Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 10-03-2005, 01:55 AM   #1
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Default MY00 Alternator - Not up to the task???
I got my MY00 NA model back last year and from day one, I noticed that the tunining on the headlights, especially the fogs and my power windows, would cause my interior light to dim slightly, and my revs dropped a bit.
Or if my radiator fan kicks in, gthe revs would dropped a bit and come back up.
Could this be a problem with the alternator not being able to handle the load or going bad -which I doubt?
Is this normal at all?
What can I check?
The battery connectors are good and clean. Ground points seems good, clean and tight.
When driving my voltage is from 13.9-14.2v, which mean nothing if it cannot handle the load.
My battery starts the car very well. Starting is very very crisp.
west_minist is offline   Reply With Quote
Old 10-04-2005, 07:52 AM   #2
west_minist
Member#: 53451
w/ AVCS Silver
Bump!
Old 10-04-2005, 10:16 AM   #3
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
Does the same thing as mine. It's done it since day one.
If your really worried about it, I hear a WRX alt. has a higher ouput, but i've never really done any research on this, so you might want to do some.
tooocool49723 is offline   Reply With Quote
Old 10-04-2005, 10:55 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Actually the WRX alternator has LESS output than the 2.5 NA alternator, 75A vs. 90A.
Aside from cleaning and tightening connections and grounds, and doing basic voltage checks, if you suspect the alternator may be weak have a shop check it out with proper diagnostic equipment. It is possible for the alternator to have one or more bad diodes which will reduce its output (and may also cause some strange electrical symptoms in the car), but you wouldn't see this on a voltmeter. It would only show up on a diagnostic scope.
Old 10-10-2005, 12:42 AM   #5
erice1984
Member#: 11778
1980 VWRabbit Diesel
w/AAZ Swap
i second mulder's response. if you got an o-scope or something laying around hook that thing up to it and look for abnormal wave patterns.
do you experience sluggish performance, or hesistation, if so you can check the grounding points on the rest of the car and check for voltage drop.
erice1984 is offline   Reply With Quote
Old 10-10-2005, 12:49 AM   #6
west_minist
Member#: 53451
w/ AVCS Silver
I am suppose to get a the car check out soon bu the shop.
I have no scope around. I would have to ask my friend.
But all true.
Old 10-10-2005, 12:50 AM   #7
west_minist
Member#: 53451
w/ AVCS Silver
No hesitation, except bad performance up to 3K.
I will check it out soon when I visit the dealer.
DD service not up to par superhero Vancouver Impreza Club Forum -- VIC 9 02-02-2004 01:19 PM
Rattling trunk -> weld not up to spec -> fixed??? h2o Southern California Impreza Club Forum -- SCIC 16 11-05-2003 03:48 PM
MY00 will be flatbedded to the nearest dealer BROWNS!:eek: Rick G Tri-State Area Forum 2 12-23-2002 03:10 PM
I think I'm losing my mind! Car not up to par spshultz General Forum Archive 5 03-20-2001 01:04 AM
