Old 10-05-2005, 04:06 PM   #1
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
Default Gear [back]lashing? gear whine.... info please
hey i noticed it coming home from busch gardens (amusement park) that my transmission is now whining whenever i'm:
~on the throttle
~coasting out of gear
but not when:
engine braking/decelerating in gear
its not a high pitched whining but it is rather loud. its speed dependant so when i slow down, the intervals of the noise decrease to a drone then stops when the vehicle is not moving.
anyone can shed any light on this?
its most noticable when i am driving normal but say, switch into the next gear early, putting a bit more load on the engine/trans. and continues to get higher pitched the faster i go/the more gears i run through.
is it something CV related? or is my diff busted?
it drives fine and shifts nicely thanks to Uncle Scotty's cocktail; but i dont think the fluid did it in. (Because there would have been extensive damage to the trans beforehand and the cocktail actually made the shifting so much better and solved all grinding problems.)
please point me to some links, i tried searching however the topics i read dont seem to be 100% related.
i just want to know if i need to start saving for a rebuild, or replacement tranny
thanks for your input in advance.
psyber_0ptix is offline   Reply With Quote
Old 10-05-2005, 04:11 PM   #2
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
I would say R&P or diff. being that it happens when you push the clutch in. I have the RA gears and they whine, but quit when you push the clutch. Mine also changes sound based on what gear I am in.
Kevin
Crazykev is offline   Reply With Quote
Old 10-05-2005, 04:22 PM   #3
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
sorry edited
its when i'm not in gear...
clutch in or out, if i'm not in gear it whines
Old 10-07-2005, 12:42 AM   #4
psyber_0ptix
Member#: 60671
1992 Turbo Miata
351whp/344tq
bump.
Old 10-07-2005, 11:32 AM   #5
jalow72
Member#: 64293
I am surrounded
by land manatees!
Sorry, didn't see your edit. Never mind.
jalow72 is offline   Reply With Quote
PPG and 3rd gear using 4th gear syncro problem. Trans guru help please!!! hybrid gti 2 Transmission (AT/MT) & Driveline 24 02-07-2008 08:58 PM
My gear oil odyssey. (non tech info inside) chrisfranklin Transmission (AT/MT) & Driveline 7 05-27-2005 06:05 AM
alternator whine help please at the end of my rope! spdracr00 Car Audio, Video & Security 6 10-07-2004 02:05 AM
Need help re. gear grinding since trans./diff. fluid change, info please! Longitude Southern California Impreza Club Forum -- SCIC 9 08-09-2004 06:21 PM
Gear Set and RPM/MPH Info Quick Time Proven Power Bragging 9 03-11-2004 03:52 PM
