Old 10-07-2005, 04:08 PM   #1
T-boner
Member#: 57608
All your boost are
belong to us! Mwahahahaaa
Default Outside air temp
Here's a silly and seemingly pointless question. Where is the sensor for the outside air temp gauge on an '04 STi? If I lean way over to one side or the other, I can catch a glimpse of the readout in the instrument cluster (normally hidden behind the dumb stock boost gauge).
I'm actually wondering because I would like to know whether or not it's likely to be influenced by underhood temperatures. Doing some datalogging, and would like to use it as a reference.
Searching didn't produce anything. Thanks.
T-boner is offline   Reply With Quote
Old 10-07-2005, 04:16 PM   #2
Handsdown
Member#: 29355
in front of radiator. engine temps are probably not going to affect it too much.
Handsdown is offline   Reply With Quote
Old 10-07-2005, 04:19 PM   #3
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Most likely its in one of the front fenders or the front bumper. I know the one on my RS is about dead on accurate.
Its pretty cool, I've driven on city street and then got on the highway and immediately saw a 2-5 degree jump in temperature. And the same drop as i exit. You'd be amazed at how much warmer the air over the highway is compared to the city.
As far as i know it is not affected by under hood temps and you can use it as a reference point.
Old 10-07-2005, 05:35 PM   #4
T-boner
Member#: 57608
All your boost are
Cool, thanks!
Old 10-10-2005, 05:51 PM   #5
vwown3d
Member#: 69991
Leh Keen Approved
'68 Volvo Amazon
find it for sure? j/w
vwown3d is offline   Reply With Quote
Old 10-10-2005, 09:47 PM   #6
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
HD is right.
According to the manual, the display electronics ignore readings while the car is moving slower than 10mph so engine heat doesn't affect the displayed number too much.
Old 10-12-2005, 08:42 PM   #7
BlueSTI4Me
Member#: 34361
04.7 STI
That's where they are on most vehicles.
BlueSTI4Me is offline   Reply With Quote
Old 10-12-2005, 08:52 PM   #8
2phless
Member#: 69343
1998 TransAm cnvrtbl
I just discovered this evening that it's below the level of the TXS FMIC. My UTEC read, IA temps have been consistantly low compared to the dash for a while. I moved it up to another threaded hole in the grill. I'll see tomorrow if there is more consistancy between the dash and the UTEC.
2phless is offline   Reply With Quote
Outside air temp display | Alaskan Winters < -22 Dominator Newbies & FAQs 21 02-19-2008 09:56 AM
Official outside air temp gauge solution thread TehSpacemanSpiff Electrical & Lighting 0 04-20-2006 04:29 PM
Relocating outside air temp sensor location grippgoat Electrical & Lighting 1 07-14-2004 06:50 PM
Outside Air temp display subicboy Electrical & Lighting 4 06-03-2004 12:52 PM
STi cluster outside air temp wiring Ti-REX Electrical & Lighting 0 05-30-2003 01:09 PM
