Old 10-07-2005, 01:10 PM   #1
Whiteghost 2.5
Member#: 72994
2001 Racekor
Emerald Green
Default 2.2T block questions
I plan on using 100mm pistons in my EJ22T and was wondering if anyone had the limits the 2.2 block can be bored to?
Thanks for the help.
Josh
Whiteghost 2.5 is offline   Reply With Quote
Old 10-08-2005, 11:01 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
The largest std bore size is 96.905 - 96.915 mm
The enlarging limit is 0.5 mm.
So I would probably say 100mm pistons are too large.
Legacy777 is offline   Reply With Quote
Old 10-14-2005, 09:11 PM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
you could always sleeve the case..
Old 10-23-2005, 02:34 PM   #4
Whiteghost 2.5
Member#: 72994
2001 Racekor
Emerald Green
yeah I am considering it. How much you figure it will run to sleeve the block for 100mm pistons Ben.
Thanks
Josh
Old 10-28-2005, 01:19 AM   #5
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
LOTS of money. I'd say 700 at a minimum but probably closer to 4 figures.
cdvma is offline   Reply With Quote
Old 10-28-2005, 04:32 AM   #6
bmxpunk
Member#: 89599
1995 almost 22B:)
red
why not just spend that money on a ej257 block?
bmxpunk is offline   Reply With Quote
Old 11-03-2005, 12:39 PM   #7
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Because it would be stronger than an EJ257.
<rant>
The 257 isn't the worlds strongest block , its sleves are actually quite thin from the factory. Its also not the end-all be-all solution just because it has a tiny bit more displacement. Its REALLY easy to build a stronger block. If you want to see factory blocks that are tough he's already starting with one. Thick sleves and already has a closed deck. If I were to build something mildly a 2.2 block is a great start, much better IMHO than the 2.5
Old 11-03-2005, 10:17 PM   #8
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
sleeve a block is not as expensive 700.
the cost of sleeves and machine work to open
up the cylinder bores and press the sleeves.
just call a few of the machine shops in your town
and ask them if they have sleeved blocks before.
and of course how much they charge.
good luck..thats what i am buying myself for a bday gift
to myself...sleeves for my 2.2 to 2.5 conversion...
Ben
Old 11-04-2005, 01:28 AM   #9
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
With pistons and sleeves and work. i would say 2000
HOK is offline   Reply With Quote
2.2T Block and parts, Borlas, Trial Replica Bumper Whiteghost 2.5 Private 'For Sale' Classifieds 7 03-06-2006 12:06 AM
WTB: 91-94 Legacy 2.2T block soobyfan Private 'Wanted' Classifieds 0 09-03-2005 04:49 PM
IL:free 2.2t block scubydrew Mid West Subaru Owners Club Forum -- MWSOC 2 06-05-2005 01:13 AM
2.5 Heads on a 2.2T block RonOtter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 50 04-05-2001 11:15 PM
