Old 10-07-2005, 09:51 PM   #1
wrx904
Member#: 97365
2015 Mustang PP SC
Default Modified Injectors with Cobb AP Base Map 2.5
I got a deadbolt super16g and I am thinking about having my stock injectors modified to flow 800cc. I am wondering if I can run cobb ap base map 2.5 for a couple of weeks until I get a protune.
wrx904 is offline   Reply With Quote
Old 10-07-2005, 10:01 PM   #2
23b_Rex
Member#: 79394
02 gda
wrb
you're already not using the mapped-for turbo, might as well unless you have a set of pinks laying around for the mean time
23b_Rex is offline   Reply With Quote
Old 10-07-2005, 10:05 PM   #3
wrx904
Member#: 97365
2015 Mustang PP SC
I don't have the turbo installed yet. I am waiting until I get a walbro fuel pump and stock injectors modified. The super 16g will max out sti pinks.
Old 10-07-2005, 10:10 PM   #4
23b_Rex
Member#: 79394
02 gda
wrb
definetely...
my suggestion would be to only drive it to the tuner on the 2.5map... it'll get there, but prob a good idea to try to stay off boost
Old 10-07-2005, 10:18 PM   #5
wrx904
Member#: 97365
2015 Mustang PP SC
I was going to drive careful but the closest protuner to me is in North Carolina.
Old 10-07-2005, 10:29 PM   #6
hondaeater69
Member#: 60324
those injectors will flow WAY too much fuel for that map. It may run, but probably barely, at idle and otherwise. I personally wouldn't do it.
hondaeater69 is online now   Reply With Quote
Old 10-07-2005, 10:32 PM   #7
wrx904
Member#: 97365
2015 Mustang PP SC
So do you think I should drive up to the tuner in NC and let them install everything and then do a protune? Thanks
Old 10-07-2005, 10:36 PM   #8
hondaeater69
Member#: 60324
are they going to mod, clean and flow test the modded injectors?
Modded stockers must me cleaned and flowed.
Old 10-07-2005, 11:48 PM   #9
b0dh1
Member#: 35269
2011 WRX
Must be?? Not at all. It's not a bad idea though.
b0dh1 is offline   Reply With Quote
Old 10-08-2005, 09:16 AM   #10
wrx904
Member#: 97365
2015 Mustang PP SC
saturday morning bump
Old 10-08-2005, 09:19 AM   #11
J-Rex2004
Member#: 68490
'04 tippin' on
fo'fo jackstands.
Ever think to call the tuner and have him e-mail you a base map that would be closer to what you are running?
J-Rex2004 is offline   Reply With Quote
Old 10-08-2005, 09:29 AM   #12
wrx904
Member#: 97365
2015 Mustang PP SC
They told me to use the sti pinks and then I could run base map 2.5, but Jerry @ Deadbolt told me that a super16g would max out sti pinks and I needed bigger injectors than that.
If my stock injectors are modified, flow rated, and tested at 800cc would that be to big for my turbo?
Old 10-08-2005, 10:25 AM   #13
J-Rex2004
Member#: 68490
'04 tippin' on
fo'fo jackstands.
I'd pick a different tuner, or PM RiftsWRX and ask him if he would be kind enough to pick up the slack where your tuner left off. I know that he posts maps to his website for people to DL so he might help you out of the kindness of his heart.
Old 10-08-2005, 02:10 PM   #14
dunk
Member#: 15359
My stock injectors before cleaning had a variance of more than 4 percent. I would pony up the dollars for the cleaning.
After cleaning, .4 percent
Duncan
dunk is offline   Reply With Quote
Old 10-08-2005, 03:59 PM   #15
wrx904
Member#: 97365
2015 Mustang PP SC
'08 STI stock with AP base map vs Pro tuned alfriedesq Proven Power Bragging 8 10-24-2008 03:28 PM
Cobb AP 1 - stage 2 map with my mods? Ultimateone AccessPort 3 12-09-2007 01:56 PM
Use Modified Stock Injectors with Cobb OTS map? Spike700 Newbies & FAQs 1 12-01-2007 03:55 PM
Utec base map, 2.5, 550s, vf34 kaos200 Engine Management & Tuning 1 07-08-2004 01:41 AM
Anyone run a P&P'd VF34 with the COBB VF34 base map & a TMI? The Modaholic Engine Management & Tuning 10 04-14-2004 07:19 PM
