covered, you've got to cut wires and grind...
Get a v7 cluster, and it's done in 3 minutes. No guesswork.
Old 10-04-2005, 11:21 AM   #11
InfamousDX
Member#: 25413
the 2004 usdm sti cluster will go in with just cutting 1 wire... I'd say that adds about a minute, tops. And it looks much better than the v7.
Old 10-04-2005, 12:02 PM   #12
wagons_ho!
Member#: 16574
A colleague just bought the back parts - white housing, motherboard, gauges - new from Subaru and didn't realize that the fascia was different.
If you buy the complete cluster - from the clear plastic cover to the back white housing - that should be easier...
And if the dealer has done your servicing in the past, you'll be busted - meaning no warranty work whatever - if the new speedometer mileage isn't changed to meet your old speedometer's mileage.
Installing an STI gauge cluster in an 02 WRX madmax02 Interior & Exterior Modification 43 06-14-2008 03:56 PM
Will 06+ STi guage cluster Fit 98RS? BlacknGold98RS Interior & Exterior Modification 2 03-29-2008 01:34 PM
05' STI Guage Cluster into an 04 WRX subietech420 Electrical & Lighting 7 04-16-2006 01:17 PM
Does the red STi gauge cluster fit in a WRX wagon? Alan l. Interior & Exterior Modification 23 07-15-2005 10:18 AM
Will a stock STI TBE fit a 02 wrx wagon? bottlediger Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-06-2004 10:50 PM
