Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 10-04-2005, 12:00 AM   #1
gc835
Member#: 78080
2001 impreza
red biatch
Default wrx dp fit a 94 legacy?
will a dp off a 03 wrx fit?
gc835 is offline   Reply With Quote
Old 10-04-2005, 12:27 AM   #2
Natoe
Member#: 90353
Sold '95 22T Impreza
'99 EJ205 L, AE86 GVR4
i have the legacy turbo motor in my impreza and got a wrx DP, and sti catback, and it works.
BUT if you plan on hookin it up to the stock exhaust the wrx one is like 1 to 2 inches longer then the legacy one. (i had both and compared them and i couldnt use the legacy one because it didnt reach)
and sti/wrx catbacks dont fit the legacy without modification.
hope that helps
Natoe is offline   Reply With Quote
Old 10-04-2005, 12:29 AM   #3
gc835
Member#: 78080
2001 impreza
red biatch
so a wrx dp wont hook up to a legacy exhust?
Old 10-04-2005, 12:38 AM   #4
Natoe
Member#: 90353
its a couple inches longer, it bolts up, fits down like it should then just sticks too far... you might be able to make it work, the bolt pattern on the flange at the bottom is the same even, just have to get rid of a couple inches or have it stick out the back too far (maybe)
Old 10-04-2005, 12:44 AM   #5
gc835
Member#: 78080
2001 impreza
red biatch
ahhh couldnt you cut the exhaust and take the extra off and weld the flange back on??
Old 10-04-2005, 02:24 AM   #6
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
That's what he just said.
Why do you want one though, it's essentially the same thing.
THAWA is offline   Reply With Quote
Old 10-04-2005, 03:11 AM   #7
gc835
Member#: 78080
2001 impreza
red biatch
same as what? a 3 " dp???
Old 10-04-2005, 03:19 AM   #8
THAWA
Member#: 44581
3 Boxers 2 AWD
What 03 WRX comes with a 3" downpipe?
Old 10-04-2005, 03:22 AM   #9
gc835
Member#: 78080
2001 impreza
red biatch
an aftermarket one made for a wrx
Old 10-04-2005, 12:40 PM   #10
Natoe
Member#: 90353
idont think its worth the effort unless you get a custom 3" catback too.... if you do that then ya, go ahead with the downpipe
Old 10-04-2005, 10:01 PM   #11
gc835
Member#: 78080
2001 impreza
red biatch
why not just use an after market wrx dp and an oem wrx catback. would this work?
Old 10-06-2005, 05:46 PM   #12
dscoobydoo
Member#: 57152
---- Subaru fleet
garage ( 5 and counting)
OK, seems that you are missing the point. STOCK, the legacy exhaust is several inches longer that the WRX one. If you go with the WRX downpipe, you will have to modify the rest of the Legacy exhaust to match up. My suggestion: put the downpipe on, and then have the rest of the exhaust custom made to match the 3 inch downpipe. That way you have a full 3 inch exhaust that fits your car.
dscoobydoo is offline   Reply With Quote
Old 10-06-2005, 06:02 PM   #13
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
http://bbs.legacycentral.org/viewtop...ighlight=turbo
Here, this should make it easy for you. That's a write up of my installation of a PDM divorced wastegate downpipe on my '94 Legacy touring wagon...
Old 10-29-2005, 03:33 PM   #14
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
Subaru Stars
Yep,..........Can't argue with that one...HA!
Think of it like pouring water into a bucket with a REALLY big funnel, No matter HOW BIG the Funnel is, it is only as efficient as the smallest restriction in it?!?! (Weakest link in the chain and all that..........)
YES, it will get you some spiked/peaked figures low in rpm due to back pressure, (just like an N/A Eng works on B/P, so too does a S or T/Charged car befor eit starts to create it's own boost/inertia/momentum), but once the pressure equalises, there is a HUGE restriction at the "Cat".
Cheers,
Sixpack Subaru
sixpack subaru is offline   Reply With Quote
Old 10-29-2005, 11:11 PM   #15
THAWA
Member#: 44581
3 Boxers 2 AWD
Sixpack Subaru
Backpressure is the enemy of ANY engine, it is never good to have.
Old 10-30-2005, 01:22 AM   #16
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
2005 Chrysler Town & ****
Try again.
Old 10-30-2005, 01:34 AM   #17
THAWA
Member#: 44581
3 Boxers 2 AWD
Try what again? Backpressure IS bad, exhaust velocity is good. In the real world in order to have a good amount of exhaust velocity there is a certain amount of backpressure that develops. That doesn't make backpressure good. If I'm wrong, you're more than welcome to correct me, or at least explain why backpressure is good.
Will stock 04 wrx dp fit stock 05 Aero? Nick's 92x Newbies & FAQs 9 05-16-2007 02:01 PM
03 WRX 2.0 into 94 legacy wagon RHD HellBinder Subaru Conversions 24 01-14-2007 07:46 PM
Will 02 stock WRX DP fit 04 STi? 02BlueSuperRoo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-13-2006 01:04 PM
will impreza (GC/GD) wheels fit a 94 legacy? BLk_WGN Legacy Forum 5 01-07-2003 02:53 PM
Will the twin turbo EJ20 fit 91-94 Legacy turbo? jwooman Legacy Forum 5 05-02-2001 01:26 AM
