Welcome to the North American Subaru Impreza Owners Club Thursday January 29, 2015
Old 10-08-2005, 01:47 PM   #1
impr25rs
Member#: 60162
04 Aspen RS
The One Not Turbo'd, NA!!
Default 04 Headlight HELP
Okay i have a 04 RS with a small problem. The other night my driver side low beam went out. No big right. However, when I went to pull the bulb, I found that the buld i s fine, not burnt out. I was like So I tried replacing it with another bulb and it still did not work. I was using these white bulbs I found. So I thought that I would put the stock style ones back in. THe funny thing is that, when I changed them I didn't put the passenger side one all the way in and the drivers side low beam began to work and the passenger one was not. So I went and fixed the passenger side one and now the drive side low beam will not work. What the hell? I am stuck. I checked the fuses and they are fine. The bulbs are connected fine. The only thing that I can think of is that there is a grounding problem. I should mention that the black plastic around the connectors for the bulb is melted off. So other than that I am Help PLZ!!!
impr25rs is offline   Reply With Quote
Old 10-08-2005, 02:26 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
There's your problem. Those bulbs you "found" ran too hot and damaged the connectors and harness. The fix will be to replace the connectors and any damaged wiring, and only use the proper stock wattage bulbs from now on.
Old 10-10-2005, 04:28 PM   #3
impr25rs
Member#: 60162
04 Aspen RS
Mulder, only the connector had the plastic melt off. So where can I replacements? From Subigal?
Removing 04 2.5RS headlights?????? HELP!! ThreeSheets2116 Interior & Exterior Modification 14 10-22-2008 09:31 PM
wtb: 04-05 headlights. help! Matzo Balla Private 'Wanted' Classifieds 6 07-22-2006 11:27 PM
Help clearing 04 headlights? Flyn'Rex Texas Impreza Club Forum -- TXIC 10 07-12-2004 06:15 AM
Anyone want to help me do the 04 Headlight mod? svxr8dr North West Impreza Club Forum -- NWIC 0 01-02-2004 03:43 PM
HELP!HELP!HELP! How to put back a 04 headlight??? chopaholix Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-12-2003 07:52 PM
