Old 10-06-2005, 02:10 PM   #1
scoogan
Member#: 85673
Default Sti vs Wrx headlights
Everyone says you could not put a HID kit into a factory Halogen headlight but while my buddy and I were cleaning our cars, I took notice to each of our headlights (His being the STI) and I could not tell a difference at all in the housing itself. Yes the bulb was different but the housings look identical. Is this to say you could get away with a name brand HID kit like Phillips and it wouldn't cause light glare all over the place? I'm just trying to verify what it is that makes the housings so different.
scoogan is offline   Reply With Quote
Old 10-06-2005, 02:54 PM   #2
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
They may look the same to the naked eye, but there are indeed differences between the STI HID reflector housings compared the WRX ones. The reflecting points are setup to where the DSR bulbs won't emit light everywhere. And yes, there will be glare issues if you just stuck in an HID kit in the WRX lights. You would have to aim them lower to not blind oncoming traffic, which would then mean less light output on the road.
Hank3 is offline   Reply With Quote
Old 10-06-2005, 06:51 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
They are not the same, and you can see the difference with the naked eye. The reflector segments are not the same size- look closer.
Old 10-06-2005, 08:48 PM   #4
leonbmx
Member#: 82864
2005 MPS Wagon HTA35
Domtuned Stage $$$$$
I've recently installed JDM 05 STI HIDS. Obviously, because they drive on the other side over there, the beam pattern is facing to the wrong side of the road (left vs. right).
Is there any way to fix this, either by buying USDM reflector housings, or maybe there's a way to "tweak" the beam pattern sideways?
leonbmx is offline   Reply With Quote
Old 10-06-2005, 10:10 PM   #5
Handsdown
Member#: 29355
not without tweaking the reflector housings. with a projector you could just dremel out the cutoff so it was sloped the other way, but with reflectors they don't really change.
back to the original dillemma, they are indeed different and you can tell that by looking at the positioning of the bulb in the housing. if you want to try it, it would be interesting to get a picture of both hid housings and halogen housings with the same HID kit, lighting up the same wall...
Handsdown is offline   Reply With Quote
EVO vs. STi vs. WRX juanmedina General Community 8 11-27-2006 01:12 PM
STI vs. WRX headlight wiring harness nateelyles Newbies & FAQs 2 11-12-2006 05:06 PM
WTB: 2004 STI or WRX headlights, 2004 STI foglight Covers STEALTH-WRX Private 'Wanted' Classifieds 0 04-17-2004 01:53 AM
CA: Wanted: 2004 STI or WRX front Bumper, STI or WRX headlights STEALTH-WRX Private 'Wanted' Classifieds 3 04-09-2004 03:54 PM
New highway/backroad video sti vs wrx vs evo vs s4 WS6toWRX Off-Topic 88 02-21-2004 08:38 PM
