Old 10-03-2005, 12:36 PM   #1
WRXINTX
Member#: 96712
Default HELP!!! what is the difference between JDM rear diff and USDM?
'03 WRX
I was told that I have a JDM rear that has been WELDED up for drag use....
I want to put a KAAZ unit in this so I can keep from breaking axles when I drive it on the street.....
What are the differences between JDM and USDM rear diffs???
Is the JDM one a R180??? like an STI over here???
I really just need to know how to I.D. an R160 versus an R180 rear diff....
Cover pattern? part numbers or what???
Thanks!
RYNO
WRXINTX is offline   Reply With Quote
Old 10-03-2005, 06:32 PM   #2
WRXINTX
Member#: 96712
anybody help on this one, please?????
Thanks!!
RYNO
Old 10-04-2005, 04:09 PM   #3
WRXINTX
Member#: 96712
bump.... still need help..
Old 10-04-2005, 04:50 PM   #4
Agile Auto
Member#: 91335
The USDM WRX diff the r160 is only 6 inches across while the larger Sti diff the r180 is 7 inches across. This is the best way to tell what you have.
Agile Auto is offline   Reply With Quote
Old 10-04-2005, 04:56 PM   #5
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
You might want to take the cover off and look at the ratio...it should be stamped but you may have to count the teeth. Even if you find out it's an r180, or r160 you'll want to know what ratio it is to see if it'll work with your car.
Louis
www.dentsport.com
781-551-3399
Soon2Bgreat is offline   Reply With Quote
Old 10-05-2005, 09:57 AM   #6
WRXINTX
Member#: 96712
Thanks so much for the info, Both of yous guys!!!!
Now on saying the "diff" is 6inches across.....
Do you mean the actual 3rd member "pumpkin" differential that the ring gear mounts to?
or are you talking about the width of the outside of the case of the whole "differential", like the inner CV axle to CV axle width....
Thanks!!!!
RYNO
what is the difference between a "small block" and a "big block?" alacrity024 Off-Topic 48 10-24-2007 04:51 AM
what is the difference between borla dual tip and single ryanpietro Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-04-2006 01:03 AM
What is the difference between JDM and US Brembos subalou1 Brakes, Steering & Suspension 3 03-19-2005 01:22 PM
What is the difference between republican, democrat, conservative, and liberal TBOD Off-Topic 42 09-08-2004 10:04 AM
what is the difference between a 2.5rs and the ts with the 2.2 engine for the gc8 bebeGDB Subaru Conversions 8 01-26-2004 10:08 AM
