Old 10-07-2005, 11:12 PM   #1
Flyguy3663
Member#: 88430
2005 Impreza WRX STi
Default Desperate for Help with Cobb AP.. Please help
my Cobb and helix came in today and I think I might have fvcked up the ECU.. like I went through all the steps..
Plugged in green test connectors under the wheel
Turned on the car(got the CEL flashing)
Plugged in the AP itself
Initialized and had me select a map..
I went with the stage1 91 Octane since I don't have catless DP on yet
Then it told me to turn off the car and re-start and I accidently started up the ignition(I'm a dumbass)
Once that happened it went straight to the "Could not communicate with ECU! Press OK/Cancel message?"
After that I tried to repeat the whole process but I can't and the car will not start beyond the ON position, like the ignition wont start. Also the CEL does not blink even when the test connectors are plugged in..
I am really scared right now.. Has this happened to anyone? Is my ECU killed? I really need some help in figuring this out? Please help me if you can.
Flyguy3663 is offline   Reply With Quote
Old 10-07-2005, 11:18 PM   #2
hondaeater69
Member#: 60324
that shouldn't kill the ECU. . .stop what yo'ure doing, walk away, and start again later. Be sure to you have the init connector plugged too.
Old 10-08-2005, 01:57 AM   #3
Flyguy3663
Member#: 88430
thats what I did.. not by choice though.. have to work all night tonight..
can I disconnect neg battery terminal, pump brake a few times, let it sit, and then restart and hopefully reser the ECU?
I don't think it's friend either but right now I am still uncertain
Old 10-08-2005, 08:58 AM   #4
csewrx
Member#: 85254
2005 Impreza WRX
Cobb Stage 2, Rally Blue
Take the car out of test mode (unplug the green connectors and init connector). Disconnect the neg battery cable, apply the brake pedal for about a min or two. Leave the battery unplugged for at least an hour, give it probably 1 hr 15 mins. This will reset the ECU.
Plug the neg battery cable back in and attempt to start the car BEFORE you try the AP again.
If that doesn't work, attempt to reflash the ECU again using the same base map you tried before. Shut EVERYTHING off in your car, radio, air, heat, etc. Follow the directions in the book exactly and be very very careful what you do. Double check each step you're about to make. Plug in green connectors, INIT connector, etc.
If you try the reflash again and it still won't start and communicate with the AP, then you need to stop, call Cobb on Monday (since they're closed today) and ask them for help. 1-801-713-0035
I would also look on Cobb's forum for help to. http://www.wrxforum.com/cgi-bin/ultimatebb.cgi but more than likely you're going to have to call Cobb.
Hope all this helps and good luck.
csewrx is offline   Reply With Quote
Old 10-08-2005, 03:56 PM   #5
Flyguy3663
Member#: 88430
csewrx,
Thanks so much for the help.. it worked!!
I took off the negative adapter on the battery and let the car sit for about an hour. Then I tried to start it and it wouldn't; so my friend said we should try hooking the Cobb back up. So we did and we were able to revert it back to stock mode. I was really glad it turned out okay..
running the Stg1 right now.. took it out for a little bit.. went to about 100mph, car felt great.
Old 10-08-2005, 04:14 PM   #6
csewrx
Member#: 85254
2005 Impreza WRX
Glad it worked out. I really didn't do anything, just said what was already in the Cobb AP owners manual. If you have any other issues, start at page 46 in the book. A ton of stuff is in there.
need home help with cobb ap v1 subz AccessPort 2 04-16-2009 02:27 PM
I need help with COBB AP B 1 AR South West Impreza Club Forum -- SWIC 8 08-06-2008 05:16 PM
Cobb AP - Please help a newbie AnorexicSTI Engine Management & Tuning 1 11-15-2005 04:46 AM
Might need some help with Cobb AP install (Portland Area) Dark Baal North West Impreza Club Forum -- NWIC 5 03-04-2005 11:47 AM
I need help with utec logs. PLEASE HELP! dman918 Engine Management & Tuning 3 05-04-2003 02:54 PM
