Old 10-05-2005, 02:21 AM   #1
druxboyz
Member#: 16827
2003 WRX(Sold), Z4
Default Anybody elses brake light turn on when driving?
well, my e-brake light turns on when i drive in the mornings and at night only. (yes, my e-brake is down). during the day, it doesnt turn on at all. it seems to be a loose wire or something.
when i brake fast, it turns off.
when i speed up/shift gears, it turns back on until i brake hard.
so, it seems there's some sort of pendulum type of receptor somewhere to make this light go off in this fashion. any tips on where i should look or what this thing looks like? anybody else have this problem? i did a search and found nothing.
druxboyz is offline   Reply With Quote
Old 10-05-2005, 02:47 AM   #2
2phless
Member#: 69343
1998 TransAm cnvrtbl
The pendulum is probably fluid. Check the level. One of the big yellow caps under the hood.
2phless is offline   Reply With Quote
Old 10-05-2005, 03:17 AM   #3
Roostar
Member#: 97512
no
not here
Roostar is offline   Reply With Quote
Old 10-05-2005, 09:08 AM   #4
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
add brake fluid.
depending on how old it is, you might want to flush.
also check pads to see if they are worn. brake fluid really doesn't leak so if fluid is low, pads are likely worn.
Old 10-05-2005, 12:27 PM   #5
jskho
Member#: 11864
I had the same problem. My brake fluid looks normal. It turns out my brake pad was pretty worn out. I changed out all 4 pads and brake light never came on again. How many miles you have on your car?
jskho is offline   Reply With Quote
Dash, hvac, and corner lights turn on when brakes are pressed 08sniper Electrical & Lighting 1 09-21-2009 05:06 AM
hand brake light comes on when driving need help!!! pjung1 Service & Maintenance 5 09-20-2008 12:07 PM
brake light comes on when i turn? Keif Service & Maintenance 2 09-24-2006 08:45 PM
E-brake light flickering on when brake is off McBain_TP Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-17-2005 10:19 PM
E-Brake light coming on when regular braking? Dolphin Overton Brakes, Steering & Suspension 5 12-10-2002 12:56 PM
