Old 10-27-2010, 10:00 PM   #126
GeneralTJI
Member#: 152680
11.75 @ 119mph - stock ej205 w/ 172k miles powered wagon
GeneralTJI is offline   Reply With Quote
Old 10-27-2010, 11:09 PM   #127
BONFIRE074
Member#: 166936
2006 Unicorn
Saabaru 9-2x
dug-e-fresh -
edit the list and throw me in there
11.845 @ 115.77, 18g, GD, c16, 23psi
BONFIRE074 is offline   Reply With Quote
Old 10-27-2010, 11:14 PM   #128
Speed
Member#: 67371
05 BUILT 2.4L STI
Originally Posted by PhatBotti Tuning TKR View Post
Ok, so as of now its safe to conclude that:
DEF has the fastest 207 time at 11.2
and..
Coolrex has the fastest ej205 time at 11.6
Both amazing and impressive. The 207 is a much more reliable block, and has superior heads, so no surprise here. Never say never, but its going to be close to impossible for a non built, non nitrous 205 to compete with that 11.2.
Im currently working with Bonfire to trump the 11.6. That I think is very possible. Gonna be fun trying!
-Mikey
I'm sure a stock EJ207 could do a lot better than 11.2... (Considering a stock EJ257 manage to hold together for a 10.3 @ 137 pass and 630WHP+ ) the EJ207 should be faster.
As far as a stock EJ205... I think you can get them in the 10's... but you will need a hell of a launch (plus shifting) an enough power to do 123-125 traps.
Speed is offline   Reply With Quote
Old 10-28-2010, 01:23 AM   #129
GeneralTJI
Member#: 152680
Not saying your wrong, because who knows....but I think some serious weight reduction would need to be done. Most all of them like to break rods when pushed hard (including mine). My 119 trap could have been an 11.5 with a harder launch, but getting 125mph+ traps out of one at stock weight doesn't sound realistic. But you know what they say- records are made to be broken....
Old 10-28-2010, 11:26 AM   #130
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.4 @ 103, '09 spec.B
No doubt about it... with a better launch (especially considering the mph) I could have potentially gotten a high 10 as she sat... with a few tweaks better turbo, etc... I think it could have cracked 130 mph and pulled a 10.6-10.8. But... well... were way past that now. lol
Given more time with that set-up... its almost been 5 years since I ran that... I think I am pretty sure I could have done better.
As for a stock 205... idk... 10's seem abit much. The rods snap pretty regularly in the 380-400 hp range... and I don't think that's enough power to get those traps.
def
dug-e-fresh is offline   Reply With Quote
Old 10-28-2010, 11:39 AM   #131
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
Dug, I bet your 207 was laughing at the power you made when you hit that 11.2. I push the 207's most of the time (on meth or e85) and they always seemed to be begging for more.
After 350whp on the airboy dyno, I cringe when the customer asks for more on a stock ej205.
I wish I had the luxury of doing more 207 cars. Ive tuned ~ a dozen, and I consider it to be my favorite OEM subaru block hands down.
-Mikey
PhatBotti Tuning TKR is offline   Reply With Quote
Old 10-28-2010, 11:53 AM   #132
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
-Mikey
i've got an ej207...wink wink...but with the stock vf and 5spd, probably not worth the extra tuning, lol.
scoobystas is offline   Reply With Quote
Old 10-28-2010, 12:21 PM   #133
BONFIRE074
Member#: 166936
2006 Unicorn
Saabaru 9-2x
mikey - more more more!! lol
Old 10-28-2010, 12:38 PM   #134
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Why not?? Ill be in Mass tomorrow... Wink
If you can drive, the 5 speed can withstand mid 11 second power levels on the 2.0l (370ish airboy whp).
Bonfire is making 340 right now with no problems, and I think he hits 2 step every light
STi Mikey is offline   Reply With Quote
Old 10-28-2010, 01:05 PM   #135
BenGSX
Member#: 210061
^^ Sure it can withstand it.. Just not over time..
Its rarely the hard driving that kills the 5 speeds.. Its stress over time.. Mine finally went on a very VERY soft downshift - lugging in fourth to a rev-matched third.. My foot wasn't even off the clutch pedal when 3rd scattered.. Its just stress over time that kills them..
Mine lasted around 10k miles above 370 whp on the airboy.. (closer to higher 380's - good for consistent mid 119 traps). I never launched it harder than a 1.7x for fear of drivetrain nukeage.. Now I wish I had.. hah.
BenGSX is offline   Reply With Quote
Old 10-28-2010, 01:15 PM   #136
BONFIRE074
Member#: 166936
2006 Unicorn
Saabaru 9-2x
he speaks the truth
Old 10-28-2010, 01:41 PM   #137
Kotir
Member#: 17300
1993 Widebody Wagon
748whp e98
Must fix car and get tuned...
Wagon is ~2,450lb range and the Holset made 400whp barely tuned (safe AFR, little timing on pump) and is setup to run E85 if I could get RomRaider to stop disconnecting at WOT in mid run.
Ran a [email protected] with like a 2.2 60' ft and the clutch slipping in pretty much every gear, but staying in it out of rage cause I knew I wouldn't get to run again this year... LOL
My EJ207 loves the abuse been over 300whp on Mustang/Airboy for 60k+ miles I believe
I broke my 5 speed too, abuse over time - but I think it was a 4th to 3rd mis shift that really did it in - now I have a shift linkage that isn't messed up and a 6 speed but I wish I didn't have the extra weight. Blah.
-Tim
Kotir is offline   Reply With Quote
Old 10-28-2010, 03:49 PM   #138
treystoys
Member#: 97436
03 toyota tundra
gray..missing my WRX's :(
Ohh...add mine too Doug...05 wrx sedan [email protected] 1.887 60'...ej207, rotated 3076, 93 octane. 23psi, 5spd, self tuned...whp...no accurate numbers 400ish??
I gotta hit the track again soon, was out there the other nite, watching a friends low 8 second mustang and decided to make a pass, and welded the dang clutch to the pressure plate on the heat up...lol
Trey
treystoys is offline   Reply With Quote
Old 10-28-2010, 04:19 PM   #139
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
I'll make some updates tonight...
def
Old 10-28-2010, 04:38 PM   #140
treystoys
Member#: 97436
03 toyota tundra
Cool deal Doug...lol...although I'm guessing I won't fall into #4 any longer though...maybe a separate pump gas/race gas list...or maybe not...lol with e85 available in places...blah!!
Trey
Old 10-28-2010, 05:51 PM   #141
Speed
Member#: 67371
05 BUILT 2.4L STI
Most definitely I think 10's can be accomplish in a stock EJ205. Iíve seen 124 traps in a stock EJ205 way back before the STiís came outÖ thatís definitely pushing the rods, but you donít get records unless you take a drastic approach. Some of you are starting to push things a littleÖ but you canít compare a car completely set-up in ďkill modeĒ (light as hell). Thatís when ridiculous things start to happen (like VF turbos trapping mid 120ís or 35R standard turbos going almost 150).
I mean that's what the big shop Evo's do... That's how they run 10's stock turbo. Another example... That's how Roly runs 10.4 with a standard DOM3 in a stock block with ebay parts. You have to push things a little.
Old 10-28-2010, 10:20 PM   #142
treystoys
Member#: 97436
03 toyota tundra
Totally agreed here...I know my car has way better than mid 11s available with a lightened set up...what people also need to realize is not only the weight itself a factor, but take 4-500 lbs out of one of our cars, and the entire tune can be re-done to compensate for lighter loads...ie. more timing!
I'll get there eventually, untill the time comes when I can pick up a nice daily or ideally a full sized truck, I can be content with a 93 octane mid 11 second 4 banger...atleast thats what I tell myself to keep happy for the time being!
Trey
Old 10-29-2010, 05:29 PM   #143
hauntedwrx
Member#: 115104
2003 WRX
Sedona Red Pearl
You also did this at 5500ft elevation if I remember correctly. That in itself says alot.
hauntedwrx is offline   Reply With Quote
Old 10-30-2010, 11:13 AM   #144
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
Updated... if I missed someone, repost.
def
Old 10-30-2010, 11:18 AM   #145
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
and..
-Mikey
I can't find (or overlooked) CoolRex 11.6 info... some help please
def
Old 10-30-2010, 11:44 AM   #146
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
[email protected] STi Mikey Tuned
def
I went 12.01 @ 115 in my 2door RS on a Stock EJ205 with a VF34. Do I need to dig up the time slip ?
Oh thats on 93 pump gas full weight.
RFoy91TSi is offline   Reply With Quote
Old 10-30-2010, 12:14 PM   #147
GeneralTJI
Member#: 152680
Thanks for the update dug-e!
(My Holset is an HE341)
Old 10-30-2010, 12:32 PM   #148
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
No prob... and got it!
def
Old 10-30-2010, 12:33 PM   #149
karlknaupp
Member#: 60871
2004 WRB WRX
Originally Posted by karlknaupp View Post
and then along comes a certain somebody with a built 205...
and then i actually read the title.. what an idiot. lol. carry on.
karlknaupp is offline   Reply With Quote
Old 10-30-2010, 12:42 PM   #150
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
I wasn't gonna say anything... lol!
def
shipping a short block from the us to the uk? rst4me General Community 9 02-05-2007 02:09 AM
Any vf39/stock block (no NOS) STis out there in the 11's? shemoves Proven Power Bragging 4 02-04-2006 02:21 AM
I drank a 2 liter of diet coke in 2 hours at work 24 Off-Topic 37 02-08-2005 10:03 PM
Nearly all the Espelir Catbacks in the US are at World One (45)! WorldOne Engine/Power/Exhaust 35 07-14-2004 06:28 PM
Will the US Target the French Embassy in Iraq? The Enemy Off-Topic 34 03-20-2003 02:25 PM
