Old 10-06-2005, 02:43 PM   #1
WRXINTX
Member#: 96712
Default Strongest aftermarket LSD for R160?
Hello all....
Kaaz LSD don't hold up..... Broke 2 already and now have a welded rear diff that is holding fine, but want to put car back on street..... Is cusco any better???
Thanks!
RYNO
WRXINTX is offline   Reply With Quote
Old 10-06-2005, 02:45 PM   #2
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Buy an R180... You can get custom axles made by the driveshaft shop to mate to your R160 hubs.
I used a Kaaz in a car that made 360 ft-lbs at the wheels last year through many hard launches and it was fine. The Cusco R160 isn't going to be any stronger than the Kaaz.
Old 10-06-2005, 03:09 PM   #3
WRXINTX
Member#: 96712
dang.....
it has had some R180's in the car also, but I think with stock LSD's....
This car makes 600ft-lbs!!!!!
krahzy!!!
thanks!
RYNO
Old 10-06-2005, 05:34 PM   #4
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
So your using a r180 rear dif w/ beefy axles but mated to non r160 hubs. Is this so you wouldn't need to change your brake setup?
DoctorNick is offline   Reply With Quote
Old 10-06-2005, 07:34 PM   #5
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
No I'm using an R160 to save weight.
Old 10-06-2005, 10:14 PM   #6
John Vanos
Member#: 49307
2006 Open Class STI
check out www.rocketrally.com
they have motorsports driveshafts
John Vanos is offline   Reply With Quote
Old 10-07-2005, 12:01 PM   #7
Ace009
Member#: 70353
2004 WRX
I know someone running the Cusco (r160) who beats the hell out of his car and it's holding up fine. He also broke his stock r160.
Ace009 is offline   Reply With Quote
Old 10-07-2005, 12:21 PM   #8
ejh25
Member#: 65267
Originally Posted by WRXINTX
Hello all....
Thanks!
RYNO
What kind of power are you putting out? What kind of racing are you doing? Who installed the Kaaz rear diff?
I've had no problems with my Kaaz 1.5 way and it has taken a fair amount of abuse on a stage 3 (not crazy power but significantly more than stock). If it was installed improperly or wasn't given Kaaz gear oil every 3K miles then it might not be the rear diffs fault. I also use BG fricition modifiers in the rear diff as well. It should hold up just fine if its installed and maintained properly IMHO.
ejh25 is offline   Reply With Quote
Old 10-07-2005, 12:22 PM   #9
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
FWIW, I also broke my stock r160 carrier(from an 01rs). I swaped it out with a 04 wrx carrier and havn't hard a problem yet. A cusco or kaaz would be the way to go if you have the $$$. I am putting down less TQ then you though (only 330)
Old 10-07-2005, 10:16 PM   #10
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
I will find out what the ATS diffs are rated at exactly. They make some pretty stout options. Do you want a 1.5 way or a 2 way?
I'm kind of with DWX on this one though, you can find an r180 pretty cheap for just the diff and then get the axles. Depends on how good you are at shopping around.
Louis
Soon2Bgreat is offline   Reply With Quote
Strongest LSD for R160 spiltheflagon Transmission (AT/MT) & Driveline 21 02-24-2010 10:16 AM
MFactory Plated LSD for R160 Group Buy DS1 Vendor 'Group Buy' Classifieds 99 09-16-2009 11:06 PM
Need Aftermarket Lsd For R160!! cquirki Private 'Wanted' Classifieds 0 06-08-2008 08:47 PM
NIB Cusco 1.5 RS LSD for R160 raamaudio Drivetrain 6 08-04-2007 10:47 AM
