Old 10-08-2005, 02:43 AM   #1
andys
Member#: 53455
2004 Forester XTI-RR
dark
Default conversion gurus - FI help needed.
Started the car today and there was a sheet load of gas / gas vapor coming out the exhaust and all the symptoms of running on three cylinders.
Isolated the problem to cylinder #4. FI plug off no smoke/gas. FI connector on the gas comes back. It's like the injector is on 100% of the time. But when the power is removed it seems like the injector is closed. It seems like way too much gas for the idle duty cycle.
There is spark. Engine is a 92 EJ20G JDM with liberty four ignitor ECU.
Any idears? Anyone experienced a stuck on injector?
andys is offline   Reply With Quote
Old 10-08-2005, 08:13 AM   #2
SubaruSMT3
Member#: 97898
andys: This would seem to indicate a short to ground on the control side of the injector. In the circuit the injector is always powered and the ECU provides ground to activate it. Look for a short to ground on that wire from the injector to the ECU. Though rare I have seen injector failures, but not being stuck open.
SubaruSMT3 is offline   Reply With Quote
Old 10-08-2005, 10:18 PM   #3
andys
Member#: 53455
dark
thanks! short to ground on the control side was what it was. sketchy. a 100% on injector makes quite the mess!!!!
Old 10-09-2005, 07:25 PM   #4
deadbolt
Member#: 990
96 Brighton and...
many
You might wanna change your oil before you run the car. A local here had an injector issue and went super rich. Washed down the cylinder walls and scored a piston.
deadbolt is offline   Reply With Quote
Old 10-10-2005, 12:19 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
you are very lucky you didn't bend a rod and as deadbolt suggested change your oil ASAP, i watched fireballs come out of valve covers and ex-coworker of mine deflooded a car that had an issue like that. It was really impressive actually, blew the valve cover right off a Chrysler Turbo 2.2l....god i still remember the sound that made
Old 10-10-2005, 03:56 AM   #6
andys
Member#: 53455
dark
ok i'll check on the oil. I never drove it tho....it was only on idle for a few seconds at a time
OT food gurus. Menu help needed Obnoxio Off-Topic 27 09-26-2008 06:39 PM
calling gurus, major help needed! v8eaterWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-28-2006 09:38 AM
Conversion Gurus I need your help ejh25 Subaru Conversions 0 08-25-2006 09:18 AM
AWD conversion gas gauge help needed LIFEFORM Subaru Conversions 0 10-19-2005 05:37 PM
Mac gurus - email help needed HoRo1 Off-Topic 10 09-08-2004 03:04 PM
