Welcome to the North American Subaru Impreza Owners Club Friday May 29, 2015
Old 10-03-2005, 03:43 PM   #1
cs11elonce
Member#: 97494
2002 Impreza WRX
Default Any idea why Cobb and other ECU companies give their mappings with Stock Intake box?
Does anyone know why Cobb only provides AccessPort mappings for setups containing the stock intake box?
When I purchased my 02 WRX it already had a cold air, turbo back exhaust and up-pipe installed.
Am I going to have to track down a stock intake box now to use the AccessPort?
I thought cold air's were normally a beneficial upgrade...
cs11elonce is offline   Reply With Quote
Old 10-03-2005, 03:44 PM   #2
HOV
Member#: 64632
CAI is not an upgrade for the WRX. It can actually reduce performance.
HOV is offline   Reply With Quote
Old 10-03-2005, 03:51 PM   #3
sportz135
Member#: 43021
08 Impreza WRX
09 Kawasaki Ninja 250R
It is possible to tune for a CAI, but it is usually pretty difficult and i'd imagine you'd need a utec or street tuner and a dyno
sportz135 is offline   Reply With Quote
Old 10-03-2005, 03:52 PM   #4
nick04263
Member#: 68799
2004 WRX COBB STG 2+
put the stock box back on.
nick04263 is offline   Reply With Quote
Old 10-03-2005, 05:20 PM   #5
KingOfSiam
Member#: 84636
2005 WRX (automatic)
Crystal Gray
Cobb has a map for a certain brand of short ram intakes. I forget which one.
KingOfSiam is offline   Reply With Quote
Old 10-03-2005, 05:24 PM   #6
2.5 SUBY
Member#: 78802
I too will soon be getting a cat back,UP and Cobb AP. That way next spring i can just hook up my DP and run stage 2. I run APS short ram right now. Wonder how that will be
2.5 SUBY is offline   Reply With Quote
Old 10-03-2005, 05:27 PM   #7
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
injen
Bishop is online now   Reply With Quote
Old 10-03-2005, 05:33 PM   #8
chinoWRXL
Member#: 89123
02 WdBody STi Wgn
03 L
cobb has their own sr too. buddy has it on sti, blue cone filter didn't stay blue for long. but AFIK it has a fin that helps stabalize intake air flow to account for MAF misreadings. running a map w/ a cold air intake shouldn't make the map unusable, just not maximized.
my 2 cents
chinoWRXL is offline   Reply With Quote
Old 10-03-2005, 06:20 PM   #9
chinoWRXL
Member#: 89123
02 WdBody STi Wgn
03 L
SF Intake (Short Ram) $185.00
Available in Silver or Black
Requires no tuning as it retains the stock size tubing for the MAF sensor.
Old 10-03-2005, 06:21 PM   #10
chinoWRXL
Member#: 89123
02 WdBody STi Wgn
03 L
from a distributor of cobbs
Old 10-03-2005, 06:35 PM   #11
Lexington
Member#: 50221
I'm on internets
Racin on ur bandwidth!
intil you are making rediculous power, the stock airbox is PLENTY.
Besides.. when you pop your hood and all ppl see is your stock airbox stock bov stock intercooler, blah blah.. they'll think you're just a slow WRX =)
Lexington is offline   Reply With Quote
Old 10-04-2005, 12:54 PM   #12
Scooby921
Merci Buckets
Member#: 88606
2015 GMC Sierra
'13 JCW
They do this because it is easier to tune the maps for one specific intake than to try and create individual maps for all the different CAI / Short-ram intakes on the market. The stock one is more than sufficient, and the majority of people who read these forums before modding their car decide to stick with stock.
In your case, the previous owner didn't read these forums. You shouldn't need to go back to a stock intake. You just won't be seeing any performance gains from having an aftermarket CAI.
Scooby921 is offline   Reply With Quote
Old 10-04-2005, 07:39 PM   #13
scooby888
Member#: 64226
2004 Impreza WRX
World Rally Blue
I believe the stock airbox will almost always give stable MAF readings, while CAI's produce erratic readings that are hard to tune for. Thus, I have a short ram which I'm pretty sure doesn't do much but looks bling!
scooby888 is offline   Reply With Quote
Old 10-04-2005, 10:04 PM   #14
BoostinEJ20
Member#: 73710
exactly waht evey 1 else was saying...they do it cause not all intakes are alike...besides stock airbox...they can guarantee their maps when all sorts of other intake characteristics exhist, and tryin to make maps for all would just not be worth it....now they might make maps in the future for their own stuff, like their own new intake and maybe one for their new tmic under development...but thats just so we buy more of their great products
BoostinEJ20 is offline   Reply With Quote
Old 10-05-2005, 11:37 AM   #15
chinoWRXL
Member#: 89123
02 WdBody STi Wgn
03 L
friend w/ 05 sti that had the COBB SR intake did a basline dyno pull. no EM. a/f's all good...
Old 10-05-2005, 12:49 PM   #16
marcus.raw
Member#: 97675
93 Stroked LS3 FD
Launch Edition 2015 STI
gernerally...under hard accelleration CAI is a downgrade on the wrx unless your making a lot of power to the ground. if im mistaken i believe thats somewhere over 300whp. the reason cai are bad is because usually the diameter is larger over stock, and creates air turbulance under a large load. the turbulance the air causes results in incorrect MAF sensor readings, making ur car act no where near what you would want it to. since cobb has a map of stage 2, it does not qualify for a CAI mod nor a map. the stock air box has been proven to hold its own up to 300whp compaired to what an aftermarket could provide to that point
marcus.raw is offline   Reply With Quote
Old 10-05-2005, 01:07 PM   #17
trustWRX
Member#: 40431
2009 Scion XB
COBB released a Stage 2 map for WRX's with an Injen CAI. Since I have an Injen CAI sitting in a box on my bedroom floor I called COBB to ask about that new map. Their response?
"It makes no difference if you have the Injen CAI in there or not. You're still better off with the stock box even though we have a map for it".
Good enough for me.
trustWRX is offline   Reply With Quote
Old 10-05-2005, 03:28 PM   #18
Beer:30
Member#: 80192
2004 subaru
JBP
Because the stock airbox is properly engineered by professional automotive engineers @ FHI.
Beer:30 is offline   Reply With Quote
Old 10-05-2005, 10:21 PM   #19
IIdiceII
Member#: 90438
I never understood why people put a cold air intake on a turbocharged motor. It draws cold air from outside the engine bay but once air goes through the turbo, it gets hot and goes then goes through the intercooler and gets cooled down. So, I dont see the point to it.
IIdiceII is offline   Reply With Quote
Old 10-06-2005, 07:49 AM   #20
quazimoto
Member#: 70395
Its because most CAI are a larger diameter than the stock air box sensor housing/orifice causing the MAF to no longer be calibrated.
quazimoto is offline   Reply With Quote
Old 10-06-2005, 07:52 AM   #21
Wolfen42
Member#: 33060
2006 WRB WRX Wagon
I turbocharge campfires.
Because when it's being compressed at the turbo you still want it to be colder.
Wolfen42 is offline   Reply With Quote
Old 10-06-2005, 07:54 AM   #22
quazimoto
Member#: 70395
I used to think the same thing untill someone shed some light on the subject.if temp A goes onto the turbo 10 degrees colder than temp B its relative to say that temp A will still come out 10 degrees colder.Plus the fact that the intake air temperature is being measured at the MAF which plays a part in timing and fueling.The IAT sensor and MAF are intergraded into one unit.
Old 10-06-2005, 08:32 AM   #23
f4phantomii
Member#: 58504
2004 STi w/o wing
Aspen White / Silver
Read the Intake FAQ and it should answer your question.
-Michael
f4phantomii is offline   Reply With Quote
Old 10-06-2005, 01:16 PM   #24
Dueysan
Member#: 50292
2004 Impreza WRX
Red
Stock intake is good up to 300whp as resz2jen has said. "Cold Air Intakes" are just another piece of expensive junk sold to noobs. Even the name is total BS. They don't do anything except empty your pocket and line the pocket of the hundreds of aftermarket makers who will sell you anything at an inflated price. If you want "colder air" buy a bigger intercooler and a waterspray (or injection system).
Dueysan is offline   Reply With Quote
Old 10-06-2005, 02:38 PM   #25
checque
Member#: 68562
RIP Edwin
lol, if you're still running a stock intercooler, you are just a slow WRX
checque is offline   Reply With Quote
2006 sti stock intake box with maf hose and air filter SUBIEDUDE33 Engine/Power/Exhaust 5 04-30-2009 07:45 PM
FS: Turbo XS UTEC 2005 with maps, Stock Springs, stock intake box xxscaxx Engine/Power/Exhaust 23 05-17-2007 10:38 PM
FMIC with stock intake box silverGDB Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-01-2006 08:46 AM
any HR guys have there stock intake box and filter?... Homemade WRX Mid Atlantic Impreza Club -- MAIC 7 06-11-2004 01:23 PM
any ideas why the power steering would give up at low rpm? Bart Service & Maintenance 9 01-14-2003 05:15 PM
