Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 10-07-2005, 11:30 AM   #1
Bphillipsaz
Member#: 81416
Default Blitz turbo timer help!
I installed my Blitz turbo timer yesterday.
I tapped into the boost/vac line that goes to the from the waste gate actuator to the stock boost controller.
The prob I am having is that my boost doesnt read accurate and I get no vac numbers at all. When I am not in boost it reads 0.00 and peak boost read in bar is .91. I usually boost around 16 psi and I am pretty sure thats more than .91 bar.
I have tested the control box manually to make sure that it reads +/- but on the car it doesn't work right. I have also checked for leaks/crimps but I can't seem to find one...any ideas?
Bphillipsaz is offline   Reply With Quote
Old 10-07-2005, 01:50 PM   #2
Bphillipsaz
Member#: 81416
bumpy for some help
Old 10-09-2005, 06:16 PM   #3
dougkmcse
Member#: 85938
2004 WRX
I did that when i installed mine. Didn't work!! I tapped into the line going to the bpv. It works good. You get - and +. Good luck
dougkmcse is offline   Reply With Quote
Old 10-09-2005, 06:36 PM   #4
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
yea, I used a T at the BOV. Worked great.
kingtut12 is offline   Reply With Quote
Old 10-09-2005, 06:41 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The wastegate line is "filtered" and not a direct manifold connection. The line to the bypass valve on the intercooler is a direct manifold source and is the proper place to connect TT's, boost gauges etc.
Blitz Turbo Timer Help! gleinz Interior & Exterior Modification 6 08-27-2008 09:49 PM
Blitz Turbo Timer Help streetrcer909 Electrical & Lighting 6 02-15-2008 10:29 PM
looking to trade: my black blitz turbo timer for an apex-i turbo timer Tobey Private 'Wanted' Classifieds 2 02-21-2004 03:24 PM
blitz turbo timer help totald Electrical & Lighting 4 02-19-2004 04:12 PM
Blitz turbo timer help Si2WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-16-2002 09:03 PM
