Old 08-25-2001, 05:40 AM   #1
moyama
Member#: 8802
91 AWD Legacy Wgn
Question 91 legacy = erratic idle
anyone have a fix for this?
idle runs around 1K, then nearly dies. this repeats a few cycles when the engine is cold...doesn't happen when the car is warmed up.
more info:
-recent plugs
-new oem plug wires
-new PCV valve
-91 legacy wgn, NON-turbo
moyama is offline   Reply With Quote
Old 08-25-2001, 04:29 PM   #2
Mike2000GT
Member#: 2709
2006 WRX Wagon
SGM
This has been covered (sort of) in a number of threads. Perform a search to make sure the topic you are posting hasnt been covered before.
Try resetting the ECU. (Unplug the battery for ~30 mins, reattach, start car up, without touching the gas, letting the car warm up, without touching the gas. While its warming up, you will have time to reset the clock and radio stations. After the car is warm, turn the car off. Restart the engine and go do some spirited driving (if thats your style).)
Thats about as far as I got with the problem I had with my 91. New plugs and wires and then an ECU reset helped, but did not totally cure the problem.
FYI,
Mike2000GT
Mike2000GT is offline   Reply With Quote
Old 08-26-2001, 12:02 AM   #3
iceman
Member#: 1546
95 Legacy L
Sounds like an EGR valve to me...
iceman is offline   Reply With Quote
Erratic idle @..... idle. SilverBullet2.5RS Normally Aspirated Powertrain 7 06-24-2006 03:07 AM
Erratic Idling GM02WRX Warranty Issues & SOA Problems 4 03-30-2002 01:54 AM
Erratic Idle?? minx Service & Maintenance 3 01-02-2002 10:23 PM
Erratic Idling?....? wrx182 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-15-2001 04:00 PM
Erratic idle when cold Peaty Normally Aspirated Powertrain 3 05-21-2001 08:41 PM
