Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 10-07-2005, 10:38 PM   #1
scoobtothenoog
Member#: 92154
04 STi
SIL/SIL
Default Ramps & Jackstands SAFE?
Might be the wrong forum but of well.
Is it safe to use ramps on one end of the car and jackstands on the other? I'm doing my uppipe install this weekend. I've seen at least 2 of the install write-ups suggest backing the car onto ramps then jacking and supporting the fron with stands. Is this a safe way to go about it?
Seems like it would make getting the car up a bit easier. But is it really just as safe??? Should I worry about say.....the car rolling forward and off of the stands in front????!! LOL
scoobtothenoog is offline   Reply With Quote
Old 10-07-2005, 10:43 PM   #2
snwman
Member#: 72680
2013 Subaru STi
Satin White Pearl
I would back the car onto the ramps and then jack the front end and support with the jackstands.
snwman is offline   Reply With Quote
Old 10-07-2005, 10:46 PM   #3
hondaeater69
Member#: 60324
ramps have a lip to prevent roll off, so if you back it onto the ramps, just jack the front a tad more than the back, so it doesn't roll forward off the stands. I personally leave the jacks under the car, and put the stands under the jacks.
Old 10-07-2005, 10:47 PM   #4
vipernj
Member#: 86854
2004 fx35 02 Z06
Beryllium, Millenium Yell
it all depends on if you know what you are doing... Search in the FAQ's I think there is one about this.... Just Be careful, Know what you are doing and if the car falls, LET IT... The car can be replaced, YOU can't...
vipernj is offline   Reply With Quote
Old 10-07-2005, 10:51 PM   #5
bowenx
Member#: 6439
2002 Impreza WRX
It might just be me...but I trust my ramps more than I trust my jackstands..especially if you are going to be jerking some parts around..
I'd use the ramps on the end that I'm going to be under...then jack up the other side....
(Note: I've never done this...so I don't know how well it would work)
so...either way, good luck with it.
bowenx is offline   Reply With Quote
Old 10-07-2005, 10:51 PM   #6
blkwrx02
Member#: 38567
2002 WRX Stage 4
Midnight Black
I do this all the time. Just leave the e-brake on and stick it in reverse.
Does the e-brake lock the front or rear tires? I think I read somewhere it was the front but last time I had my car up I didn't think they were locked.
blkwrx02 is offline   Reply With Quote
Old 10-07-2005, 10:56 PM   #7
hondaeater69
Member#: 60324
E brake locks rear tires only
Old 10-08-2005, 12:30 AM   #8
scoobtothenoog
Member#: 92154
04 STi
SIL/SIL
The car falling won't bug me, its the being uder it while its falling that gets me =)
Old 10-08-2005, 12:41 AM   #9
zumnwrx
Member#: 26792
03 wrx sedan
white
jacks are safe... but i wont ever and suggest others to NOT use a jack that has teeth to adjust its hieght.
i had a set under both front jack points (under the front doors) and as i was doing my oil change i heard a SNAP...
turns out the tooth on one of the jack stands snapped off. good thing the car was only on the second tooth, but it did cause the car to tilt enough to have pinned me under the car if i would have been under that side.
edgar,
(when i get home ill take pics) and post the brand that failed in my case
zumnwrx is offline   Reply With Quote
Old 10-08-2005, 12:46 AM   #10
blkwrx02
Member#: 38567
2002 WRX Stage 4
Midnight Black
That's what I thought but someone somewhere posted that it was the front...
Old 10-08-2005, 01:26 AM   #11
rmilly
Member#: 92797
man thats scary I always wondered if thoes teeth could break, I always give the car a good pushing around after its on the stands it so if its got any instabilities I'll know about it before I'm under it
rmilly is offline   Reply With Quote
Old 10-08-2005, 02:48 AM   #12
InfamousDX
Member#: 25413
I always get nervous around my jack stands... I always think the locking teeth are gonna somehow unlock or in your case, break. I wish ramps could be use all the time... or just have a lift!
Old 10-08-2005, 06:07 AM   #13
jvic
Member#: 34953
2011 Legacy
The jack stands I use have safety pins in addition to the teeth. Guess I should start using them!
jvic is offline   Reply With Quote
Old 10-08-2005, 08:07 AM   #14
SubieRX
Member#: 16611
05' STi w/ meth inj
Tuned By Harman Motive
Haha, don't tell me you've never experienced with the ebrake before... Man your missing out. Before I got my STi, I had a lot of fun in the camry with that ebrake.
SubieRX is offline   Reply With Quote
Old 10-08-2005, 09:45 AM   #15
Lethargic1
Member#: 20998
Holy crap, the teeth broke? That's their only freakin' job, to hold stuff up. That's some fine craftsmanship for ya'
Lethargic1 is offline   Reply With Quote
Old 10-08-2005, 10:01 AM   #16
TacticalNuke
Member#: 91296
I would never get under my car without 4 over-rated jackstands (2 tons/each) and a jack with pressure in it at both the rear diff and the front jack point. Heck when I had my wheels off to clean them the side with the wheels off got the jack stands + jack, while the other got stands. To be honest I would probably never get under my car in any case without a proper lift (except for a oil change, in which case I'd use ramps).
TacticalNuke is offline   Reply With Quote
Old 10-08-2005, 10:20 AM   #17
proletariandan
Member#: 88436
in t he market again
Well TacticalNuke I think you'd call the rest of us insane. I'm using some old rusty jackstands on my WRX which I don't know the rating for and my dad says should be ok since he has used them on our 3-ton Suburban I did my UP/TBE without issue as well as SS brakelines. I always leave the pressurized jack at the end I'm under however...just in case. All of my jackstands use pins though...those teeth sound like bad news...
proletariandan is offline   Reply With Quote
Old 10-08-2005, 12:20 PM   #18
WolfInSheepsCLothing
Member#: 61197
2004 WRX
vf39 + goodies...
wait, why do you need the back of the car off the ground if you're installing an uppipe? i did a header install on an STi and i'm pretty sure you only need the front end of the car off the ground cuz thats where you're doing the work. good luck with the o2 sensor on the header, its a stubborn little punk.
WolfInSheepsCLothing is offline   Reply With Quote
Old 10-08-2005, 12:22 PM   #19
Chandy69
Member#: 16087
02 WRX
Back seat with your mom
YES IT MAKES IT A LOT EASIER!!!
Chandy69 is offline   Reply With Quote
Old 10-08-2005, 12:39 PM   #20
teh Phil
Member#: 24888
The only car I've ever run into where the E-Brake was on the front was my '91 Subaru Loyale.
teh Phil is offline   Reply With Quote
Old 10-08-2005, 01:38 PM   #21
scoobtothenoog
Member#: 92154
04 STi
SIL/SIL
Well, I'll be doin my codd dp at the same time =)
Old 10-08-2005, 01:41 PM   #22
105wrx
Member#: 75931
2005 hmmm STI?
Clark Tuned!
ok do not drive the car up the ramps you will scratch the crap out of your front bumper and hate yourself later if you are not good at painting..i did it and man was i pissed..back it onto the ramps and use the jack for the front just make sure to use jackstands and you should be fine..
105wrx is offline   Reply With Quote
Old 10-08-2005, 02:03 PM   #23
BoneStockTS
Member#: 80670
SAABs used to have the parking brake activate the front. Not sure whether they do now or not.
BoneStockTS is offline   Reply With Quote
Old 10-08-2005, 02:10 PM   #24
KmanRuffian
Member#: 48360
2011 WRX 5-door
Actually I find when I back my car up onto the ramps because the front lip is tilted down there isn't quite enough room to slip my cheap-o floor jack under the front lip. If your car isn't lowered you should be able to drive up the ramps without scraping the front lip. Anyway I have put my front up on ramps and jacked up the rear/put it on stands before. Some things to remember are that floor jacks jack in an arc so as you jack up the rear it's going to try to pull the car backward. With my car in gear and the front up on ramps this wasn't enough pull to pull it off the ramps. It just ended up sliding the jack slightly if I remember rightly. Maybe it also pulled the front wheels back against the rear lip of the ramp. Anyway if you go slow and be careful you should be able to get it up. After you get the rear up make sure the front can't roll forward any on the ramp (especially if you put the rear higher than the front). If you pulled the front wheels to the rear lip of the ramp when jacking it up with the floor jack (because of the arc motion) then conceivably it could roll forward on the ramp (there is a bit of play back and forth on some ramps) and fall off the stands. Just check to see if there is a gap in front of the wheels on the ramps and chock them with something if there is. Then they won't be able to roll forward or backward and you should be fairly safe/secure. The key is making sure the front is immobilized then you should be ok...
Hope that helps,
-D
KmanRuffian is offline   Reply With Quote
Old 10-08-2005, 03:07 PM   #25
blkwrx02
Member#: 38567
2002 WRX Stage 4
Midnight Black
Camry is FWD. I use to play with the e-brake all the time in my Honda and Mazda but with an AWD car I don't use it unless parked. I like my rear diff in one piece
FS : ramps & rollmaster for you car / project - Los Angeles 90066 fredtga SCIC Private Classifieds 0 08-15-2008 01:35 PM
For Sale: Car Ramps & creeper - $25 rbahr NESIC Private Classifieds 5 09-18-2007 03:04 PM
Noob Question on using jackstands safely Uber Wagon Motorsports 7 10-29-2005 07:28 AM
Ramps and jackstands... Penphoe Service & Maintenance 1 01-14-2002 09:19 AM
suggestions needed for hydraulic jack & jackstands cj917 New England Impreza Club Forum -- NESIC 5 03-06-2001 02:19 PM
