Old 10-08-2005, 09:59 AM   #1
notyet227
Member#: 58142
2002 WRX/forester
WRB/Silver
Default small problem with HID kit.
I installed a PnP 9007 6000k hid kit on my 02 wrx. the only problem i have is the high beam light is slightly on and my gauges on my a-pillar are very dim. when i turn my foglights on the high beam light comes on fully and the a-pillar gauges get xtremly dim. whats wrong here? love the hid's though.
notyet227 is offline   Reply With Quote
Old 10-08-2005, 02:33 PM   #2
kcook
Member#: 78074
2005 STi
they should get dim... but u need to upgrade ur fuses boy... u do know that right??
kcook is offline   Reply With Quote
Old 10-08-2005, 02:35 PM   #3
FNR32
Member#: 84147
03 WRX
which fuses does he need to upgrade? im thinking of installing an HID kit very soon
FNR32 is offline   Reply With Quote
Old 10-08-2005, 02:59 PM   #4
Handsdown
Member#: 29355
what's the manufacturer of said "PnP" kit? might help others diagnose the problem.
Handsdown is offline   Reply With Quote
Old 10-08-2005, 10:06 PM   #5
notyet227
Member#: 58142
2002 WRX/forester
WRB/Silver
why would i need to upgrade my fuses. the kit connects to the battery for power and uses the existing headlight harness for the switch. i have my lights for my gauges hooked up to the headlight wire inside the car. the lights used to go off when i turned my high beams on. should i just find a diffrent power source for gauges?
Old 10-10-2005, 10:00 PM   #6
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Why not use the OEM gauge lighting circuit to power your gauge lights? You can tap into it at the HU harness as well as other places.
Old 10-11-2005, 06:58 PM   #7
notyet227
Member#: 58142
2002 WRX/forester
WRB/Silver
i figured out the problem thanks
Old 10-16-2005, 12:28 PM   #8
STiLIN04
Member#: 45758
2004 STi
HID's use less power than incandescents or halogens after they are on for a few seconds, but the initial start-up creates a surge that requires higher-amperage fuses to be used. At least you solved your problem, but hopefully my $.02 helps someone.
STiLIN04 is offline   Reply With Quote
Old 03-22-2006, 10:04 PM   #9
readymix
Member#: 59839
2004 WRX
Platinum Silver
Nice, good to hear....NOW WHAT WAS THE GODDAMNED SOLUTION!?!?!?! I see this all the time around here. "I fixed the problem"...and how?
readymix is offline   Reply With Quote
Old 03-22-2006, 10:29 PM   #10
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Yes, you should find a different power source for your gauges; your gauges shouldn't turn off when you turn on your highbeams. There is a lighting circuit and there is an instrument lighting circuit, you want the latter of the two.
No kidding.
specialev is offline   Reply With Quote
Small Problem with H11 HID Shinra21 Electrical & Lighting 6 10-30-2007 08:59 PM
small problem with the recaro survey philip_g Off-Topic 2 03-09-2004 08:40 PM
small problem with vf-22 at track, help pierceman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 12-09-2003 05:12 PM
Problem installing HID kit fuzzy logik Electrical & Lighting 7 07-27-2003 01:08 PM
Small problem with dual tip Stromung jack_uw Normally Aspirated Powertrain 21 06-25-2002 09:58 AM
