Canada Region Club
Go Back   NASIOC > NASIOC Regional Areas > Canada Region Forum
Old 08-25-2001, 03:30 AM   #1
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Talking 13.7 in the quarter mile!!!
WOO HOO,
I just pulled a 13.758 at the track tonight!!!!
these are the details...
r/t .688
60' 2.061
330 5.820
1/8 8.875
1000 11.521
1/4 13.758
Mph 98.66
WOO previously i was having problems with my launches and doing low 14's but... when i finally got a good launch... 13.7 hehehehehe
Tulit where were you guys, where you guys there? the AAWDC
hey thanks for coming out inpreza kid...
sadly i couldn't go with the Typhoon guy... he was fast 13.8...
Hok
HOK is offline   Reply With Quote
Old 08-25-2001, 04:49 AM   #2
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Thumbs up
WOW! That's some pretty good numbers. What kind of turbo kit are you running? JCSports, Minnam, other?
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 08-25-2001, 10:00 AM   #3
tulit
Member#: 338
09 STi
Hi guys. Sorry I didn't make it.
But thats an impressive result HOK. Good job!
tulit is offline   Reply With Quote
Old 08-25-2001, 02:05 PM   #4
inpreza kid
Member#: 3334
Talking
i had a good time out there and got to see hok's car in action. wow. this car is very fast. if hok decides to go for a couple more runs i suggest anyone to go down there and watch.
inpreza kid is offline   Reply With Quote
Old 08-25-2001, 02:12 PM   #5
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Penphoe - HOK is running a Gen 1 JCS kit, but the turbo is a T28/T3 with a special impeller grind.
In the next week we'll be installing some more engine manganment to increase the revs to 7000rpm as well as mapping a new ignition map. That way, HOK won't have to shift into 5th right before the end of the 1/4 mile as well as increase more low end response. These changes may possilbly push the car into either the high 12's or low 13's. (Remember, HOK ran an uncorrected time of 13.7s)
Remember, up here in Calgary we're 3500ft above sea-level (or 0.663 miles above or 1061m above)
GTBGUY is offline   Reply With Quote
Old 08-25-2001, 02:24 PM   #6
tulit
Member#: 338
09 STi
GTB, that sounds good.
But remember, altitude corrections don't apply the same to turbo charged cars. Turbos are based on differences in ambient pressure, and thus automatically compenstate for much of the altitude change.
Old 08-25-2001, 02:58 PM   #7
GTBGUY
Member#: 2003
'99 BGP Legacy GT
tulit - Yes you're partially right, Force-induced cars aren't as heavily affected as N/A cars at alititude, but they're still affected by thinner air etc.
There are many factors when you're at altitude. You have to remember, this was done on 1/2 tank of 92 Octane gas + 1/2 bottle of STP octane booster (which I think didn't do too much at all).
Old 08-25-2001, 08:19 PM   #8
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
Good times HOK.....
With a bit more practice, you times should lower...... since you should improve your 60 times.....
With a turbo kit, you should be getting 1.8sec or a bit faster.....
Keep posting the info......
Robin
www.ottawasubaru.com
Robin2 is offline   Reply With Quote
Old 08-25-2001, 09:30 PM   #9
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Yeah... I thought this as well.. but this thing is that the EJ22T has less low end torque... it feels dramatically different to my inaccurate butt dyno...
Since the 2.5 has gobs of low end I believe this is what made really good 60 ‘ times… I was also trying to be a little easy on the tranny… so.. I was slipping and wasn’t doing a really good job of it… I was happy with 13.7 so its ok… If you tell me that I can get better times with my current setup… then I’m happy hehehehe
But hopefully we can get 12’s in a year or so,. At this elevation. But I’m really antsy about the tranny… no money..
Hok
Old 08-26-2001, 11:35 AM   #10
markus
Member#: 438
2004 STi
White on Gold
Most of Calgary is around the 3000ft mark. Is the track really 500' higher? Were you racing west of Calgary? Curious.
markus is offline   Reply With Quote
Old 08-26-2001, 12:43 PM   #11
GTBGUY
Member#: 2003
'99 BGP Legacy GT
markus - Actually, elevation gets higher than 3500ft as you move west. 3500ft above sealevel is measured @ city centre. This was taken straight out of tourism guide.
Old 08-27-2001, 12:37 AM   #12
markus
Member#: 438
2004 STi
White on Gold
Jack,
No offense to the Tourism Guide, but it's dead wrong. I've done enough surveying/engineering work to know that Calgary City centre is almost bang on to 3000'
Anyways, we're getting way off topic. 13.7 is awesome!!!! HOK just needs to improve that 60' time and you'll likely shave another 3/10ths off the 1/4.
Cheers,
MB
Old 08-27-2001, 09:56 AM   #13
RageHardIntoTheBendies
Member#: 1532
1999 RS, Silverthorn
www.zucru.com
Great time man!
Are you running the stock EJ22 block?
What kind of EMS are you going with?
I really hope you hit the 12's some day my car will be there too!
RageHardIntoTheBendies is offline   Reply With Quote
Old 08-27-2001, 11:24 AM   #14
GTBGUY
Member#: 2003
'99 BGP Legacy GT
markus - That's quite interesting, I guess it's time to write to the editor of the publication. IIRC, Calgary's elevation increases from E->W, lowest point being downtown.
RageHardIntoTheBendies - HOK is running the EJ22T w/ EJ25 SOHC heads and 440cc RC injectors. As for engine management, running the stock ECU, SAFC, TC2 (was). We're taking out the SAFC in favor of the Unichip.
We'll be eventually using the Unichip to bump the rev limit 8-12% somewhere in there, we'll be able to break into the low 13's and high 12's with alot more ease. Everytime HOK get's very close to end of the 1/4", he must shift into 5th to avoid hitting the limter. In fact, he's actually hitting the limiter in every gear, hence he's only shifting at 5500rpm to get the 13.7 run.
If he can practice launching faster (keep in mind that he's trying to baby the tranny till he has more funds), lowering the 60' times should yield a run of 13.4-13.5s. With the higher rev limit, doing high 12's shouldn't be out of the question.
[edit for typo]
Old 08-27-2001, 11:32 AM   #15
Member#: 1532
www.zucru.com
Great thanks, very interested to hear how the Unichip works on an RS, don't think I've seen that done before, if it works well I may reconsider my additional Injector plans, mmmm
Great stuff guys, keep up the good work!
Old 08-27-2001, 12:01 PM   #16
GTBGUY
Member#: 2003
'99 BGP Legacy GT
RageHardIntoTheBendies - Yup, no probs, we'll be keeping everyone posted. First of all, we have to "un-install" the SAFC and TC2. We got the harness in for the Unichip this weekend, but won't be able to do anymore until next week, as HOK won't be in town.
Anyways, several main advantage of the Unichip over the TEC2 exists : The biggest being cost. (about $9XXUSD for the ECU w/ boost and rpm modules)
Another good thing is that you can adapt up to 440CC RC injectors on your stock fuel rails and FPR, and use the Unichip to control them. There's still 2 channels on the Unichip that allows for the use of an addition 4 injectors to be driven (ie, you can use your stock injectors again on the intake tract somewhere to produce a total of 2880CC/min (at full static), equivalent to runing (4) 720CC injectors. Of course you'd only want to run at 80% duty cycle which is equal to a max of 576cc/min. vs: the 550CC upgrade that Shiv has, this is way more economical. (the 550's running @ 80% duty cycle is equal to 440's).
However, one big benefit to Shiv's set-up is the fuel rail, which distributes fuel more evenly vs. the stock rails.
In the case of referencing the amount of air going into the engine, the MAF units are alot more accurate vs. MAP systems. This is outlined in many cases (you can check some back issues of SCC, they have the explaination there as well). The Unichip allows you to retain the more accurate MAF. Ofcourse, depending on which turbo-kit you go with will determine the longevity of your MAF unit.
In anycase, this is going to be an interesting experiment.
Old 08-27-2001, 12:21 PM   #17
Member#: 1532
www.zucru.com
So the unichip allows additional injectors also? wow that sounds awesome!!! can you run low impedence injectors on the additional channels?
This is very intersting.
Old 08-27-2001, 12:39 PM   #18
GTBGUY
Member#: 2003
'99 BGP Legacy GT
RageHardIntoTheBendies - I'll have to check on that... not to sure at this point, but it will drive extra injectors. If memory serves me correctly, it drives up to 8. But most likely only 4.
Old 08-28-2001, 01:11 AM   #19
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Question
ummm... the TC2 is not in my car... GTBGUY??!??!?!!? What the ****?????
Hok
Old 08-28-2001, 01:25 AM   #20
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Yes... i was think about putting in the Unichip... but it seems a little too difficult without some help from APS or cobb... cause I guess thats why Cobb didn't want to give people plug and play harnesses. go figure... but the car works fine now... and no det.. so... I'm still considering. If I can get better launches or i get more horsepower I will need to spend more on a new Tranny!!! maybe... so i'm at a Catch22 get more horsepower=need to spend more money on tranny.,.,. booooooo
Hok
Old 08-29-2001, 11:47 PM   #21
Rick Hunter
Member#: 825
2002 wrx
Guys, please tell me more about the Unichip.
Could i make it work with my MY00 EJ25 turbo setup?
Right now I'm running the basic 5-6 psi piggy back setup being zener diode, RRFPR, wrx fuel pump, TMC1 boost sensitive retard timing controller. I've got it all dialed in quite rich and am retarding quite a bit, which is safe. Though, for more power, I definately want to go to the Tec-II or some similar engine management system. So.. would the Unichip work?
Rick Hunter is offline   Reply With Quote
Old 08-30-2001, 09:48 AM   #22
Member#: 1532
www.zucru.com
Rick Hunter: The unichip sounds like a good match for your setup, it will allow you to run larger injectors and raise the rev limit if want too. I would be confident running up to 10 - 12psi on a unichip, after that a TECII would probabley be a good idea as it has the multi toothed wheel/sensor for finer control etc.
I know cobb is also looking at this.
Old 08-30-2001, 10:59 AM   #23
GTBGUY
Member#: 2003
'99 BGP Legacy GT
Rick Hunter - With the Unichip and also their boost module, you can use their 2bar or 3 bar map sensor to over come the "diode" problem.
RageHardIntoTheBendies - On the stock EJ25, it's not recommend to rev anymore past 6500rpm with that kind of boost level, as you will throw a rod. With the EJ22T, you can rev all the way to 7250rpm's but the stock EJ25 heads (SOHC) are only good for 7200rpms safely until they start having valve float and irratic operation.
Innovative Tuning Subaru goes 6.6 1/8 and 10.4 in the quarter mile Innovative Tuning Proven Power Bragging 83 12-26-2007 10:44 AM
Which car would win in the quarter mile? atomic4877 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 10-03-2007 08:58 PM
Z06 vs Festiva in the quarter mile street racing in school zones... The Tree Off-Topic 4 10-29-2005 05:51 PM
The quickest manual Impreza in the world on the quarter mile Ice555 Proven Power Bragging 55 08-23-2005 02:49 PM
