Old 10-07-2005, 02:28 PM   #1
giggio26
Member#: 81393
2005 wrx
Default Springs for my wrx 05 inverted struts...
Which springs to choose??I've got a european 05 wrx.I don't want to lower the car too much or max 1-2cm
giggio26 is offline   Reply With Quote
Old 10-08-2005, 08:06 AM   #2
giggio26
Member#: 81393
2005 wrx
bumpp
Old 10-08-2005, 12:36 PM   #3
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
A good combo would be stock STi springs, preferably take-offs from someone in your area who has upgraded to stiffer springs. They would lower about 2 cm and should be a bit stiffer than the WRX spring rate. I'm not sure exactly what the spring and damper rates of the WRX inverted setup as we don't have that here (yet). But they are generally softer than the STi.
Arnie is offline   Reply With Quote
Old 10-08-2005, 02:40 PM   #4
giggio26
Member#: 81393
2005 wrx
which sti springs...I think there are a lot of models.The pink?
Old 10-08-2005, 03:12 PM   #5
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Like I said above Stock Takeoff STi springs. Just the normal black springs that come stock on an STi. There are usually quite a few used ones around and cheap. Or if you want your car lowered a bit more then the USDM SPT/STi WRX pink springs available form SubieGal. Not sure if they are available in europe. Where are you located?
Old 10-08-2005, 04:02 PM   #6
giggio26
Member#: 81393
2005 wrx
hi,I'm in italy...I've looked on mauromotorsport website there are different pink springs,not only one model
will Legacy spec B bilstien struts and springs fit my wrx 04 fast wagon Brakes, Steering & Suspension 2 09-25-2009 09:41 PM
Springs to level out 05 WRX maxpower_454 Brakes, Steering & Suspension 1 02-14-2008 12:45 PM
Question: 05 STi springs to 02 wrx [email protected] Brakes, Steering & Suspension 1 10-18-2007 01:17 PM
NY: WTT: My KYB AGXs and Gold-Line springs for JDM STI wagon inverted struts and pink chrisarella Private 'Wanted' Classifieds 5 04-10-2007 09:27 AM
Best Springs to match KYB GR-2 Struts on '02 WRX? TurismoLou Brakes, Steering & Suspension 26 05-15-2005 04:49 PM
