Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 10-05-2005, 06:38 PM   #1
psyber_0ptix
Member#: 60671
1992 Miata
Default 04 projector Retrofit and public apology to Trail*of*dead
I hope he doesnt kill me posting this, but heres a retrofit for trail*of*dead's sti
he sent me these lights long long ago (janurary) and i've been extremely lazy and hadnt finished them until now. i thank him for his understanding and patience, if i were in his shoes, i'd have fallen off the map long ago. he is an extremely exceptional[spell checked by handsdown] person and is by far a very cool guy. i am really sorry for always procrastinating, and for not being motivated. there are no excuses that will hold water to how poorly i handled this. and i hope he enjoys the lights the best he can, although to me it probably wasnt worth the time waiting for.
so to trail*of*dead, this ones for you
i just finished aligning them and sealing the projector.
hopefully there will be some better pictures when he gets them installed on his car
Specs:
04 wrx headlights (no auto level motors would work with the size of this projector.this projector
2x phillips OEM d2s bulbs 4100k
the best and only temp one should use. (4100-4300k)
Hella e55 projectors
these are extremely large and are a pain in the butt hole to get into a housing. the selenoid sits diagonally so its not level and i had to cut the bottom of the housing out a bit. but because they are bi-xenon, when a current passes through the selenoid (high beam trigger) the cutoff shield drops down expelling more light. so not only does he have his stock halogen high beam, but an HID one as well
and a special thanks to my buddy sean at hidtech.com for being my supplier through and through.
But most importantly, thanks to Tommy[Vudoo7] and [SJF01] for letting me use their garage, car, space, bulbs, ballasts, and dremel to aim set and complete these headlights. It wouldnt have been done without their help.
thanks for looking
~Payam Fahr
psyber_0ptix is offline   Reply With Quote
Old 10-05-2005, 06:44 PM   #2
Synic Motorsports
Vendor
Member#: 96179
1996 Ver.7 Brighton
03 DC5-T
looking good, doing any for the gc headlights?
Synic Motorsports is offline   Reply With Quote
Old 10-05-2005, 06:49 PM   #3
subyrally
Member#: 52662
2009 dgm WRX hatch
86 & 87 rx, 1985 brat
odd, i usually have no problem seeing pics, i only see red x's
subyrally is offline   Reply With Quote
Old 10-05-2005, 06:50 PM   #4
psyber_0ptix
Member#: 60671
1992 Miata
unfortunately i have never had my hands on a set of gc headlights, it appears though it is an extremely small housing and may be difficult to fit a bi-xenon projector in (to retain the high beams)
maybe with an e46 projector. but i havnet tried yet.
those headlights are hard to find
Old 10-05-2005, 07:18 PM   #5
psyber_0ptix
Member#: 60671
1992 Miata
mess with browser settings?
Old 10-05-2005, 10:11 PM   #6
psyber_0ptix
Member#: 60671
1992 Miata
remove all auxiliary screws, clips, unneccisary plastics from the headlight
preheat the oven to 250
bake headlight in middle rack for 7 minutes
seperate lens and housing
after taking the trim off the lens, clear them by collapsing the obvious tabs from behind
*AFTER TAKING THE TURN SIGAL/INDICATOR PIECE OUT*(3 screws)
take notice of the little ball join in the center of the housing.
pop it loose with a long screwdriver (or anything with good leverage)
Old 10-05-2005, 10:54 PM   #7
DeKaP
Member#: 90627
2005 Impreza WRX
Obsidian Black Pearl
how much he pay you to do that?
DeKaP is offline   Reply With Quote
Old 10-05-2005, 10:58 PM   #8
garie
Member#: 26607
2002 wrx wagon
nice work...looks very labor intensive but the final product looks very very clean.
garie is offline   Reply With Quote
Old 10-05-2005, 11:04 PM   #9
psyber_0ptix
Member#: 60671
1992 Miata
i'm reorganizing the pictures.... please hold
confidential
Old 10-05-2005, 11:11 PM   #10
psyber_0ptix
Member#: 60671
1992 Miata
loosen adjustment screws
*BE CAREFUL NOT TO LOSE ANYTHING WHEN YOU SEPERATE THE HOUSING*
There is a small black plastic thingy that is not secured in the housing, and can easily fall out. It is very important and used in alignment of the headlight ( it acts as the nut for the alignment screw).
pause for a break, organize
tape off the highbeam reflector, and start taking material out
hole
Old 10-05-2005, 11:12 PM   #11
psyber_0ptix
Member#: 60671
1992 Miata
pic's of the process:
everything torn apart
cut a hole out the back and drill the 4 holes for mounting the projector
test fit the projector
test fit the trim ring
voila
testing 1-2-3
BAM! /emeril voice
Old 10-05-2005, 11:13 PM   #12
psyber_0ptix
Member#: 60671
1992 Miata
afterward, i just took everything out, and bolted the projector housing in, trimmed the excess stud off the back.
JB welded the screws and the space between the housing and projector to seal it tight.
adjusted, reassembled and routed the high beam selenoid wires.
Old 10-05-2005, 11:14 PM   #13
psyber_0ptix
Member#: 60671
1992 Miata
the cutoff from head on
some of the line
low res of the low beams [KanosWRX] (it appears misaligned but its just the light is so saturated in the picture its hard to see how sharp the cutoff really is)
and finally highbeams
Old 10-05-2005, 11:16 PM   #14
psyber_0ptix
Member#: 60671
1992 Miata
updated thread, rearranged pictures
Old 10-06-2005, 12:01 AM   #15
scoogan
Member#: 85673
Nice work!
scoogan is offline   Reply With Quote
Old 10-06-2005, 12:07 AM   #16
vwown3d
Member#: 69991
Leh Keen
Approved
im not seeing pics but i think my comp's messed up.
vwown3d is offline   Reply With Quote
Old 10-06-2005, 01:04 AM   #17
WShade
Member#: 74339
Me either..........
WShade is offline   Reply With Quote
Old 10-06-2005, 02:52 AM   #18
psyber_0ptix
Member#: 60671
1992 Miata
i dunno, i'm linking it off photobucket
Old 10-06-2005, 03:00 AM   #19
JDM 3SGTE
Member#: 35479
very nice. do you plan on doing this for other people? i live in the dcmetro area, and would be very interested. what materials did you need besides the projector and ballasts?
JDM 3SGTE is offline   Reply With Quote
Old 10-06-2005, 03:13 AM   #20
psyber_0ptix
Member#: 60671
1992 Miata
Supplies:
Spare headlights, Projectors, ballasts, bulbs, screws, nuts, washers, jb-weld, black studio tape, wire, soldering iron/solder, screwdrivers, pliers, patience, time and lots of drinks
Old 10-06-2005, 03:15 AM   #21
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
Originally Posted by psyber_0ptix
he is an extremely acceptional person and is by far a very cool guy.
okay the pictures loaded for me and that is way badass. looks better than any of the other retrofits i've seen so far.
Handsdown is offline   Reply With Quote
Old 10-06-2005, 03:21 AM   #22
psyber_0ptix
Member#: 60671
1992 Miata
obviously you havent seen Myles:RaceCompEngineering's then?
identical
i think this is the last time i will work with e55 projectors. they are just damned difficult.
i'll try a smaller projector next time
Old 10-06-2005, 03:26 AM   #23
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
i've seen myles... these look bigger than his, but maybe i'm just not remembering correctly.
go smaller and we'll see how it turns out, but i like the large projector.
and for future reference- not trying to hate or anything, but- it's exceptional, not acceptional
Old 10-06-2005, 03:30 AM   #24
psyber_0ptix
Member#: 60671
1992 Miata
yea, i used the same exact projectors for myles.
its just i dont have any shots while its on the car, so its hard to reference i guess.
they are effing bright though when highbeams are lit up.
oh yea, i cant forget myles reaction....
"DAMN they are bright. 'It's like god came into the room and caught you f*cking."
myles is a great guy to, easy to talk to. one of the very good people i had the chance to meet.
Old 10-06-2005, 03:31 AM   #25
psyber_0ptix
Member#: 60671
1992 Miata
hahaha i was horrible in english class. sorry thanks for pointing it out
edited for your reading pleasure.
I felt I needed to publicly apologize to StriderTB as well Neek Off-Topic 21 06-03-2010 03:16 PM
This is my public apology to StriderTB. I25 Off-Topic 62 06-03-2010 09:07 AM
MI: Xceedspeed BBQ Pics (100+ pics 56k beware) sizzflair Member's Car Gallery 57 09-14-2006 07:22 PM
Public apology to DYNO-COMP AND RICH FAST CO STi Proven Power Bragging 6 08-19-2004 03:04 AM
Finally updated my system pics (lots of pics 56k beware) Jakezor Car Audio, Video & Security 29 05-16-2004 07:24 PM
