Old 10-04-2005, 12:00 AM   #1
MattSTi
Member#: 54885
2004 PSM STi
2006 Mazda MX-5 Race Car
Default My Setup for Logging/Displaying EGT's with UTEC/Tuna
I have a Turboxs UTEC and Tuner Pro and I wanted to be able to both log my EGT's as well as see them on a gauge.
So, I bought the DTEC EGT probe that turboxs sells, did the usual drilling and tapping of the manifold to install the probe. I also bought one of the z-series autometer pyrometer gauges that runs off a straight k-type thermocouple signal, and tapped this into the probe wires BEFORE the turboxs signal conditioner (little grey box).
The setup has been working flawlessy and is relatively cost effective if you already have the tuner.
Just wanted to share that with the community to let everyone know it can be done and works well.
-Matt
MattSTi is offline   Reply With Quote
Old 10-04-2005, 09:20 AM   #2
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
matt, what do you use to concatenate the tuner's output stream to the utecs?
Old 10-04-2005, 10:02 AM   #3
StiDreams
Member#: 26315
07 Outback
Silver/Silver
Probably nothing. You can hook the UTEC to the TUNA and take the output of the TUNA into the laptop. The TUNA will put the WB data in the last column of log1 of the UTEC.
StiDreams is offline   Reply With Quote
Old 10-04-2005, 10:06 AM   #4
StiDreams
Member#: 26315
07 Outback
Silver/Silver
ride5000,
Oops my bad, I understand what you're talking about now.
Matt, how do you get the EGT data in with log 1 info?
Old 10-04-2005, 10:15 AM   #5
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
maybe i should have been more clear...
i HAVE a utec, and a tuner pro, and have been using them both together for the past year and half.
i was wondering if he had been successful with using a product like jmussetter's mps logmapper.. http://forums.nasioc.com/forums/showthread.php?t=781783 that can take two data streams from two com ports and merge them together. this would allow logging of ALL of the utec and tuner pro data.
ken
Old 10-04-2005, 10:18 AM   #6
StiDreams
Member#: 26315
07 Outback
Silver/Silver
It would be better if TurboXS would just provide some more firmware upgrade to allow the TUNA to merge the WB data and one of the spare inputs on the PRO to the log1. I would gladly pay them for the firmware upgrade + EGT probe.
Old 10-04-2005, 10:26 AM   #7
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
i absolutely agree that some flexibility in the logger options would be a very nice option!
the trick is getting txs to do it..
Old 10-04-2005, 12:29 PM   #8
MattSTi
Member#: 54885
2004 PSM STi
The most recent firmware for the sti (1.1c I think) has allows you to log the Tuner's analog inputs, I believe it is logger number 6.
Hopefully they will integrate the analog inputs (at least one) into logger 1.
I have tried using the MPS Logmapper but since I only have one serial input I'm not sure how I would use it.
Since the MPS logmapper is made for integrating other WB's with utec, it has no provision for merging the data from the daisy-chained utec and tuner setup. I'm not a programmer so I don't know how hard it would be to change this, but it would def. help a lot.
-Matt
Old 10-04-2005, 03:31 PM   #9
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
He said cat
former unix guy --> n2xlr8n
Good thread.
S.
n2xlr8n is offline   Reply With Quote
Want to swap my setup for coilovers jaredperry Private 'Wanted' Classifieds 4 06-23-2010 05:51 AM
logging a/f with utec? spoolinred UTEC 9 12-13-2009 02:01 PM
Logging EGT's with utec / tuner pro? AaronWRX Engine Management & Tuning 8 06-06-2005 07:22 PM
my setup for five guages Zornorph Member's Car Gallery 5 08-16-2003 12:40 AM
calibrating for correct PSI readings with UTEC. - help ndw1138 Engine Management & Tuning 1 04-06-2003 01:29 AM
