Old 10-06-2005, 01:46 PM   #1
Brian Broz
Member#: 13783
2008 2.5i Slow
Default 1st step to make my ride more comfortable?
Hi,
I have an 03WRX w/Whiteline flatout springs, Whiteline thick Front and Rear Swaybars (rear w/endlinks) STi Struts and Group N tops and engine/tranny bushings and Whiteline ALK. Oh also I have f+R strut tower bars as well.
The ride around the rough bumps and uneven concrete in the city is getting to be too jarring for me. I live in the city with lots of really uneven/cracked roads...I really feel the paint on the road at crosswalks (now that it's colder)! I'm looking to get a little more comfortable ride...not stock but not bone jarring.
Would the first step to be: swap back to a stock front swaybar maybe then softer springs?
Looking for any suggestions from anyone who switches from a track to street setup or has ridden in different WRXs.
Thanks for any suggestions.
BBroz
Brian Broz is offline   Reply With Quote
Old 10-06-2005, 02:18 PM   #2
SUPAREX
Member#: 28278
02 WRX
Platinum
I would get Koni inserts and get rid of the STI struts for a better ride.
SUPAREX is offline   Reply With Quote
Old 10-06-2005, 03:06 PM   #3
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
Different springs may help. What is the drop and springrate on those Whiteline springs? If those are the super low version that could be a problem.
The swaybars won't contribute too much to any ride quality problems.
Koni Inserts and different springs would be a good solution, but you could probably work with your STi struts. are they V7 or V8?
- andrew
AndyRoo is offline   Reply With Quote
Old 10-06-2005, 03:36 PM   #4
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
A couple of things, springs are Whiteline's aesthetic tuner springs, they made those as a concession to the folks who demand that super low look. However, they are too low and too soft. The Sti struts work much better with stiffer springs. However, if you have V7's you are kind out of luck. No real spring options there unless you are willing to do the washer trick and move up to 04+ springs like STi JDM Pinks or STi Prodrives and Group N tophats. Or as the others have suggested, go to Koni inserts and a higher spring like the Prodrives. you will be amazed at the difference.
Here's a good thread for you: http://forums.nasioc.com/forums/showthread.php?t=826926
Arnie is offline   Reply With Quote
Old 10-06-2005, 03:57 PM   #5
Brian Broz
Member#: 13783
2008 2.5i Slow
Hi Arnie,
Thanks...these are the Flatout springs. I've heard they are very soft in their springrate but they sure "feel" stiff.
My struts are the V8 of a USDM sti. My car is an 03..so my springs are 03 but I can't remember if my groupN tophats are for an 03 or 04?!
Anyways, thanks for the info.
I've been debating the prodrives vs. Sti springs with my setup. I still want to have a lower ride height than stock, but not prepared to switch out struts.
Brian
Old 10-06-2005, 07:56 PM   #6
Funky
Member#: 11520
2005 STi (retired)
Obsidian Black
Tires with really soft sidewalls...
Funky is offline   Reply With Quote
Old 10-06-2005, 09:16 PM   #7
redwagon
Member#: 2181
2008 SpecB
A conventional strut would be much more compliant over small surface irregularities, even if the overall damping rates were similar. Even on the same springs the car will feel so much more compliant with the Konis or AGX struts on it. I know you probably don't want to hear this, but you'll be hard pressed to get a better low speed ride quality out of those struts even if you change springs. Arnie is right on the money about the Flatout springs, they're too low for the Impreza and not hard enough for that height. The sport springs are much better.
Option 1: Get new struts.
Option 2: Drive faster.
Option 3: Softer tires (aka undamped suspension)
BTW... soon your interior will start making noise and once it does, even going back to stock suspension won't cure it.
redwagon is offline   Reply With Quote
Suspension that will ride more comfortable than stock! GoneSingle Brakes, Steering & Suspension 10 06-02-2010 12:28 PM
How can I make my futon more comfortable? Briman2021 Off-Topic 23 09-22-2005 06:41 PM
Does removing anti-sway bars make my car more comfortable? Dealer Xing Tri-State Area Forum 21 11-14-2004 08:13 PM
Make stock seats more comfortable??? rexxer Interior & Exterior Modification 2 08-22-2003 04:31 PM
What can I do to make my car more secure? BeavisNuke Car Audio, Video & Security 18 06-06-2002 09:23 AM
