Old 10-07-2005, 10:46 PM   #1
vintagemilano
Member#: 92528
2000 2.5RS coupe
blue ridge
Default 2000 impreza RS, oil press indicator
Subject pretty much says it all. I tried searching the forum but kept getting tonnes of stuff not really related. What would be the best way to install an oil pressure indicator into a 2000 impreza RS? Are there kits out there or do you have to piece together pits? Thanks,
vintagemilano is offline   Reply With Quote
Old 10-09-2005, 11:34 PM   #2
erice1984
Member#: 11778
1980 VWRabbit Diesel
w/AAZ Swap
what do you mean, an after market oil pressure gauge (i.e. autometer, defi, etc..)
if thats the case, electrical or mechanical?
electrical you have the sending unit, easiest place to install it would probably be the factory oil pressure sensor hole, i believe it is right behind the alternator between the alt. and the power steering pump. get the correct fittings and a stainless braided hose to extend it out of there and mount the sending unit to something that wont vibrate very much, and get a t-fitting so you can keep your factory oil press light in there.
if you are replacing the factory unit its in the same place, behind the alt, and in between the alt. and ps pump.
erice1984 is offline   Reply With Quote
Old 10-10-2005, 10:55 AM   #3
vintagemilano
Member#: 92528
2000 2.5RS coupe
blue ridge
Sorry, yes an aftermarket electric one. I'm used to having more than an idiot light for oil pressure and figure it wouldn't be that hard to install one in this car.
Old 10-10-2005, 01:21 PM   #4
ej25power
Member#: 14771
02 RS
All Silver!
I did mine a few weeks and put the sensor behind the alternator. I had to remove the alternator to make the stock sensor/galley plug easier to take out.
I think most kits would include the sensor, you might have to retap the stock galley plug to thread the sensor in though.
Two brands I can think of that include the sensor are Greddy and Defi.
ej25power is offline   Reply With Quote
Old 10-13-2005, 12:58 AM   #5
erice1984
Member#: 11778
w/AAZ Swap
autometer does as well, the thing is you need the bsp, to bspt or something like that, basically it adapts the standard threads on the pressure sending unit to the metric ones we have on our cars.
here: http://www.wrxtra.com/ thats the website that sells it, and here is the unit itself: http://www.wrxtra.com/cat_3.html
fs: ej22 longblock from 2000 impreza burns oil bad xionide NWIC Private Classifieds 1 10-06-2009 05:04 PM
For Sale: WRX clear rear corner Tail Lights for 2000 Impreza RS tach Bay Area Impreza Club Forum -- BAIC 4 10-09-2002 02:13 AM
FS: 2000 Impreza RS Whiplash Tri-State Area Forum 25 05-24-2002 06:32 PM
